01-08-2017, 08:52 PM | #199 | |
Rep 369
01-08-2017, 09:00 PM | #200 | |
Rep 189
I have learned to go overkill on the gauges and logging. |
01-08-2017, 10:05 PM | #201 | |
Rep 194,617
01-08-2017, 10:27 PM | #202 | |
Rep 189
If I use a JB4, I understand that the OBD2 port is now taken over (completely/physically in the case of the B58) and cannot be logged from there. This is not a big deal because the JB4 has an alternative option for logging, which is built in to the device. But I have trying pretty hard in this thread for anyone to tell me what options are available when the AA A8, or any other non-JB4 device, is installed. Still haven't figured out why people can't answer simple questions, and just type in the first thing that pops into their head about what they want me to hear. |
01-08-2017, 10:31 PM | #203 | |
Rep 194,617
JB4 is the only one that has the datalog feature, if you are using a third party application (Dashcommand) you can datalog whether the car is stock or is using a tune (AA, Dinan,etc...)
Roki187126.00 |
01-08-2017, 10:46 PM | #204 | |
Rep 189
At least I kind of got you to answer my question. If you are so confident in your technical responses, please tell me this: 1. Do any of these other products block, or take up significant bandwidth, of the OBD2 port to where a third party logging solution would not be realistic? 2. When these other products are installed, do all parameters get reported as actual/true values (boost, timing, fuel, IAT)? Or are they the "dummy" values like in the case of the JB4? Honestly, if you don't know you should just keep your speculation and misinformation to yourself. I know this is your thread, but you shouldn't keep posting inaccurate and incomplete responses. Leave that to the Dinan representative in his own threads. |
01-09-2017, 05:41 AM | #205 | |
Rep 369
The AA tune does not log but it does not plug into your obd port so you can use what ever device you'd like to log. The jb4 uses the obd port but it does log. Your sampling rate (accuracy) depends on the device you're using. Last edited by Roki187; 01-10-2017 at 05:59 AM.. |
01-09-2017, 07:07 AM | #206 | |
Rep 4,599
For a discrete install and to keep OBD port clear, you can hardwire JB4 canbus to the back of the OBD port - photo below shows how:- OBD --->> JB4 Canbus Grey --->> Green Blue --->> Brown. BP
Current '22 X3M LCI.. |
01-09-2017, 07:51 AM | #207 | |
Rep 151
-Jb4 can provide you with all you seek in terms of logging, clear codes... etc. I've ran it since early release when it was in BETA. -AA doesn't have added features. Also, you I believe you can still use your OBD2 for dataloging your 3rd party device if you go with the AA Tune. JB4 plugs into OBD2, so no third party logging. |
mike@x-ph.com26143.00 |
01-09-2017, 09:55 AM | #208 |
Rep 498
This is the funniest and most stupid thing I've read in 2017 yet.
BMS must spend countless hours filling up the memory of the JB4 to have it spit out the dummy values. ... the 'dummy values' can be seen on their site right next to the bmw throttle cables, supercharger belts and accelerator pedal fluid. |
01-09-2017, 11:59 PM | #209 | |
Rep 189
I am trying to convince MHD to add the B58 to his app(s) just for logging purposes. He already said it's doable, even though actually tuning of the B58 could literally be years away. A couple issues I have with logging with Torque or DashCommand via the OBD2 port are:
01-10-2017, 01:46 AM | #210 |
2JZ-GTE
3146
Rep 4,112
Another issue when logging via ODB is if you're using a piggyback it lies to the ECU..... thus the logs show your ECU is seeing.
01-10-2017, 06:15 AM | #211 | |
Rep 4,599
If MHD is used on B58 for logging only, when you run JB4 or any other tuning box, then you may find that MHD doesn't log the "true" parameters. As mentioned already, JB4 datalogging is extensive, even showing "true" and "duped" boost. My suggestion would be you use JB4 to tune and datalog initially until such time that MHD has a turn-key B58 tune/datalog solution then switch from Jb4 to MHD.
01-16-2017, 02:45 PM | #212 | |
Rep 526
2. When using the Active-8 the only parameter that will not be a true value will be boost. Timing, Fuel, IAT etc will all be accurate. Therefore you will still be able to accurately measure how the car is running by monitoring AFR and timing. |
01-16-2017, 03:45 PM | #213 | |
Rep 189
DS_BMW1690.00 |
02-25-2017, 07:21 AM | #214 |
Rep 3,211
416 ftlb @ ~3500rpm .. this is fairly awesome crazy torque but does this not concern anyone that the 8HP50 is only rated to 368ft lb and torque this high in this most accessible range on an everyday basis wont affect their tranny prematurely?
We're talkin 40-50 ftlbs (~>10%) over ZF ratings most of the time in everyday driving with this much power at only 3500rpm |
02-25-2017, 08:03 AM | #215 | |
Rep 401
02-25-2017, 09:44 AM | #216 |
Rep 3,211
I dont think the rest of the components of the B58 setup will have an issue with that but the expensive tranny is what I'm concerned about.
And yes I've heard lots of guys running north of 400 ftlb but I've also heard 335 guys putting tunes on and subsequently having their ZF 8hp45 slip.. and not every guy is gonna post their problems online so I wonder how much its really happening. This tune is compelling though the torque jam in the mid-range is useful. What kind of performance is to be got from just 91 octane? |
02-25-2017, 08:13 PM | #217 |
Rep 5,174
I was initially concerned, but with my Activ8 installed, it's pretty apparently BMW has integrated a lot of torque safety features. If I try to do a WOT shift under heavy load, car goes into a torque management throttle cut.
You can feel it slightly with the stock car on the 2-3 hard shift. With a tuner, it's VERY apparent. You just need to get off the throttle a bit during the shifts to mitigate it. |
02-26-2017, 10:10 AM | #218 | ||
Rep 413
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
03-23-2017, 12:27 PM | #220 | |
Rep 194,617
Yes it will. When you place an order with us, you can enter this note in the comment section
