03-01-2020, 06:09 AM | #265 |
Rep 4
Hello
Not sure if it is NBT or ID4 version on my 118d. VIN : 5A81096 Map : ROAD MAP EUROPE WEST ROUTE 2020-1 I tryied FSC codes generated for NBT and ID4 without success. Now car asking for code with already installed map... Could somebody help me with this issue ? |
03-01-2020, 09:14 AM | #266 | |
Rep 42,932
03-01-2020, 02:24 PM | #267 |
Rep 4
03-01-2020, 02:26 PM | #268 |
Rep 42,932
Need to enter current FSC Code.
03-08-2020, 08:33 PM | #269 |
Rep 1
Code nav
Ciao amico non riesco a generare il codice attivazione per aggiornare la mappa del mio navigatore cic nella versione premium/Europe west 2020 -1 . Chi mi può aiutare ? Vin A761245
03-10-2020, 01:54 PM | #270 |
Rep 1
Help needed
Hello,
I tried to generate a code with the generator, (using Mac OS version). But it doesn't let me enter any date even with a valid VIN (date field is not greyed out anymore after entering the VIN, but can't type / select anything). I downloaded BMW Europe West Next 2020-1 but nothing happens when I put the USB stick in the car? is this the right map for my car (see picture below). Have they split the map between West/East or is it still possible to download the whole Europe (as I have on my car?). Can someone help me with the code / tell me how to get the correct map for my car? do I need CIC or NBT? VIN: A269375 Prod Date: 2012-10-30 BMW 328i M-Sport Touring |
03-10-2020, 03:26 PM | #271 |
Rep 6
Question
Hello how can't make extraction from e-sys (i am new with this program) to my car f31 f654424 for one fsc lifetime
Y have try until now 4 code and now my navi is asking me every time for code when I start auto. I have attached down below my last maps. This have somebody for me worked. Road Map Europe next 2018-2 Thanks in advance. |
03-11-2020, 10:50 AM | #272 |
Rep 25
Same problem with Windows version. Even while using compatibility launch option.
03-11-2020, 02:06 PM | #273 |
Rep 3
Incorrect RSA Key Header/Footer - File Likely Corrupted
Hi Jaeger,
thank you for the great tool, was surprised to see Linux version as well (made my day) Im having some issues with my F02, trying to update to 2020-1 Europe east, however when I try to open my 1b file I get: Incorrect RSA Key Header/Footer - File Likely Corrupted No luck in manual repair, I tried pulling generalPersistencyData_DiagnosticSWTController file via ENET and manually extracting 319bytes with no luck either. I have attached the file. VIN number is CY50456. Current version of map is: ECE BMW 1.2.4 Road Map Europe PREMIUM 2008-2 Was also thinking perhaps old module versions so took the car today into independent dealer who updated ALL car modules to latest versions via Autohex2. Hopefully you could see something I don't. |
03-11-2020, 02:38 PM | #274 | |
Rep 2,302
03-13-2020, 03:08 PM | #275 | |
Rep 3
Updated 1b manually but incorrect code
I have also managed to manually create this file with my vin and correct timestamp, got the key generated for 2020-1 Europe East but it complains about incorrect fsc code. Getting out of ideas. Will try downloading 2020-2 just in case somehow wrong files, but if that doesnt work no more ideas.
You can see it attached as try3.pdf Quote:
03-13-2020, 04:39 PM | #276 |
Rep 3
Hi,
Feel like Im facing the same issue, might be wrong. Did you had any luck with this step by step upgrade of various versions? Thanks in advance. |
03-14-2020, 02:50 PM | #277 | |
Rep 6
03-17-2020, 11:35 AM | #279 |
Rep 2
03-18-2020, 03:59 AM | #281 |
Rep 25
03-26-2020, 05:28 PM | #282 |
Rep 21
Drives: F20 116i
Just came here to thank for the FSC calc, simple and effective, great tool.
An advice for those that will update for the first time like me: -I've inserted the flash drive with the map before turning on the ignition. -It can take a few seconds to start, like 20 seconds after boot. I used a 64GB flash drive, FAT32. cheers.
03-30-2020, 10:06 PM | #286 |
Rep 6
Thanks Jagaer !
Is the only way to pull the DE file on an NBT using an Enet / Esys? I found the method to extract the 1b file for CIC but haven't come across the equivalent for NBT yet. Can anyone confirm? |
