09-13-2019, 09:08 PM | #244 |
Rep 28
Hey guys,
Just completed this retrofit on my 2015 M235i, however I am now getting a TPMS fault on my iDrive and dash. I've read the codes through ISTA+ and have 2 fault codes in the DSC module. 480A46 'Tyre Pressure Monitor: gateway or aerial fault D35694 'No message (RDC data package 1, 127.0.2), receiver DSC, transmitter FEM Has anyone ever had this issue? After doing some research I haven't been able to find an exact match. The sensors I bought were brand new and genuine BMW parts so I don't think they're the issue. As my car car has the TPMS integrated into the DSC I just added the sensors to the wheels and then added 2VB to FA and then VO coded DSC, NBT, ICM and KOMBI. |
09-15-2019, 05:07 AM | #246 |
Rep 28
09-23-2019, 01:10 PM | #248 | |
Rep 2,302
10-03-2019, 04:32 AM | #249 |
Rep 8
Hi,
I have retrofited my car with control unit 6876227 and sensor 6856227. All is working But I have a question. Can I use with other control unit on this list below: 36106876227 Control unit RDC From:07/01/2015To:07/26/2016 (ENDED)Weight:0.005 kgPrice: Superseded by: 36106881433(03/01/2016 — ), Exchangeable retrospectively Supersedes: 36106875773(03/01/2015 — 12/17/2015), Exchangeable retrospectively36106872027(11/01/2015 — 12/15/2015), Exchangeable retrospectively36106872026(03/01/2015 — 12/22/2015), Exchangeable retrospectively36106871056(07/01/2014 — 03/02/2016), Exchangeable retrospectively36106869235(07/01/2014 — 08/25/2015), Exchangeable retrospectively36106864952(03/01/2014 — 08/25/2015), Exchangeable retrospectively36106857938(03/01/2012 — 04/08/2014), Exchangeable retrospectively36106853670(09/01/2011 — 06/13/2013), Exchangeable retrospectively36106851214(03/01/2011 — 08/11/2011), Exchangeable retrospectively36106790247(09/01/2010 — 04/06/2011), nonexchangeable retrospectively36106796604(03/01/2010 — ), Exchangeable retrospectively36106790839(03/02/2009 — 03/01/2012), Bilaterally exchangeable36106790980(11/03/2008 — 03/09/2009), Bilaterally exchangeable36106787230(11/03/2008 — 07/31/2008) Part 36106876227 was found on the following vehicles: |
10-03-2019, 05:30 AM | #250 |
Rep 5,801
FYI- I got great advice and pricing on TPMS from *********. My car came with sensors made by VDO with the BMW label on them. Was able to buy VDO from them at a fraction of dealer price.
10-03-2019, 08:39 AM | #251 | |
Rep 2,302
I deleted all part numbers from your quote which i didn't found in the parts catalog or which aren't exchangeable. Additionally i found the part number 36106881474. |
10-12-2019, 05:48 AM | #252 | |
Rep 21
I hate to beat on a dead horse but am I right to assume the connections described here for the RDC connectivity to FEM are for an F30 with NBT? |
10-12-2019, 11:50 AM | #253 | |
Rep 2,302
I think it should work with all headunits and the wiring is all the same. |
11-12-2019, 08:52 AM | #254 |
Rep 72
Coded by FDL (https://f30.bimmerpost.com/forums/sh...4&postcount=19), but still get errors: "tyre pressure monitor failure", also I has a errors: D018E8 (Message (RDC Tyre status. 280.0.8) missing, receiver ICM, transmiter RDC) and E114A0 (No message (status, tyre RDC 0x368) receiver KOMBI transmitter RDC). How to fix this?
11-12-2019, 10:48 AM | #255 | |
Rep 2,302
Did you choose the right part numbers? |
11-12-2019, 11:41 AM | #256 |
Rep 72
11-12-2019, 03:20 PM | #257 | |
Rep 2,302
And is it an EU model? It is still not clear if it works so easily that you just retrofit the sensors on newer models. All those who have tried so far, have not reported then whether it works or not. |
11-13-2019, 01:19 AM | #258 |
Rep 72
ok, guys, now it works well. I added 2VB to FA and code only DSC today, then compared NCD files (result and backuped) and found that one parameter (C_Funktion_RDCi_l) missed in this thread:
Correct coding list: HU_NBT > 3001 > RDC > activ HU_NBT > 3001 RDC_SAFETY > nicht_aktiv (active is not needed, and FA code this parameter as nicht_activ) HU_NBT > 3001 RPA > nicht_aktiv HU_NBT > 3001 RDC_FORTSCHRITTSANZEIGE > activ HU_NBT > 3001 REIFENUEBERWACHUNG_RDC_RPA > rdc (02) HU_NBT > 3001 RDC_DRUCK_TEMP > druck druck_und_temperatur (02) FEM > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv ICM > Daten 3000 > IcmKod_B_S2VBA = verbaut DSC > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv DSC > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv DSC > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = aktiv - missed parameter KOMBI > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv KOMBI > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv KOMBI > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA (02) BTW, I bought cheap sensors from Aliexpress - https://aliexpress.com/item/32975907426.html and they works! Last edited by sitetech; 11-13-2019 at 01:47 AM.. |
11-17-2019, 10:12 AM | #259 |
Rep 18
I have a 2015/07 330d and I have orderd the 4 sensors for the wheels. I HAVE E-sys. Just one thing, How will the car know the position of the sensor? Is there more coding required?
11-17-2019, 11:22 AM | #260 | |
Rep 2,302
The position of the sensors is calculated by the car about the distance and the rotation. The left wheel turns the other way from the sensor's point of view and the sensors in the front wheels are farther from the controller than the sensors in the rear wheels. |
11-17-2019, 01:59 PM | #261 |
Rep 18
Thanks for the reply. I dont think I require a module reading through the post for my car is a 7/2015 build and dont see an module on realoem under the VIN so I assume its integrated.
11-24-2019, 01:43 PM | #262 |
Rep 127
Hello experts,
I have been trying to disable the tpms malfunction on my 2012 f30. I have purchased BimmerCode and wanted to know how i can disable this warning alert that pops up every few seconds. Can this be done without disconnecting any wiring? If yes, please advise on how I can use the expert mode. Thank you, looking forward to fixing this problem Jo |
12-02-2019, 01:00 PM | #264 |
Rep 127
Update:
After enabling the Pressure and Temperature using BImmercode, the TPMS malfunction alerts went away! I have to reset the sensors from the i-drive after coding this feature.
2012 335i | silver | Sport | Premium | DHP | Lane Departure | Nav
