03-06-2013, 09:49 PM | #2883 |
Rep 41,229
03-06-2013, 11:29 PM | #2884 |
Rep 407
esys 3.18.4 and psdzdata 48.3. I need to check about the i-level but I suppose it is the latest one because the dealer just updated the car this week. I was able to code the car before.
03-07-2013, 12:07 AM | #2885 |
Rep 41,229
You need to update. PM sent.
03-07-2013, 12:07 AM | #2886 | |
Rep 1,892
Mine is a 2012, they may update 2013's to F020-12-11-505 which will require 2.48.3. The only way to tell what version you have is to connect to it with E-Sys. Here's how (courtesy of Shawn): http://www.f30post.com/forums/showpo...postcount=1403 I suggest PM'ing Shawn for links. |
03-07-2013, 12:25 AM | #2887 | |
Rep 41,229
03-07-2013, 01:27 AM | #2888 |
Rep 490
Booked my car in next Sat, and the SA already told me I'm going to get the March 2013 update which they are in the midst of installing... probably the v49 for me?
F020-13-03-501 |
03-07-2013, 05:54 AM | #2889 |
Rep 84
03-07-2013, 08:59 PM | #2890 |
Rep 52
Hi, I am the owner of f30 who is interested to change default hvac behavior. Currently my car remembers last temperature setting but not the on/off state. Every time when I start the engine, hvac turns on even though I left it off last time before I turned the engine off. I was wondering if there is a way to make computer remembers a last hvac on/off setting.
Thank you. |
03-07-2013, 09:19 PM | #2891 | |
Rep 490
03-08-2013, 01:08 AM | #2893 | |
Rep 490
But if my dealer going to tell me the warranty is void because I switch off my aircon, I'm pretty sure a hammer or spanner will be up their arse |
03-08-2013, 11:05 AM | #2895 |
Rep 18
Hi guys i'm trying to code something and everything is ok except when I click "code". It reports me this message:
What should I do?? It give me the same errors trying to code anything so I don't think it depends on what I'm trying to code... |
03-08-2013, 09:05 PM | #2897 |
Rep 10
I have E-Sys-3.22.5 with the personalized token. I downloaded PSdZData-48.3 and do not find data for F30. Which version of PSdZData covers the F30? Please send a link. TIA
03-08-2013, 09:39 PM | #2898 |
Rep 1
Wow u guys are indeed knowledgeable abt the coding for the BMW usage systems. Am expecting my new 316i to drop and would also like to find out more of what can be customised esp the ASS and the aircon as most people do. Any local boys (SG) can help? Thx a bunch
03-08-2013, 10:25 PM | #2899 |
Rep 1,892
03-09-2013, 09:47 AM | #2900 | |
Rep 41,229
Were you FDL Coding or VO Coding? If FDL Coding, is your EST Token installed in E-Sys? Lastly, try setting your Windows Regional and Language options to English U.S.
03-09-2013, 09:50 AM | #2901 |
Rep 41,229
If you add the hardware, the you should be able to just add S322A Comfort Access to your VO and VO Code CAS module.
03-09-2013, 12:05 PM | #2902 | |
Rep 18
I think I pressed the "code" button instead of "code fdl" I'm not sure... Anyway EST is installed.... What's the difference between coding FDL or VO? I see two buttons: CODE and CODE FDL. Is the non FDL just the VO option? I'll retry being sure to hit code fdl. And will try also to change the region option of windows! Many thanks! |
03-09-2013, 12:09 PM | #2903 |
Rep 41,229
You can not use E-Sys 3.18.4 and F20 48.3 PSdZdata with Code Away.EST. This has been discussed ad nauseam. If you want to use 48.3, you must get a new Patch / Token, which means you might as well update to E-Sys 3.22.5 at the same time.
03-09-2013, 12:16 PM | #2904 | |
Rep 18
Anyway I have version 3.22.5 too. What should I do? Install this version using the same PSdZData? Or do I have to get this new Patch/Token?And what's exactly this?Where Can I find it? Or sould i get other PSdZData? Where to find? Again sorry for all the questions |
