02-13-2023, 08:24 AM | #1 |
Rep 412
Fried DME on N55 ???
Hi all,
I have replaced this weekend my valve cover gasket on N55 from 2014. It takes time but have done the job many times on N54, N55. Bad luck, I forgot to unplug the battery before starting the job and unfortunately, the + cable that I disconnected has been in contact with a ground and generated some sparks... I was not to worry at that time since I assumed that worse case, I would need to replace a fuse but seems not... After putting back all parts, I have tried to start the engine but even if crank running, engine was not starting. I checked all my connection but everything was ok. I have then plugged my Ista and saw a lot of faults that you can see on the picture. I though that it was the ISM as per ISTA instruction but I ave tried this ISM on another car and it worked... I am really worried now since all post that I read are mentionning a DME failure...I would expect that some asfety would blow before the DME... If any of you have any idea that would not cost me 2000$...If it was the DME, can I buy a used DME and just have mine cloned to the used one?
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
02-15-2023, 12:22 PM | #2 |
Rep 412
I have found the issue in my case, too bad that I sent the DME for repair before checking that but it is one of the fuse in the distributor B+ next to the battery that is down. I checked the ISM and all fuses of the car but forgot about this one...
I have requested the return of my DME asap and found a dstributor B+ unit on ebay for around 20euros.
AmuroRay2851.50 |
02-15-2023, 02:13 PM | #3 |
Rep 4,969
Awesome news.
02-15-2023, 03:01 PM | #4 |
Rep 679
Dodged a bullet, buddy.
I once serviced a friend's E70 X5 with the DME located under the intake manifold. Turns out that their car underwent some engine bay wash by a mechanic before me; and some of the soap got seeped into the wiring harness junctions at the DME's 3 main sockets. Long story short, a circuit concerning Valvetronic control and gas pedal signal got real funky, kept throwing faults even after replacing those units. Car drove rough the whole time. I then checked the DME's pins and found some pretty harsh oxidation witness marks on the pin location where it concerns the gas pedal and Valvetronic controls. Luckily, I was able to purchase another used DME and have ByteTronic help me clone the DME and got everything to work properly afterwards. Total spent was under 600 bucks. These N55 DME's are in a location with lots of exposure, absolutely not the ideal place to put it. Anyways, glad you're able to resolve it without spending thousands. Happy motoring.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
02-15-2023, 10:55 PM | #5 |
@lbb_kev
524
Rep 547
The terminal 15n codes are a dead giveaway. Glad everything worked out for you.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
02-16-2023, 04:42 AM | #6 |
Rep 412
Thanks alot gusys for your feedback. Lesson learned for the disconnection of the battery every time that am working on engine bay...
09-11-2024, 01:16 PM | #7 | |
Rep 16
Drives: 2011 335D Sport, deletes, 2.5
