01-06-2021, 05:17 PM | #2401 | |
Rep 10
Fantastic idea! Will give that a try |
01-06-2021, 11:17 PM | #2402 | |
Rep 500
If I press the phone button on the steering, the Android screen will launch the BT connection screen for telephony (in Android mode) and the HUD will show the last 10 dials number/name. When receiving call, I just press the thumb wheel to accept. Android screen still stay the same but will pause my music player (Audioamp v3). Once hang up call, it didn't resume the music and have to press the play button on the screen. Both calling and receiving will not jump to OEM menu. * Note sure if this will affect the Android behaviour, in the settings I set the CANBUS to Old_V1.5 (third in the sequence). According to Kri XML Config file, the first is for CCC, second for CIC, third for NBT and fourth for NBT EVO. I also change in Android setting the voice command to do nothing when press so that I can use it for OEM voice command and trigger SIRI when long press. |
Alex201.50 |
01-07-2021, 12:25 AM | #2403 |
Rep 1
Hello guys.
I have a Android 10 navi for my e92 335d CCC. My Problem is after the Update for my device to 2.6.1 my Bluetooth is not connecting. It always says connection timed out. Before the Update it was okey Sry for may bad english |
01-07-2021, 01:20 AM | #2404 |
Rep 556
Our bluetooth module is still very crap ... full of connection problems after an update, and a restriction that prevents any connection other than a tablet or a mobile phone ... Frankly our Chinese friends do not. were not friendly on this occasion and strongly that we find a way to bypass, install a new BT module
In the meantime, the re-injection of the factory_config.xml file worked for me (only once there again it does not work anymore at me too) this restored my bluetooth connection |
01-07-2021, 03:35 AM | #2405 | |
Rep 68
It started working after I did a factory reset. |
01-07-2021, 04:02 AM | #2406 | |
Rep 80
"and write how to upload it" > this is done on your phone to turn on/off wifi hotspot when you turn on/off your car. 1) If you are still on Android 10: - Create 2 tasks: one that turns on WiFi Tether and another that turns off WiFi Tether. - Then create 2 profiles: 1 that when bluetooth connects to your car calls the task WiFi Tether ON and another that when bluetooth disconnects from your car calls WiFi Tether OFF. 2) If you are on Android 11: Tasker is not allowed to control WiFi Tether anymore so you have to use a convoluted method using the AutoInput plugin to simulate key presses on your screen as if you were manually turning on wifi hotspot. Obviously this is quite phone dependent so the screenshots refer to what works for me (Samsung Galaxy S20FE). Once everything is configured though, it works great and the phone barely flashes when turning the car on/off. - Install the AutoInput plugin: https://play.google.com/store/apps/d...mgcd.autoinput - Create a task called Toggle Hotspot which uses AutoInput to turn on your screen, unlock it, opens quick settings, press on the screen where the icon is and then backs out of those screens. - Create a Profile that calls this Toggle Hotspot task when bluetooth is disconnected |
01-07-2021, 05:15 AM | #2407 |
Rep 1
After updating the version to 2.6.1, I can no longer connect to Speedplay.
From Japan
After updating the version to 2.6.1, I can no longer connect to Speedplay. The version of Speedplay is now 1.5.8, but Apple CarPlay can't be used wirelessly or wired because it can't be connected. I am asked for an activation code. |
01-07-2021, 05:27 AM | #2408 | |
Rep 68
How can I add a task to enable mobile data? Now the router turns on but without the internet from the phone. |
01-07-2021, 07:10 AM | #2409 |
Rep 80
01-07-2021, 07:30 AM | #2410 |
Rep 5
Help with " no signal "
This forum is very good, I already read more than half of the 100 pages.
I need your help, I think I have a problem. After connecting my new screen I receive a NO SIGNAL message from the car unit, the rest works perfect. I already checked all the connections and they are fine, if I install the original screen in parallel, it works perfect .Android unit : Mode 1025-04 13 17Y NBT 720P // 1 SER ES NBT 8953 4+64 H MCU Ver:023055dGS-NBT-GTH-DC-201107 APP Ver: Ksw-Q-Userdebug_OS_v2.3.5 Sys Ver: 10-8953EA-1 Flash: 48.92GB/64GB RAM: 4GB My car is a 2018 M140 F20 with: Harman Model: NBT EVO HU BMW 6512 CI 8 794 114 01 Original display: BMW LK CID 8.8 BMW Part BM 9387547 02 The vendor (Wondefoo) tells me to change the type of screen in factory settings, I already did this by trying all the options and it does not work. I suspect the problem is that my car is EVO and the Android unit is NBT, does this have any solution other than changing the unit? (I live in Argentina and it is not easy to buy something in China, when entering you pay a lot of tax) I tried various solutions via bimmercode changing screen parameters and also from the factory settings of the Android unit trying all the screen options, nothing worked. Excuse my poor English. Thanks a lot. |
01-07-2021, 09:14 AM | #2411 |
Rep 68
ok. it works.
Mobile data + router has been successfully launched. Normally mobile data cannot be added to task because they are blocked by tasker. You need to connect the phone to the computer and enter the command via "cmd" Code:
adb shell pm grant net.dinglisch.android.taskerm android.permission.WRITE_SECURE_SETTINGS Last edited by Tomasz_pl; 01-07-2021 at 09:40 AM.. |
Mjam136.00 |
01-07-2021, 11:24 AM | #2412 | |
Rep 353
I made such mistake ordered NBT instead of Evo and what I learned about Evo, there are different pins functions even though the LVDS 6-pin cable is the same, also the seller told there is a different mother board in Android HU. |
01-07-2021, 02:34 PM | #2413 | |
Rep 5
Can you recommend me where to buy a HU EVO at aliexpres? ( for my car 2018 M140 F20 - Harman Model: NBT EVO HU BMW 6512 CI 8 794 114 01 Original display: BMW LK CID 8.8 BMW Part BM 9387547 02 ) |
01-07-2021, 03:31 PM | #2414 | |
Rep 5
Aliexpress Sania's store "For BMW EVO host to a normal NBT display LVDS video cable" If with this cable I solve my problem I would be very lucky |
01-07-2021, 04:54 PM | #2415 | ||
Rep 353
I've been working with this seller for a long time. Very good pricing and service. Quote:
01-07-2021, 05:32 PM | #2416 | |
Rep 5
01-08-2021, 04:26 AM | #2417 | |
Rep 17
So when i have incoming call, it does not bring the OEM phone menu, show the caller on HUD only, so its fine till this moment But issues came after i accpepted the call ... during the call OEM phone menu is shown (still ok), but after the call is done (wheel button), the display stay in OEM HU menu, and no sounds from android. Does anybody have a solution for that? p.s. i do not see any difference in CAN settings is in pos 3 or 4, works same on my side btw AppsWhiteList - what is the purpose of that list? May be memory killer will not touch apps from that list? Last edited by Alex20; 01-08-2021 at 04:44 AM.. |
01-08-2021, 05:48 AM | #2418 | |
Rep 80
01-08-2021, 07:54 AM | #2420 |
Rep 58
i have installed the 10.25" atm.
the Android device works but if i want to Show the oem car System it says no Signal. we Check All wires/ connections and seem All fine . maybe anybody can help. i really appericate it. thx |
