06-04-2020, 04:01 PM | #2267 | |
Matusov
Rep 43
Updated item 2)
1) Menu button does not always switch to Carlinkit. I had to reset it and my phone few times to get it to show up. 2) I was not able to answer any calls as the it won't scroll to the little call pop up. I have not figured out how to answer calls. ---I figured out that i had to hit the UP button on the iDrive controller to select the Pop Up window. 3) in AA the currently selected item overlay was not showing up. had to reboot to fix it. any thoughts? I'm thinking about going back to 20.4.2.14. can I use the link from the first page for carlinkit? Last edited by Matusov; 06-05-2020 at 07:51 AM.. |
06-04-2020, 04:12 PM | #2269 |
Rep 1,217
06-05-2020, 12:35 AM | #2270 |
Rep 30
Somebody knows what CarPlay U/D key is?
There is another setting “alter volume” which I don’t know what it does. Also, I find the notification sound too loud, any suggestions? Thanks Edit: it is the Carlink box |
06-05-2020, 01:40 AM | #2271 |
Rep 147
I haven’t used any other MCU so i have no base to compare, but from the short time of use I didn't sense any noticeable lag.
Well I have talked too soon. The System keeps rebooting it's self when ever I start the car or trying to go back to the mmi menu are going back to original system. As for lag? it's wirless AA so it's not always snappy but nothing major, unless you try to use the dailer (with a whorrible UI) than it takes a sec for it to register a click and move to the next number. I guess I should have gone with Android Multimedia, it's not perfact but much more fliud. Last edited by Mollyran; 06-05-2020 at 04:15 AM.. |
06-05-2020, 05:44 AM | #2272 |
Matusov
Rep 43
alter volume controls Maps navigation sounds and such alike without impacting media sound.
06-05-2020, 06:26 AM | #2273 |
Rep 2
06-05-2020, 06:37 AM | #2274 | |
Rep 43
Maybe updating my box might resolve. Not sure. One thing I have learnt is that Google aren't putting much effort into AA and its shows with the numerous bugs introduced every update. |
Matusov13.50 |
06-05-2020, 07:28 AM | #2275 |
Rep 14
HELP ME! No skip buttons working!
Hi All,
i just brought a Andream CIC. i installed everything and it works great! However i have no skip forward or back buttons on either the steering wheel or idrive. i press them and NOTHING happends The other buttons like Call and Siri on the steering wheel work fine! i have tried the following: Checked all wiring tried fitting the optional idrive loom that bypasses the idrive (No difference) checked jumper switches. the buttons work fine operating the orginal idrive system its running the following: SDK: 25.0.0.5.6.0.0.0 CUST: v2.1.0.5.1.gpe.c MCU: 20.5.18.17 Please help thank you friends! |
06-05-2020, 08:53 AM | #2276 | |
Rep 768
For now you can use the left/right arrows in the radio (those next to number 8). This was a key feature for me so for now I went back to an old bimmertech firmware that allows the skip function via idrive. |
06-05-2020, 08:55 AM | #2277 | |
Rep 30
06-05-2020, 09:58 AM | #2278 | |
Rep 14
06-05-2020, 10:58 AM | #2279 | ||
Rep 768
You can use Siri to skip songs then but guess the plan B is to revert to the Bimmertech firmware until Andream releases an update. Send them a note on this and hopefully they implement it the next release |
06-05-2020, 11:40 AM | #2280 | |
Rep 102
06-05-2020, 12:17 PM | #2281 |
Rep 59
I get a red screen when switching to the carplay unit with the idrive buttons. I can hear it click but it's just a red screen. Has it happened to anybody else? I played around with the switches but couldn't find a combination that works.
When switched to iDrive everything works. This is on an E60 with 8.8" CIC if it helps. |
06-05-2020, 02:49 PM | #2282 |
Rep 28
Hi, im half way through the install for the andream nbt unit on a 2015 420d. Everything seems to be working fine with the exception of the steering wheel scroll button, the others work ok. Also both my iphone and my android work fine wired but i cant seem to connect either wirelessly. Any ideas
Many thanks. |
06-05-2020, 03:56 PM | #2284 | |
Rep 30
06-05-2020, 04:00 PM | #2285 |
Rep 694
OK, so again forgive my ignorance...when new updates come out, how are they installed? Is this only via laptop and cable or are there other methods for an idiot like me?
06-05-2020, 04:06 PM | #2287 |
Rep 30
andream, android, android auto, apple, carplay, mmi, retrofit |
