06-13-2022, 08:45 AM | #2443 | |
Rep 3,983
If you are however after maximum performance at the cost of higher risk - you can of course run it as is and maybe keep an eye on it to make sure it doesn't get worse with other fuels and temperatures.
06-13-2022, 09:00 AM | #2444 |
Rep 1,181
A higher tune is not necessarily better performance, sometimes it's even worse.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
06-13-2022, 09:10 AM | #2445 | |
Rep 70
I believe mine was at 1-2 on cyl 1 and around 6-8 on the rest of the cylinders. So you want timings on all cyl to be >-2? |
06-13-2022, 09:15 AM | #2446 |
Rep 1,181
No more than -2 timing corrections in ALL cylinders, your current timing corrections are ok but combined with -1 timing delta not great.
06-13-2022, 09:56 AM | #2448 | |
Rep 70
Great thanks! Last edited by BMW335l; 06-13-2022 at 10:04 AM.. |
06-13-2022, 10:27 AM | #2449 |
Rep 185
Guys, I dare to ask my question again..
How is it possible to have a misfire in one cylinder (n°1) and, at the same time, the misfire counter indicates 0 ? Thank you!
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
06-13-2022, 03:40 PM | #2451 |
Rep 70
I have tried stage 2 95 now, and it doesn't look that good.
What do you guys think? What can I do, can this be caused by something else then bad fuel? https://datazap.me/u/bmw335ie92/log-...39-40-41-42-48 https://datazap.me/u/bmw335ie92/log-...38-39-40-41-42 |
06-13-2022, 03:58 PM | #2452 | |
Rep 1,181
No it's the fuel, try Stage 1 95 and 98 tunes.
06-14-2022, 01:22 AM | #2453 |
Rep 70
So the only option right now if I want to run stage 2 is to mix some E85?
How much E85 should I try with stage 2 98 tune? I have the stock HPFP and I want to run a safe amount of E85. Is the fuel system made for up to E20? Last edited by BMW335l; 06-14-2022 at 01:33 AM.. |
06-14-2022, 02:56 AM | #2454 |
Rep 1,181
Just to make it clear your Stage 2 logs are not that bad.
Timing corrections don't make the car slower but low ignition timing does. If you have access to Ethanol and it's not a headache to mix it go for it. You should safely use E30 including the % in the gasoline. For Stage 2 98 you won't need more than E15. If you have access to Ethanol you can run Stage 2 102 on an E25 fuel mix.
06-14-2022, 03:47 AM | #2455 | |
Rep 70
If i understood it correctly. My timing delta for knock adapt should be closer to 0 and my timing corrections should be closer to -2 for all cylinder at all times ideally. But it was not horribly bad when I ran stage 2 98. I will definitely try to mix E85 as I have it close by. Will try stage 2 98 with 15% E85. 98 here is already E5 so I will add another 10% units. Are there any good mixing calculator available? |
06-14-2022, 04:15 AM | #2456 | |
Rep 1,181
Your fuel might be ok but it's the tune that might need higher octane.
Ideally timing delta and corrections should be zero. Personally in my car I never run more than -0.2 timing delta and -1.5 corrections in SOME cylinders. Definitely go for Stage 2 102 on E25 fuel mix. Start by adding 8 liters of E85 and you should be around E20-E25. Many online calculators just google Ethanol Calculator and see which one you like. Quote:
06-15-2022, 02:31 PM | #2457 | |
Rep 70
https://datazap.me/u/bmw335ie92/stage-2-e15-20-0 https://datazap.me/u/bmw335ie92/stag...og=0&data=4-23 |
06-15-2022, 02:56 PM | #2458 | |
Rep 1,181
Looks good you could increase ethanol a little but keep an eye on fuel pressure as it's starting to struggle.
Don't worry about torque limiter it's not affecting anything. Quote:
06-15-2022, 03:57 PM | #2459 | |
Rep 70
Do you believe this setup is safe? Does my rail/fuel pressure look good as is and at what pressure is to low, what should I keep it above to be safe? Will E20 degrade the fuel system? Sorry for a bunch of questions, trying to learn the B58. |
06-15-2022, 04:05 PM | #2460 | |
Rep 1,181
It's ok if fuel pressure dips to 2500 psi momentarly but not the entire RPM range.
Yes this setup is safe but unfortunately you won't be able to run stage 2 102. Quote:
06-15-2022, 04:31 PM | #2461 | |
Rep 70
I guess it's the rail pressure mean 1 I should watch. Whats the ideal pressure thought the rev range? |
06-15-2022, 04:45 PM | #2462 |
Rep 1,181
It's the Ethanol that puts pressure on the HPFP and you will need more to run stage 2 102.
Pressure should be around 2900 psi.
06-16-2022, 04:52 AM | #2463 | |
Rep 70
I have the stock air box with the stock filter. Is the stock filter a restriction when running Stage 2? |
06-16-2022, 04:57 AM | #2464 |
Rep 1,181
Stock filter is good.
