01-01-2021, 03:44 AM | #2355 | |
Rep 1,049
thx Eric XD Kri Last edited by Kri; 01-01-2021 at 08:21 AM.. |
LittleSamurai4.50 |
01-01-2021, 08:13 AM | #2356 | ||
Rep 2,445
Drives: E63 645Ci
LittleSamurai4.50 |
01-01-2021, 08:59 PM | #2357 | ||||
Rep 33
cn.manstep.phonemirrorBox |
01-01-2021, 09:06 PM | #2358 |
Rep 25
01-02-2021, 04:55 AM | #2359 |
Rep 3
Problem with update to 2.6.1
Hi guys, i've copied downloaded zip file to FAT32 formated pendrive which was used before to update to 2.5.3 version which was ok. Now when try to update to 2.6.1 and after i connect pendrive to device, it doesn't recognize the update and nothing happens. I tried switching pendrive between USB1 and USB2 but no luck. Any1 have similar problem or know what can i do?
01-02-2021, 07:22 AM | #2360 | |
Rep 500
01-02-2021, 07:33 AM | #2361 |
Rep 3
01-02-2021, 10:21 AM | #2362 | |
Rep 55
I've tried updating the factory_config file as follows, but when I select the option in the GUI, the theme does not change? I'm running 2.6.1... What have I done wrong here please? |
LittleSamurai4.50 Alex201.50 |
01-02-2021, 09:05 PM | #2363 |
Rep 500
Any one know how to stop default music player from playing music on startup? I prefer to use Poweramp. My current favorite setup is running split screen with Poweramp v3 and iGo or Waze.
LittleSamurai4.50 |
01-03-2021, 12:04 AM | #2364 |
Rep 556
"factory menu" and choice "default audio player"
LittleSamurai4.50 |
01-03-2021, 01:52 AM | #2365 | ||
Rep 84
Then , the next time you will start your engine , you will be on the idrive again and the automatic media player engagement will not exist. |
01-03-2021, 03:35 AM | #2366 |
Rep 500
LittleSamurai4.50 |
01-03-2021, 03:39 AM | #2367 |
Rep 500
I just want it to boot directly into android. Will try out Automate app to kill default player and load poweramp v3
01-03-2021, 04:23 AM | #2368 | ||
Rep 84
They could have an option in the factory settings , letting you to choose if you want it or not. And , of course , the best would be to let you define what app the default media player you like to launch (from the media player tile). |
01-03-2021, 04:55 AM | #2369 |
Rep 556
The automatic start of the default audio player must be a new feature built in because: without it you will have an audio bug.
And here we have configured (automaton / tasker / KSW-SoundRestorer / etc ...) so that the default audio player starts to avoid either too low volume or rotten and distorted sound. In short, the simplest is a PLC or tasker to: launch the default audio player, stop it, kill it, launch the application of your choice (adjust its volume, etc.) Good luck nb: But it's still cool that on the new versions, with the updates, this audio player starts, because it saves you a hell of a bug. Simply configure PLC or tasker to stop (or pause) it after launching (and then launch your application of course) |
01-03-2021, 08:06 AM | #2371 |
Rep 500
I have a temp solution by pointing the default player to play a silent file. Later I'm going to try using automation script to kill the player and load Poweramp v3 to left split screen.
01-03-2021, 11:22 AM | #2372 |
Rep 556
01-03-2021, 02:02 PM | #2373 | |
Rep 84
If you listen to a song from Androids default player while you turn off the car , then the next time you startup your car , media player starts by it's own. |
01-04-2021, 01:12 AM | #2374 |
Rep 10
Cheers to everyone here for all your great advice. Recently encouraged me to get an Avin 10.25 Android 10 unit for my 135i.
Overall, hasn't been too bad but there have been lots of teething issues that I've been working through (i.e. DAB+ suddenly dying). Kinda been two steps forward, one step back. However one major bug bear - the aftermarket iDrive controller. I've decided I will keep it, but at the moment it has limited functionality since the keys are automatically mapped to pre-determined functions. Is there any way to remap all the keys (e.g. like a config file to edit)? I'm primarily running Android Auto through the unit but would love to map the keys to on it to other functions e.g. DAB+ app (if I can get the dongle to work). Also wonder if there is a way to improve the response speed of this aftermarket iDrive unit. |
01-04-2021, 02:32 AM | #2375 |
Rep 556
01-04-2021, 09:12 AM | #2376 |
Rep 8
Hello friend, thank you all very much I have learned a lot with you!
I have a snapdragon android 10 and I do not know if I have it installed incorrectly or is it so When I travel and I put the browser "google maps" and listen to music with Spotify, when I stop at a gas station to refuel and continue the march after a few minutes, everything has been canceled, the navigation route, the music I was listening to ... this is it normal or need to put a continuous power cable without a lock? Thanks a lot |
