03-04-2020, 11:39 AM | #2773 | |
Rep 20
03-04-2020, 11:47 AM | #2774 | |
Rep 86
BTW: do you have a MCU file? I have the same device with an older MCU |
03-04-2020, 12:20 PM | #2775 |
Rep 571
03-04-2020, 01:56 PM | #2776 |
Rep 20
03-04-2020, 03:13 PM | #2777 |
Rep 1,420
Drives: 13' F30 328i 6MT
It means you can navigate the head unit in all sections via idrive in your center console. ( Google Maps / App Store / Chrome / etc etc ) "System Wide".
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
03-04-2020, 03:42 PM | #2778 |
Rep 6
03-05-2020, 01:09 AM | #2779 |
Rep 20
Hi,
I put the file on my usb key without decompressing it then plugged into the device but nothing happens, the device starts normally, I do something wrong, why the update does not start? thank |
03-05-2020, 02:58 AM | #2780 | |
Rep 1,049
No, Touch is not supported, only normal non touch idrive movements.
Your thumbdrive is found at ES explorer and accessible ? the File has not "double ending" , like ".zip.zip" ? If it still does not work, try a different USB thumbdrive (below 32GB size), some sticks master boot records are not supported. Kri |
03-05-2020, 05:08 AM | #2781 |
Rep 51
Does someone also have the problem in V3.8.3 which max media volume level?
Maxing out the volume through the knob or steering wheel buttons only goes to a fix point. (Not the loudest but ~"ok") To make it louder i have to open the Options and set the Media Volume by hand to example 30 and than it can go up to that volume level. Even whith the knob and steering wheel. After a restart it is the same problem. Strangest part about the bug is, it still shows the (for example) 30 in the volume settings, but i have to reset it to that to make it louder again. |
03-05-2020, 09:39 AM | #2782 | |
Rep 80
PS C:\android\platform-tools> .\adb connect 192.168.43.174:5555 connected to 192.168.43.174:5555 PS C:\android\platform-tools> .\adb root adbd is already running as root PS C:\android\platform-tools> .\adb connect 192.168.43.174:5555 already connected to 192.168.43.174:5555 PS C:\android\platform-tools> .\adb remount remount of the / superblock failed: Permission denied remount failed PS C:\android\platform-tools> .\adb shell mv /data/app/com.google.android.googlequicksearchbox* /system/priv-app/ mv: /system/priv-app//com.google.android.googlequicksearchbox-MYbNIQYz_fZiqySfAbLdlQ==: Read-only file system Any ideas? Also, would be great if the Voice button on the steering wheel would bring up bring up Google Voice. Right now it still brings up the BMW voice assistant which is in German for me (my car is imported from Germany). Is this something that could be done with Tasker? Kri's tasker project for GMaps works great ! |
03-05-2020, 09:59 AM | #2784 |
Rep 80
03-05-2020, 10:14 AM | #2785 |
Rep 12
03-05-2020, 11:21 AM | #2786 | |
Rep 20
I tried to install the application CF.lumen version 3.72 by following the tutorial of the 1st page but impossible to go to daytime / sundown the choice is grayed out an idea ? |
03-05-2020, 11:27 AM | #2787 | |
Rep 1,049
Kri |
03-06-2020, 12:06 AM | #2788 | |
Rep 20
something else since update 3.8.5 the maximum volume is very low, is there a place to fix this? Thank you again for your help |
03-06-2020, 01:57 AM | #2790 |
Rep 1,049
03-06-2020, 03:19 AM | #2791 | |
Rep 51
Check if its behaving the same |
03-06-2020, 03:20 AM | #2792 | |
Rep 556
I tried this method on a ROCKCHIP PX6 = failure Because in our OEM folder, accessible by ESEXPLORER, there are only the original APK files and the files: cartype.xml, filterlist.txt and mapApkLst.txt (still no factory.xml) Do you have an idea to change the animated ANDROID logo after the still image (connected drive in my case) please ? : confused2 |
03-06-2020, 04:42 AM | #2793 | |
Rep 1,049
Kri |
03-06-2020, 05:29 AM | #2794 |
Rep 30
I have two questions.
1.Is it possible to launch Spotify on Android startup? I'm currently playing music and I don't like it. 2. Can I connect the Huawei E3772 USB modem in the PX6 unit and have internet from it? Just plug it in or need to install any programs and drivers? |
