03-23-2020, 03:26 AM | #287 |
Rep 124
Drives: BMW316da Touring 2014
Location: Ypres, West-Vlaanderen (near the tranches of WWI)
When I connected my Veepeak BLE dongle to the car and started the Bimmercode app, it reads all the ECU information.
Now after I went into the option "Electronic Transmission Control" there is the option "Sport Automatic Transmission" and this was Not Active. So my guess was this gear was not coded yet as to be in Sport. I changed it to active and coded the ECU. Then I changed it back to Not Active and coded the ECU drove the car, changed it back to Active and drove again and I noticed a little difference in Comfort mode. I cannot test it very good now because we are not allowed to drive outside in this Corona situation. I will have to wait for a few weeks. |
04-03-2020, 03:19 PM | #288 |
Rep 18
About VO and FDL coding
Hi guys! I know this is F30 forum, but I own MINI Cooper S F55 and know that many of the codes/options are similar. I just have few generic questions and hope to find answers.
1) After adding an option for 2TB to VO FA and then coding ECU and it would activate all options accordingly. Simple way but changes vehicle's VO. 2) Before I do that, is there a tool/program that will be able to show me what coding would change if you were to add the 2TB to the FA. This is in case I want to avoid editing VO and just want to FDL code separately. 3) Is there an issue with coding VO if my car is still under factory warranty? Just don't want any issues if my dealer should need to update the software(in case of a recall) and that would fail because VO was modified... Unless editing VO is harmless and even if dealer would update the software, it would simply reset all coding, then I am fine doing it again. Thanks! |
04-03-2020, 03:29 PM | #289 | |
Rep 41,196
Charkatak9.00 |
04-03-2020, 04:22 PM | #290 | |
Rep 18
Could you please be a bit detailed in explaining? 1) So after my car's VO is read, activate FA, I then open Salapa element, add 2TB option and apply changes? 2) I think I would need to calculate FA at some point. 3) Avoid going to VCM(for any Master FA/FP writing), Instead just stay in coding tab and read SVT or ECU? - don't know which. 4) Do I then just right click on ECU folder and select "code" to make the car search and code appropriate modules OR do I need to select specific items and code manually? Really appreciate your help! |
04-03-2020, 04:33 PM | #291 | |
Rep 41,196
That's it. Make sure "Update VCM" option is NOT enabled under E-Sys settings. |
Charkatak9.00 raphaelpais6.00 |
04-03-2020, 06:00 PM | #292 | |
Rep 18
1) Initially after reading FA under VO, I would be saving back up of my original VO. 2) After editing FA with 2TB, I then apply changes and after calculating FA would click save (floppy disk icon) on top. Will this action save to my original VO file that I saved at the beginning? 3) Then I click back button and E-sys should show: Another module or application has updated the file "name of my original VO file". Would you like to reload it in the module "coding"? At this point I say "yes" and this will load my Saved FA as you mentioned before? |
04-03-2020, 09:01 PM | #293 | |
Rep 41,196
Charkatak9.00 |
04-03-2020, 09:15 PM | #294 | |
Rep 18
- Shawn, any idea if I have saved a back up of my car's FA and something went wrong while coding, how would I be able to restore/flash that back up back to my car? - I have read from someone that there is an app/program that could show which modules are connected to 2TB transmission? Basically user enters an any VO option into that app and it shows all modules that will require to be set. |
04-03-2020, 09:21 PM | #295 | |
Rep 41,196
Token Master's NCD CAFD Tool has function to determine affected modules / FDL Codes. It's outdated now though, and has little support for newer CAFD files.
04-03-2020, 10:01 PM | #296 | |
Rep 18
The day I download E-Sys and other stuff, NCD tool was there too. I had no idea what it was. Looks like it can compare CAFD files and possibly something more. I guess once cable arrives, I will be able to experiment. - In my case the car is 2016 MINI Cooper S F55 with a regular steering wheel(without paddle shifters) and I am not planning to retrofit them in the near future. As I know, MINIs with paddle shifters have 2TB and Launch Control enabled at the factory. - Since MINI might have some different modules than BMW has, don't know if any of you guys would know which modules might need coding when 2TB is added. For example some MINI forums mention EGS, KOMBI and BDC_Body and this would take care of paddle shifters, 2TB transmission and show info on the instrument cluster. Other forums just mention EGS and KOMBI, no word about BDC_Body. The reason I want to know exactly what is being coded in the ECU is because if it will automatically enable paddle shifters and my car throws an error for the lack of them, then I want to be able to disable that function. |
04-04-2020, 05:53 AM | #297 |
Rep 1,240
I changed mine to "sport auto transmission" on bimmercode a few days ago. No paddles. No fancy shifter. Just a 2013 328i sport line. I don't know if I think the shift points are faster, but she certainly feels more aggressive getting through her gears. I think it increases acceleration quite a bit imo. Sport+ (already had it) plus the sport transmission makes for a very enjoyable driving experience. Also I show no codes or errors when the car is on.
