06-22-2015, 04:56 PM | #221 | |
Rep 60
So how much of the wires do you think you can hide in the housing ? |
06-22-2015, 04:59 PM | #222 |
Rep 616
06-22-2015, 05:00 PM | #223 |
Rep 1,035
the physical diagram i posted earlier shows which wires i plan on keeping inside the housing and which ones are outside the housing - nothing has changed. i wanna keep all the stuff that can break outside as much as possible .. or at least accessible.
gregtaylor160.00 |
06-22-2015, 06:01 PM | #224 |
Rep 60
I got the HIDs from TRS, and it seems to have too much crap with it. I am sersl;y thinking about going down to doing only one of the projectors instead of quad.
06-22-2015, 06:11 PM | #225 | |
Rep 616
What projectors did you get? |
06-22-2015, 06:14 PM | #226 | |
Rep 60
2.5" Mini H1 Bi-Xenon HID Projector Lens with Shroud For Headlight |
06-22-2015, 07:19 PM | #227 |
Rep 1,035
Whats that hanging on the input side of your ballast? Is that a CANBUS resistor circuit? I had asked TRS if it was needed and the answer was a little vague ...
gregtaylor160.00 |
06-22-2015, 09:09 PM | #228 | |
Rep 60
It is a capacitor link as described by TRS. (anti-flicker capacitor link) it was optional. I am not sure if is necessary, but i bought it just in case. |
06-22-2015, 09:32 PM | #230 |
Rep 1,035
Ah... interesting.
That relay harness i mentioned in an earlier post had one attached as well. I took apart the relay to test it this weekend and noticed that it had a capacitor attached between the power and ground lines - the whole thing was hidden under this huge heat shrink tube that was covering up all the lines. Usually they put those there in case there are unwanted fluctuations on the line - the cap smooths out the signal to keep the lights from flickering. I'm not sure if its needed, but i guess it can't hurt. Btw.. after testing that relay harness this weekend, its not good as is. I found that the wire gauge is slightly too small for my comfort, so i'm going to have to beef up the wires (14 awg) to provide some margin. Sorry. |
gregtaylor160.00 |
06-22-2015, 09:45 PM | #231 | |
Rep 1,035
You could take your car out at night and mark where your current halogens hit the garage or any flat vertical service, and mark the reference point on the ground/road where your car is sitting. Then when you take off your bumper and mount your new lights - while the putty is still setting, and the lens is still off, point your new lights at the same spot while your car is in the same position, and check it that way. Obviously, doing it like this is going to be a lot less convenient as you will have your bumper off, while your lights are still being worked on, so you'll need to plan it out well. At that point, everything else will have need to be done except for the putty to set and your lens to be sealed. Or instead of doing it against the garage, you could have another car in front of you and make sure your new lights are positioned low enough that its not blinding the person in front of you or an oncoming driver. Again, not the best or most convenient way to do it, but i'm sure you can come up a bunch of other ideas as well... |
06-23-2015, 01:32 PM | #232 | |
Rep 60
Do you have the headlights installed on your car ? (the quad ) seems very white n bright |
06-23-2015, 05:31 PM | #233 |
Rep 1,035
No, those are my current GP thunder halogens - they are close to 6000k color temp though. I'm just going to use those pics as a secondary (sanity) check to approximate that the new beams are at about the right height.
06-24-2015, 03:16 PM | #234 |
Rep 616
The ebay seller has got hold of the correct size rings and they're on the way to me, heres some pics of them he sent me...
If anyone else has been sent the wrong rings it might be worth contacting him. |
06-24-2015, 06:05 PM | #235 | |
Rep 60
06-25-2015, 01:37 PM | #237 | |
Rep 616
http://www.ebay.co.uk/itm/261942278432 Make sure you ask him for the 120mm and 128mm rings, I would save my money next time and buy them from squidlyboy. |
06-25-2015, 04:33 PM | #239 | |
Rep 49
06-25-2015, 05:17 PM | #240 | |
Rep 616
a pic from squidlyboy that show the holes... |
06-25-2015, 10:09 PM | #242 | |
Rep 4
Thanks guys 👍 |
angel eyes, corona, f30, morimoto, projectors |
