03-03-2024, 03:53 PM | #2487 | |||
Rep 30
03-03-2024, 05:54 PM | #2488 | |
Rep 232
Thanks for all the info! Great!
If so, yes, whenever you get a call, you cannot flip over to another app until the call is over, by default! But, you can always go to the app properties and remove the permission to 'display over other apps'. I did test it and it can even do split screen. I did not test to see what happens when you get an incoming call though. Check it out. Last edited by conandrum; 03-03-2024 at 06:29 PM.. |
909914.00 |
03-04-2024, 11:32 PM | #2489 | |
Rep 30
03-05-2024, 09:06 AM | #2490 | ||
Rep 232
Shamanix
About the Q3 battery... Let's say you go on holiday abroad for a couple of weeks and leave the Q3 in the car without switching it off. When you come back, the Q3 will obviously be discharged. When you start the car, will the Q3 start working normally?... ...or will it need to be charged for a few hours, and switched OFF & ON, before it starts working? Look at this review on Amazon: Quote:
03-05-2024, 12:45 PM | #2491 |
Rep 304
No problems with the battery. Turn on constant charging. When the HU is turned on, even with the battery completely drained, the USB-Dac will automatically turn on and work. The instructions have a description of the modes. If this is not done, in a different mode, there may be problems with sound (shutdown) when charging is activated on the USB-Dac.
03-05-2024, 01:48 PM | #2492 | |
Rep 30
I'm gonna go back to using car Bluetooth (Combox) to take calls, at least this way I can still have control of the screen. |
03-06-2024, 02:41 AM | #2493 |
Rep 49
Im on A12 KSW with SD662 12.3" (the typical Mekede/Navifly). Usually I use ID7 Launcher but when using regular KSW Launcher I opened up BT by accident, since then I cannot get rid of the autostart of teh BT app. Very annoying.even closing all apps, then opening 20 or 30 other apps and using system for 30 minutes....after restart BT app again opened up...and again and again..I dont get rid of it..
Did I miss how to resolve this? Anything else I can do? I read something to open BT app from KSW launcher and then just go back from there to main screen of ksw launcher....will this resolve the issue? Anything else i can try ton ight when being back home? THANKS! |
03-06-2024, 03:26 AM | #2494 | |
Rep 49
Being "stuck" in the phone call screen was a major downside for me the whole time....only saw this "solution" by accident just now, because of my post about BT App is auto starting after each bootup and so far I could not get rid of that app autostarting..:-( |
909914.00 |
03-06-2024, 05:45 AM | #2495 | |
Rep 224
Drives: MINI Cooper, 2020 X1
03-06-2024, 06:21 AM | #2496 |
Rep 49
Thanks a million times. I will try this right away! I am happy for everything that saves me from doing factory reset! :-)
03-06-2024, 01:57 PM | #2497 | |
Rep 232
https://f30.bimmerpost.com/forums/sh...postcount=2478 My video & music apps were auto loading just before the HD icon was shown in the upper right tray area. It got resolved by reloading my factory config file. |
03-06-2024, 02:19 PM | #2498 |
Rep 232
Guys, when I press the 'voice command' button on the steering wheel, I get both the car's assistant and the google assistant answering at the same time.
Is it possible to get only one of them? I want google assistant only? |
03-07-2024, 01:54 AM | #2499 |
Rep 49
I resolved this by coding the car. I removed Sa620 from vehicle order/Fahrzeugauftrag of my BMW e60. You might also need to code SVS nicht_aktiv in ECU CAPPL (or whatever ECU is relevant for car assisstant)
conandrum43.00 |
03-07-2024, 01:56 AM | #2500 | |
Rep 49
Then when I did some call via BT, it was gone after next bootup and did not come back yet again :-) |
03-07-2024, 03:10 AM | #2501 |
Rep 2,450
Drives: E63 645Ci
conandrum you still didn't answer what you need my permission for. You showed me a video of some animation that I have nothing to do with, so I'm really confused. I do understand what you are asking me for.
03-07-2024, 03:57 AM | #2502 |
Rep 232
I used your BMW logo animation towards the end of my animation. Maybe you did not recognize it.
03-07-2024, 04:07 AM | #2503 | |
Rep 232
Also, if you are familiar with coding, can you help me with 'RADIO MUTE'? I want to mute CCC audio using a wire (in many cars there is a 'amp mute' pin that can be grounded to mute the audio). Can I mute my CCC (2008) using such a method? I tried to do it by grounding pin#10 (X13812 socket) on the back of the CCC, but nothing happened. https://www.xbimmers.com/forums/show...7#post30955607 Can you check please and tell me if I should connect my mute wire to another device (e.g. the amp)? |
03-07-2024, 04:31 AM | #2504 | ||
Rep 232
I tested today on the road. With navigation running, I switch over to FM on the CCC, but I cannot hear any voice prompts. Come back to AUX and I can hear the prompts. FYI: 'Aux auto switching': Harman 'AUX switching mode': Manual (with Auto it switches to CD or other mode randomly, so I do not use it) |
03-07-2024, 04:39 AM | #2505 | |
Rep 49
I dont know anything these cables. |
03-07-2024, 04:42 AM | #2506 |
Rep 2,450
Drives: E63 645Ci
All files I've ever uploaded to this forum and Discord are free to use by anyone and do not require any permission. I do not benefit from them in any way, shape or form.
03-07-2024, 05:13 AM | #2507 | |
Rep 232
Can you help with my 'radio mute' enquiry? I got ISTA+ installed yesterday, but I cannot find any info showing pin#10 of X13812 and how it works. |
03-07-2024, 05:43 AM | #2508 |
Rep 2,450
Drives: E63 645Ci
I can't, sorry. All I know is that it connects to the ULF/MULF module, but completely omitted in the documentation on how it works.