Charkatak9.00 |
04-04-2020, 09:53 AM | #298 | |
Rep 41,196
Charkatak9.00 |
04-04-2020, 04:02 PM | #299 |
Rep 18
Thanks Shawn.
Couple of simple questions: - Under SVT Actual: what is the difference between read(VCM) and read ECU button? What is commonly used for coding? - Location of cheat sheet? I got one but I believe it is 2014 and doesn't seem to have 2TB info in it. |
04-04-2020, 04:23 PM | #300 | |
Rep 41,196
No idea on Cheat Sheet. YOu are VO COding 2TB, no need Cheat Sheet, as they are for FDL Coding.
Charkatak9.00 |
04-05-2020, 01:02 PM | #301 |
Rep 1,240
I have question regarding the coding for 2TB vs Standard 205. Does anyone know how many gears are in "DS" mode? We know is S1-S7, but is DS also 7 gears and not the full 8? I can't find the answer anywhere and can't go out and test drive to try and count them out because of the stay home order. Trying to avoid starting a whole thread to ask anyone who may know.
04-05-2020, 01:04 PM | #302 | |
Rep 41,196
Silverlining_m21746.50 |
04-05-2020, 02:06 PM | #303 |
Rep 1,240
That is what I suspected. I've switched it back to S205, and I'm curious to go try it after swapping back. S mode has 7 gears. So does DS. And pulling the paddles (or tilting the shifter up/down like mine) still clicks it to M1-M8. Kinda makes me think the 2TB code is for enabling the paddle shifters themselves and not much else. The added cooler is nice too as part of the 2TB package, but even though I said I noticed a difference earlier, since everything else is the same, minus the letter swap, I'm legit wondering if I placeboed myself lol. It felt like it grabbed quicker and pulled harder on each shift, but now I'm not sure. Does it auto shift up in manual mode on the S205? It did not when I had coded 2TB... this is one of the most interesting F30 convos to me. Definitive answers are nil.
04-05-2020, 06:49 PM | #304 | |
Rep 1,240
LOL NOPE. There is in fact a gear difference. S-1 through S8 "snap up", and while also fast (maybe just as?), DS "winds out" then switches... I can't explain it better really. Feels like I get through 4 gears in the time DS gets through 3. Now, hopefully it doesn't do damage to the tranny or timing chain. Feels like I can hear it "whine" more. Not like the dying cat sound, but there's more of a noticeable hum or rev in the motor. Car was warmed up. No faults though. |
04-05-2020, 06:54 PM | #305 | |
Rep 18
04-05-2020, 07:22 PM | #306 | |
Rep 1,240
There's instructions floating around about how to add it on bimmercode, but I think theres some added hardware we don't have with our standard 205. A tranny cooler and extra oil pump or cooler? Don't recall and I'm just learning. I have a 2013 with 51k and bought it last month. I have some time left on the non bmw warranty and a secondary starting soon. So I clearly worry about the extra wear, already knowing now, that I have the n26 that's least reliable. The 2013 wasn't LC compatible from what I read. So I'm gonna stay away. Bimmercode is a 1 button switch, and I assume it handles the correct coding for you. I pulled no codes when I checked afterward, and have switched twice now. It is definitely a different shifting program imo from 205 to 2TB. I'm wanting to hear accounts of it harming the engine/transmission if they're out there. I've been reading for days. Last edited by Silverlining_m2; 04-05-2020 at 07:55 PM.. |
04-05-2020, 08:00 PM | #307 | |
Rep 18
04-05-2020, 08:12 PM | #308 | |
Rep 1,240
Charkatak9.00 |
