02-03-2023, 10:15 AM | #1 |
Rep 36
Short Circuit to Ground
Last night I got a drivetrain malfunction with a check engine light and multiple codes about short circuit to ground. The car repair ppl told me the battery was weak and would eventually cause issues, do I just need to replace the battery or is this something else?
02-03-2023, 11:40 AM | #2 |
Rep 16,671
A weak battery doesn't cause a short to ground. You need to pull codes with a reader to see what's shorting. If you don't have one now you know why you should. Many reader apps are free, search them.
02-03-2023, 11:43 AM | #3 |
Rep 36
Sorry I’m not sure what happened, I tried to attach the codes but it didn’t seem to work. The confusing part to me is that it’s in so many places.
02-03-2023, 01:17 PM | #4 |
Rep 16,671
You can look each of them up here to see possible causes and cures:
https://bmwfault.codes/ Also try googling each, as in 'BMW 135B11'. That will show you posts from various sources who've dealt with the same problem. One problem can sometimes cause others, in a cascading effect. For instance, a faulty ABS wheel sensor will throw codes for everything that uses wheel speed information, which is half the iDrive processes. Fix that one problem and the rest go away. |
02-09-2023, 10:34 AM | #5 | |
Rep 36
10-05-2023, 11:29 AM | #6 | |
Rep 84
10-05-2023, 11:31 AM | #7 |
Rep 36
