02-10-2021, 11:29 AM | #2905 |
Rep 3
Might as well try my luck here as I have 0 technical background with these units.
I have a resolution problem on my unit. Within the Idrive menu the resolution of background images is not ok + letters appear to be purple. Android menu is fine. I have tried to enter factory settings and adjust Car Type but with no luck (I have tried them all). Is there any other thing I have to adjust. Thanks ! Last edited by Syne; 02-10-2021 at 11:42 AM.. |
02-13-2021, 04:39 PM | #2906 |
Rep 95
Guys need your suggestion. My car comes from factory without OEM monitor head unit. I installed AVIN android unit, I also ordered and installed iDrive controller form AVIN. Problem is that, iDrive controller very poor quality, also it doesn’t have main button tilting features it only rolling.
I’m wandering can I use OEM iDrive controller instead of that AVIN trash? I tried to understand how to connect it, because AVIN iDrive controller have 5 pin socket. BMW OEM iDrive controller have 4 pin socket. Does anyone tried and use OEM iDrive on AVIN head units? Regards |
03-28-2021, 11:16 AM | #2907 |
Rep 6
BMW Headunit - Use Tasker Easy
Dear together,
I have a CCC Android 8.1 Unit with an USB DAC attached (Meizu Hifi). My problem was that the volume was always set to about 25% after reboot (not sure if it's a behaviour of the DAC or the headunit). I'm not rooted. Tasker was not working because it was not starting together with Android. I installed an app from XDA. (https://forum.xda-developers.com/t/s...4102439/page-3). I changed the source code to start already 1s after the USB intent was recognized (which is triggered by the attached USB-C DAC). It's working nicely. I would post the changed app but I'm not sure if this is allowed by the developer. In tasker I change the volume by "Monitor Start" of tasker itself. Anyway another problem is that the Bluetooth call is always using the orignal AUX output of the headunit. I use a Y Splitter cable. It doesn't affect my sound output quality as far as I can say (or not noticeable) of the DAC but it clearly affects the output of the unit in case I use it for a bluetooth call. I ordered another USB-C DAC...maybe this one reacts different. I think the DAC has a really low impendance which is maybe a little bit hard for the headunit...Maybe I will also play a little bit with some resistors. If somebody is interested I can report. So far it's working good and the sound quality noticeable improved. |
03-29-2021, 04:44 AM | #2908 | |
Rep 190
If you have the knowledge to make the idrive knob to work with all the system and not only the native apps it would be great !! That is the only issue with our units !!! |
05-15-2021, 06:45 PM | #2909 |
Rep 2
Hi everyone
Guys did buy HU like a week ago, everything was working fine, but 2 days earlier i have lost option on my main screen "Car device" wich send me to original bmw settings, now i have Settings up there, and cant find anything to let me go to original CCC settings. Factory reset isnt doing anything. :/ |
05-22-2021, 03:52 PM | #2910 | |
Rep 1
MCU
11-10-2021, 07:00 AM | #2911 |
Rep 5
12-29-2021, 02:40 AM | #2912 |
Rep 1
Hi, I recently bought my first BMW, i.e. E87. I have purchased a GPS navigation on android for it. I have some problem. After buying the device to check if it works, I connected it to the BMW radio. At first the screen was flickering, but then it worked. So I started installing it in the car. After installing all the components, I connected the GPS device, but again, the screen started to flicker (picture 1). I've unplugged and replugged the cables several times, and finally the screen lights up and android does not start at all. Interestingly, when I put the car in reverse, the screen switches to the reversing camera properly. Has anyone of you encountered this problem?
01-14-2022, 02:15 AM | #2913 |
Rep 36
01-14-2022, 02:18 AM | #2914 | |
Rep 36
I have been able to revert to an older version but the GPS seems not working again. I'm looking for a differet factory.xml file because it changed and now also password has changed. |
01-26-2022, 11:05 AM | #2916 |
Rep 36
Is there a kind anyone that could help me or teach me how to do some little grammar corrections to the Italian language? I include in this message a small pdf with some of the edits I would like to do on my px3 image.
I don't know if it's possible but I wuold be glad to learn how to do. Thank you all in advance. |
01-28-2022, 05:03 AM | #2917 | |
Rep 36
01-28-2022, 09:21 AM | #2918 |
Rep 1,049
Unfortunately thats a very outdated system, which is before my "Android Headunit" time.
Someone would reverse engineer the image, gather the launcher app , check if the system is rootable and Root it. Then create a new specific KswOverlay for this head unit typ and test it. That requires a Headunit at the desk alot of work and not just done in an hour, for me i unfortunately don't have the time to do this Kri Last edited by Kri; 01-28-2022 at 02:46 PM.. |
StevenRed1.00 |
01-28-2022, 02:42 PM | #2919 | |
Rep 36
01-28-2022, 03:23 PM | #2920 |
Rep 36
Sorry for the delay in answering, here's the link for the download: https://drive.google.com/file/d/1dNg...ew?usp=sharing
02-17-2022, 10:53 AM | #2921 | |
Rep 1
Or maybe someone else has an answer to it. |
04-15-2022, 12:15 AM | #2923 | |
Rep 5
06-13-2022, 01:24 PM | #2924 |
Rep 6
Hi , any idea how to relatively safely root my HU PX3 7.1.1 ?
I have an app that I use for android auto ( headunit reloaded ) but the system doesn't save the option to open the app when I plug usb cable. LE. I updatated the android with the rooted image from the wiki but the annying message regaring the app acees to usb still allways popup Last edited by arisgigi; 06-17-2022 at 01:59 AM.. |
07-11-2022, 01:07 PM | #2925 | |
Rep 38
I have the same problem, look at the previous page of this thread, but never found a solution. Did you? |
08-10-2022, 08:26 AM | #2926 |
Rep 3
Android 8
This old navigation has an overheating problem and only worked well with Android Auto. Unfortunately that stopped working on Android 7. Is there a way to upgrade this to Android 8?
Thanks, L |
