03-22-2020, 02:55 PM | #2863 | |
Rep 43
Tried with the update, is the same version not an improvment Can somebody help me with an updated version of this mcu? 01204bJLY-NBT-HW7-190628(B1290_170325) ON github.. Is lower than my version.. And i can t downgrade it.. I think so https://we.tl/t-3ZXN5yP0Fp?src=dnl Video with sygic when it crash and it gives me "no signal" |
03-29-2020, 10:27 AM | #2865 |
Rep 2
04-01-2020, 12:00 AM | #2867 | |
Rep 1,049
First it was only necessary on newer car`s who had no low-level output anymore (newer F series), but since some time it will be delivered with nearly every new unit. Maybe to also solve the "navigation voice too loud" issue on some cars. Kri |
04-01-2020, 05:57 AM | #2868 | |
Rep 2
Thanks a lot. I have a 2013 f20, so I understand that if I don't install the speaker, I can't hear the navigation, but will the rest work perfectly? |
04-01-2020, 06:45 AM | #2869 |
Rep 1,049
04-06-2020, 02:51 PM | #2871 |
Rep 1,049
I can`t see your pictures at the older threads, they are deleted already, also the download. On which OS version is your system running at the moment ? Best is always to update and perform a factory reset to have a clean system again. Your sellers vendor "JLY" is not very common, you have to ask your seller if he has a update. Kri |
04-07-2020, 02:50 AM | #2872 | |
Rep 32
Are you saying that the BMW antenna is supplying a higher voltage than the Android unit can handle? In which case I guess there is a way to limit that voltage by putting something on the Android leg. But haven't people also connected the BMW antenna directly without any problems? Any electronic engineers here? |
04-09-2020, 05:18 AM | #2873 | |
Rep 43
04-09-2020, 05:28 AM | #2874 | |
Rep 1,049
best is to use the upload function of this forum to see it permanently. Kri |
04-09-2020, 06:00 AM | #2875 | |
Rep 43
Here you have a video: https://we.tl/t-YCbJfRHRLi https://we.tl/t-YCbJfRHRLi Last edited by b777rky; 04-09-2020 at 06:15 AM.. Reason: Added photos |
04-26-2020, 03:28 AM | #2877 | |
Rep 34
_____ Buenas, pudiste solucionar el problema? a mí me pasaba lo mismo hasta que probé con varias configuraciones en las opciones de fábrica. Del MCU tienes enlace de descarga? |
04-26-2020, 10:40 AM | #2878 |
Rep 1
Translate PX6
Hello everyone,
I'm newbee on f30 bimmerpost, but in reality I often read these forums ! I have a PX6 rk3399 10.25" on Android 8.1. I'm looking for updates for this device, I dream of a basic AOSP version, so I read your messages frequently! But I understood, over time, that I could never put Android 9 or Android 10, too bad I would have liked to activate the dark mode! My problem is not there, I activate the dark mode in all apps, they offer it more and more often, and I think that for use in the car it's better! My problem, you will probably have noticed, is that I am not an English speaker, and that these devices are very badly translated (in English too, but less) so I would simply like to translate Launcher3 applications and a few others (naviSettings, ...) I tried, with URTool (on chinesebmwheadunits github), I can extract the applications, I can decompile them (with APKStudio 5.2.3). After that, I can edit translation errors, with APKStudio, Notepad++ or Android Studio and Translation Editor ... But afterwards, impossible to recompile? or sign the application? it seems to work with APKStudio and Uber Sign, but the application no longer works, no longer installs, and has a reduced size (more than half!) Do you know a method of translating an application that does not belong to us? These applications, used by all these Chinese resellers should not be very secure? Yes ? I also tried to replace the modified ressources.arsc file in the original application, with 7z, but the result is identical, it no longer works! Do you have a solution? Thank you ! |
04-26-2020, 02:08 PM | #2879 | |
Rep 1,049
Kri |
04-29-2020, 12:46 PM | #2880 |
Rep 1
Hey. I want to introduce myself, I Sergey, I live in Spain. The exchange has a small problem, it is necessary to update the MCU, but could not find it on my model. If anyone can help, I will be very grateful. Mod: Android 9, MCU Ver: 415187dLZH-CIC-GTL-190716-B18. Thank you.
05-25-2020, 02:52 PM | #2881 |
Rep 1
Good afternoon from Athens , Greece
Another one dissatisfied owner of a Chinese BMW Android Unit (7.1 - px3) which the screen stopped responding in android mode... ( No signal or flickering issue ) Τhe unit is out of warranty and Chinese seller can't really help me... He just offered me a laconic way to buy a new coreboard !!! Is really the correct solution to solve this problem ??? |
