04-11-2020, 08:04 AM | #265 | ||
Rep 1,049
Thats why i said that i don`t know if it will be activated (does work at all). I only checked the source of centerservice, there is a "EL" folder which contains greek translation. You have edited your file and using magisk, or without ? Kri |
04-11-2020, 08:42 AM | #266 | |
Rep 86
in your factory_config.xml remove the line Code:
<Item name = "com.google.android.apps.maps" /> The device is supposed to mix the navigation audio with the OEM audio while listening to OEM Radio. For some reason it is also mixing the sound when you listen to Android Music (Spotify) sometimes. Removing that line will disable that feature for this app. So you will hear the navigation sounds like every other sound on Android |
Kri1080.50 |
04-11-2020, 12:20 PM | #267 |
Rep 224
Drives: MINI Cooper, 2020 X1
On Android 8 I used Magisk, riru-core, EdXposed-YAHFA and EdXposedInstaller, now on Android 10 Magisk, riru-core, EdXposed-YAHFA and EdXposedManager.
04-12-2020, 09:18 AM | #268 |
Rep 606
Hi Guys,
after being idle on this forum for quite a while I think I am going to replace my PX3 7.1 unit to a 625 android 10 unit. My older unit has some issues that I learned to live with but, since we drive BMW here, it feels like having an Lada component in a luxury car... Especially since things have progressed and more is possible but my unit is to slow for that im afraid... I have read 50 pages on the android 9 topic and this topic completely and the guys I got my current unit from (Ugode) are apparently not really active anymore. I previously had an AVIN unit so im aware of their aftersales (aka non at all). Which supplier (ali seller) is currently the most active in supplying updates? Is that navifly, Mekede or Andream? Is it true that the hardware of the later android 9 systems is identical to the android 10 units? it seems the android 9 units are somewhat cheaper but if that's only the software... |
04-12-2020, 10:51 AM | #269 | |
Rep 13
However I brought my unit from Mekede who seem to be one of the original manufacturers. There support is a tad slow but they still reply quite decently. I probably would’ve gone for a Navifly unit now I think of it, but MEKEDE were very good with me and keeping track of my delivery. Guys, sorry for all the questions but I have one more haha! I have to plug my AUX into my AUX by arm rest to get noise, does anyone have an idea how I can hide the cable? One more thing, I have a Carlinkit dongle for Apple car play, however I think like a lot of other people, the dongle does not charge the phone because of a low power from headunit. It uses more battery than it charges the phone. Does anyone have workaround to make sure I can charge my phone from cigarette lighter and also send data to the Carlinkit dongle? |
04-12-2020, 11:03 AM | #270 | |
Rep 606
for your other question, perhaps a powered USB hub could solve the power issue? Regarding Navifly and Mekede, I see in the add from Navifly that they actually mention the Mekede certificates of manufacture (not that I really read nor trust the certificates for CE, ISO etc...). I think I will go with Navifly then. the seem to sell the most as well. |
MrChang36.00 |
04-12-2020, 09:47 PM | #271 |
Rep 3
Hi everyone.
I just installed a new Avin 10.25 screen in my 2016 X1. The installation was a real pia. The factory HU barely pulls out enough to change the harness. It took me all day to figure out a way to pull it out enough and then I had to ask my wife to plug the new harness in since she has tiny hands. Anyways, it works now, but imo the trouble to install this thing is way underestimated for a 2016 X1. The original HU does not come out like in any of the install videos I watched. It actually does not come out at all! FYI So I bought: (North America) | Android 10 With 4GB RAM | 4G SIM Card Support | Qualcomm Snapdragon | Black Trim Bezel Also got the GPS splitter and the newest little black box for wireless carplay/android auto as I was potentially planing to use AA with it. My 2016 X1 is fully loaded. So I am coming from an 8.8 screen with NAV. I really just wanted Waze and Tidal and the ability to use my Plex server on my long trips back to my hometown. So I figured when I'm not going on long trips, I would use AA. I tested Plex and it does work on the Android side. Haven't done any type of long term testing. Really just got it up and running, installed AA and Waze and Plex on the Android side. I was however, quite disappointed with the resolution of AA. Is there a way to not have it stretched out for the whole 10.25''? Can I split screen it some how? Or change the resolution in a way. Maybe make the icons smaller? Adding more rows or something? What do you guys use the most? AA or simply stay on the Androiud side for Waze and Spotify? If you do stay on the Android side, am I correct to assume that I always have to hotspot from my phone? Don't want to get another sim card for my car. Unless that is the way to go? Also, is there a way to keep spotify or tidal going when I switch to the OEM side? Which Bluetooth settings do you guys have running? On OEM side VS Android. Alot to configure it seems. I also don't have the autoplay working right. I have to go in the apps section, select autoplay, then plug my phone in. I think I read somewhere that this can be changed though. |
04-13-2020, 04:51 AM | #272 |
Rep 38
Upgrade Android 10.0
Hello Kri,
I am very happy that you are in this group, you helped me in the other thread. I updated my system to Android 10 and my device is working very fine. Only i have a problem with CarPlay (Carlinkit), when i am stopped in my car all right but when my engine is on, i have a noise in the mic. I need connect bt Android and change it in iPhone settings. Maybe someone has this same problem. Thanks, |
04-13-2020, 08:41 AM | #273 | |
Rep 80
Anyway, unit works fine apart from that. |
04-13-2020, 08:42 AM | #274 | |
Rep 80
LTE might not support all the bands but it works fine. I have a good connection, music streaming works, etc. |
04-14-2020, 03:20 AM | #276 |
Rep 3
no connection to E60 CCC
Hello friends,
I have a problem. I have BMW E60 and bought Android Radio CCC through NaviFly. I made updates several times and installed different MCU versions on it. Unfortunately I have no connection to my car, steering wheel and menu button and the wheel does not work. I have already measured the cables there are no problems, I also got no success from the seller. Then I tried the radio on my friend's BMW E60, but it was not a success either. what do you think it could be? Last edited by zehirlioglu; 04-14-2020 at 03:40 AM.. |
04-14-2020, 04:53 AM | #277 |
Rep 41
I tried the OEM antenna first, which was delivered with the DAB adapter and it was terrible. My F20 didn’t, have a native DAB. So I decided to buy a diversity with DAB. It’s placed in the middle above the pane of the trunklid, pretty easy to reach. New it would cost about 140 Euros I got it on eBay for 25. Then I ran a cable from the trunk to the glove box where I have my DAB adapter and the USB plugs and the reception is much better. Not perfect but pretty good.
04-14-2020, 05:35 AM | #278 | |
Rep 13
I'm using a CarPlay dongle for one and a DAB+ box that came from the same seller. Currently having issues of power with the CarPlay dongle that essentially isn't giving enough juice to the phone to charge it properly. Have you got a work around by any chance? |
04-14-2020, 07:14 AM | #280 | |
Rep 11
04-14-2020, 11:16 PM | #282 | |
Rep 142
The only problem is that HeadUnit Reloaded is not free, but it does have a trial app you can download to try it out. The app costs only a few bucks anyway. |
04-15-2020, 02:38 AM | #284 | |
Rep 29
04-15-2020, 02:53 AM | #285 | |
Rep 80
OEM, the mic is much better imho. |
04-15-2020, 04:14 AM | #286 |
Rep 86
