03-15-2020, 05:01 PM | #221 |
Rep 133
6WB
Hi, after installing the black panel on 340i the maximum speed on dashboard is 263km/h. How to change this limit on dashboard thru Esys coding?
Thanks |
03-25-2020, 08:15 PM | #223 |
New BMW owner
139
Rep 629
Drives: BMW 316d, BMW F40 116d
If I would happen to want to install a 6WB in my 2014 F30 with i-Step : 13-11-503 I would have to flash the FEM_GW and HU_NBT?
04-04-2020, 01:25 AM | #224 |
Rep 244
Hi, anyone can help me ?
I used esys flashed 6WB (2017 made). I cancelled flash due it take too long (flashing only in UDS mode only, not HTTP). After that i can’t flash again due ESYS can’t see it anymore. Cluster panel all black while plugged in power. Maybe it dead. How to rescue it ? Thanks in advance. (Sorry for my English) |
04-18-2020, 08:00 PM | #226 | |
Rep 6
Me too My car is bmw 2014 320d (Composition: NBT ID6, 6WB) After replacement with 6wb instrument panel, hud flashes and then goes off. Did you solve this problem? |
04-20-2020, 12:23 PM | #228 | |
Rep 42,932
sstyle12.50 |
04-20-2020, 12:44 PM | #230 |
Rep 42,932
ENTRYNAV2 has MOST Bus.
sstyle12.50 |
04-20-2020, 03:34 PM | #232 |
Rep 2,302
04-21-2020, 05:09 AM | #233 |
Rep 99
04-21-2020, 07:24 AM | #234 |
New BMW owner
139
Rep 629
You can always install a MOST cable?
04-21-2020, 08:29 AM | #236 | |
Rep 42,932
I was referring only to yours based on BUS ID3 showing in SVT. What is name of your ENTRYNAV2 HWEL?
04-21-2020, 08:36 AM | #237 |
Rep 99
Here is. Ok, one more question: what I have to do to code after swap my entrynav2 to another one with MOST?
04-21-2020, 08:41 AM | #238 | |
Rep 42,932
00005D0F = "EntryEvoMed ECE 03D0 (USB2 2MICIN CVBS1 ETH OABR1 BT USB1)" In short, to replace Head Unit:
sstyle12.50 |
04-21-2020, 09:03 AM | #239 | |
Rep 99
Looks like not so easy if you did not do that before |
04-21-2020, 09:11 AM | #240 |
Rep 42,932
If you can, find seller that will preload it for your VIN.
04-21-2020, 09:30 AM | #241 |
Rep 99
04-21-2020, 09:34 AM | #242 | |
Rep 42,932
Unit has no NAV GPS function. ID5 vs ID6 should be a coding function.
