04-14-2022, 05:15 AM | #2201 |
Rep 1,181
25L of E85 on a full tank is E38.6 mix.
Also why are you mixing with 94 ? you should be mixing with 98.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
04-14-2022, 05:18 AM | #2202 |
Rep 232
04-14-2022, 05:23 AM | #2203 |
Rep 1,181
You are at E38.6 which explains the corrections.
04-14-2022, 05:23 AM | #2204 |
Rep 232
04-14-2022, 05:24 AM | #2205 |
Rep 232
04-14-2022, 05:32 AM | #2206 |
Rep 1,181
Ok, as I said best solution is to increase the E% but your HPFP might crash.
So you will try the highest tune below HPFP E40. Which is HPFP 95 OCT tune.
04-14-2022, 09:22 AM | #2207 | |
Rep 1,181
Yes it makes sense.
Check this: https://f30.bimmerpost.com/forums/sh...76&postcount=7 Quote:
dinan5m34488.00 |
04-14-2022, 05:27 PM | #2208 |
Rep 232
04-14-2022, 05:34 PM | #2209 | |
Rep 970
04-14-2022, 05:44 PM | #2210 | ||
Rep 232
https://datazap.me/u/lam240i/95-octa...&data=3-21 |
04-14-2022, 05:48 PM | #2211 | |
Rep 970
04-14-2022, 05:49 PM | #2212 | ||
Rep 232
04-14-2022, 06:33 PM | #2213 |
DisplacementReplacement
604
Rep 1,291
That's so interesting to me because i'm seeing the exact opposite, E40 relatively clean and 95 a basic mess.
2020 X3M /// MHD Tune
2017 240XI Hybrid Turbo / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 2007 328XI Stock |
LanceM26115.50 |
04-14-2022, 07:13 PM | #2214 | |
Rep 970
If you mixed 93 pump with exactly 10 percent ethanol in it and you mixed exactly 85 percent e with it at those ratios you get barely over 95.3 octane. Which is why it was recommend you splash in a little more E. I would measure the E content of any ethanol you add to make sure otherwise you could easily fall under 95 octane. https://www.brewcity**********/ethanol-calculator/ |
04-14-2022, 07:23 PM | #2215 | ||
Rep 232
WrxToBeamerGuy516.00 |
04-14-2022, 08:15 PM | #2216 |
Rep 970
I'm not sure what the TU pump ethanol limit is but yeah I agree that it is strange that its doing that. Only thing I can think to try is adding more ethanol but first know the limit of the TU pump before you do that.
04-15-2022, 01:08 AM | #2219 | |
Rep 1,181
HPFP 95 OCT log look great and with it you can go down to E35 fuel mix ( or maybe less) to ease the pressure on the TU pump.
And you don't have the hassle of adjusting the E% to exactly E40. Also 100-200 should be better now, curious to know what time you run. If you still want to run the HPFP E40 tune you have to increase the E% above 40% but you risk crashing the TU pump, it's up to you. p.s please add abm. temp in your log options. Quote:
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 04-15-2022 at 05:40 AM.. |
04-15-2022, 01:21 AM | #2220 |
Rep 1,181
In theory yes but practically it depends how the tuner setup his tunes, some tuners prefer timing over boost others prefer boost over timing.
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 04-15-2022 at 02:38 AM.. |
dinan5m34488.00 |
04-15-2022, 06:58 AM | #2221 | |
Rep 232
And I will try to lessen my E to about e35 and keep going down from there. 100-200 will probably be posted by Monday, maybe even sooner. |
04-15-2022, 07:08 AM | #2222 |
Rep 1,181
No those are enough.
Please log after trying HPFP 95 map on E35 mix. How did you find the acceleration with the HPFP 95 map ?
