04-16-2024, 10:32 PM | #1 |
Rep 5
Wheel and tire question for Xdrive.
Hello! I have looked for the answer to this question on the other threads and couldn’t find it.
I'm currently on the market for a F30 340i and I'm looking at one to maybe get this Friday. The only thing is is that it's X-drive. I have a set of wheels coming that are 18x8.5 ET30 for the front and 18x9.5et30 for the rear. Will I be able to run this setup? And if so what tire size should I go with? I'm looking at getting a 3.5" drop with 12mm spacers and I just want to make sure I can use these wheels. I know I can probably use those wheels but l'm more worried about the tire sizes. Thank kind of you in advance! I'm going from a e90 RWD 328i so help is needed haha thank you again! |
04-17-2024, 01:25 AM | #2 | |
Rep 4,380
225/45/18+255/40/18, you'll need the stretch at the rear for x-drive max recommended lowering up front is 1.5". lowering changes angle of half shafts into front diff, which puts more stress on the axle. it may also unseat as well. you'll surely have problems with 3 5" lowering. post pics after everything is done |
Aurora_328i0.00 |
04-17-2024, 06:45 AM | #3 | |
Rep 5
04-17-2024, 08:38 AM | #4 |
Rep 4,380
You can determine the front spacer to match the rear after everything is installed.
Probably 12.5mm spacer up front only . Last edited by alohasurftoad; 04-17-2024 at 08:44 AM.. |
04-17-2024, 09:55 AM | #5 |
Melbourne Red F32 B58
59
Rep 99
Recommend adjustable end links from SPL when you lower the car. It helps.
I am all square with xDrive. 18x8.5 et35 245/45/18. Sitting on KW Street Comfort coilovers.
Real drivers use 3 pedals. Its about connection.
04-17-2024, 09:56 AM | #6 |
Rep 5
