BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
Studio RSR
      04-03-2020, 12:51 PM   #3059
pitoncho
Drives: bmw e87
Originally Posted by ande86 View Post
You probably will have to program the screen size, e.g. with bimmercode or icarly if you want to use apps or with other software
soo, it is possibly?
i mean, can i lie the system to have like a cic profesional with this android screen?
Is there any tutorial for changin the resolution?
Thank you
      04-03-2020, 01:45 PM   #3060
Mjam
Drives: E87, i3, Taycan Cross Turismo
Originally Posted by F20_M135i View Post
If it was as simple on a PX6, it is not the case with my S625 (V 3.8.7)
The instructions are for S625. If it doesn't work for you, try updating the MCU.
      04-03-2020, 02:01 PM   #3061
Kri
Austria
1084
Drives: E87
Originally Posted by fredy3330 View Post
The animation has to be only 150 pic (png) or more?
No, picture amount is not limited, but time of animation is defined through amount of pictures and fps setting of config file, so you don`t want to have it too long.
Thank you
Maybe it is possibly maybe not, there is some stuff the coding files, but this is a little bit too offtopic from this Thread.
Kri
      04-03-2020, 02:21 PM   #3062
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
Since the last version (the one I have) these "instructions" are no longer valid. I found (with difficulty) my happiness in the standard and system parameters, directly from the first screen (not the factory menu) then you have to click on camera selection to arrive on a second screen (with the choice this time -ci) Not at all obvious and rather poorly made in connection with my first PX6 ... But I found !!!
      04-03-2020, 05:34 PM   #3063
ande86
Drives: BMW F20
Thank you
What does your screen look right now? Do you only have the 6.6 inch and on the right Information about fuel ? And you want to have it in full screen In 8.8?
      04-03-2020, 06:13 PM   #3064
pitoncho
Drives: bmw e87
Yes, exactly, i mean, i dont know if it is possibly, because when i put 6,5 fullscreen it is to strait.. i see it in a very bad resolution
      04-04-2020, 12:05 AM   #3065
F20_M135i
France
101
Question
Hello guys,
2 questions for the regulars of the S625 (which I run with joy)
- Where is the file "factory_config.xml" please ?
- How to do so that I can control the SYGIC application with the Idrive wheel please?
I think I read something on this thread, so that it works but I can't find it ...
About the file "factory config.xml" I have an "ALs" unit and I have found only files (on the internet) which specifies "GS client" inside: Is there an incompatibility between?
Thank you in advance and good day !
      04-04-2020, 02:21 AM   #3066
daschacka
Drives: M5Competition
Hello guys,
You can use this one:
https://f30.bimmerpost.com/forums/sh...postcount=1920
All you have to do is to replace these lines:
Code:
<factory>
        <!-- Version information-->
        <ver>GS-BMW-20191211.en</ver>
        <!-- Vendor information-->
        <client>GS</client>
        <!-- Password of factory setting (4~6 digits) -->
        <password>0</password>
With your data.
I have a ALS device with these data:
Code:
<factory>
        <ver>ALS-20190713.en</ver>
        <client>ALS_6208</client>
        <password>070305</password>
F20_M135i100.50
      04-04-2020, 03:11 AM   #3067
ande86
Drives: BMW F20
Yes it is possible, but before you can change the resolution on the unit, you need to code the resolution into your car. You need an OBD adapter and an app bimmercode for example or if you know someone who can code, ask him.
      04-04-2020, 04:04 AM   #3068
pitoncho
Drives: bmw e87
Allrigh, thank you soo much. Where can i find the code to do that? I will use or carly or ncsexpert.. thank you
      04-04-2020, 04:41 AM   #3069
twoface
Drives: BMW 316D
I think its not possible for CIC units, only with NBT (NBT_ENTRYNAV). You can search forum for that
      04-04-2020, 05:06 AM   #3070
pitoncho
Drives: bmw e87
i will search it, thank you!
      04-04-2020, 05:43 AM   #3071
ande86
Drives: BMW F20
I read something that it should be possible for CIC mid, but can’t tell you for sure. I have a NBT and thought it would work for CIC as well, sorry.
      04-05-2020, 01:38 AM   #3072
F20_M135i
France
101
Question
Hello everyone,
I have an S625 Android 9 unit (Als) and I encounter a slightly annoying bug, in the FACTORY Menu (with code) there is an option to choose the action "voice" button on the steering wheel with choice of support long short press or do nothing
My problem and that whatever happens the OEM voice is triggered, and therefore I can not set up (via TASKER) the google assistant on this button
Is there a solution to completely disable this OEM voice button please? (except listening to it by the MCU of course)
good day to all !
      04-05-2020, 01:44 AM   #3073
Kri
Austria
1084
Drives: E87
Hello everyone,
good day to all !
You can`t disable any OEM Buttons with Android system, the chinese probably tried, but didn`t get it to work.
The Function they tried to implement is just not possible this way.
Kri
F20_M135i100.50
      04-05-2020, 04:40 PM   #3074
bepp67
Italy
Drives: bmw 520 xd f11
Hi guys, can you tell me if there are boot animations for 1920x720 displays and, if so, where to find them? thanks
      04-05-2020, 05:52 PM   #3075
Mjam
This works on cars without Voice option, so I wouldn't be surpriced if it will work for your car also if you remove the voice option from the VO. Assuming you don't use it anyway.
Kri
All options for the voice button are working on my car (E87):
1. Do nothing.
2. Short press do nothing, long press Navi
3. Short press Voice (does nothing, because I don't have oem voice option), Long press Navi
4. Short press Navi, long press do nothing
So if Tasker can recognize when Navi is launched from the Voice button, it should be possible to overrun this?
      04-05-2020, 11:13 PM   #3076
F20_M135i
France
101
Smile
1. Do nothing.
This is what I say in my message above
1 Default voice is triggered
2 Default voice is triggered
3 Default voice is triggered
4 Default voice is triggered
So I asked if there was a way for the voice not to be triggered, but it seems that it must go through a vehicle computer coding (BimmerCode / Carly / Esys) which I will not do
So I can say that the choices (from the factory menu) do not work with my F20 vehicle from 2012.
If I launch a TASKER task from this button, I enter an infinite loop of triggering of the wizard. I must be very scared, but I managed to make up for this (after 1 hour!)
On this subject, do you know which line is to be intercepted by "logcat" of TASKER please ?
because I no longer have the same reference "EventSystem" and "Icar Button" seems to be no longer the reference, MCU looks like it but that's what made me do the infinite loop, so I prefer to ask now ...
      04-06-2020, 03:13 AM   #3077
zorglubxx
zorglubxx's Avatar
Netherlands
Drives: 2010 E91 Touring
Yeah my E91 has the OEM voice option and I also have the same problem. And I get the same:
Would love to have it trigger Google Voice but not enough to mess with car coding
Problem when I use "OK Google" is that my phone also wakes up and then I have both the car and the phone listening
F20_M135i100.50
      04-06-2020, 03:22 AM   #3078
Kri
Austria
1084
Drives: E87
Thats exactly what i mean`t when your car has voice activation you can`t disable it, it will always start.
I have no idea how to implement a "OK google" Key without issues at the moment :/
Tasker String for example is:
Code:
<Str sr="arg1" ve="3">KswMcuListener</Str>
<Str sr="arg2" ve="3">--Mcu toString-----[ cmdType:A1 - data:17-07-01 ]</Str>
The Data numbers are the different hardware keys.
Firefly uploaded a list of the keys somewhere, i see if i can find it again.
Kri
F20_M135i100.50
      04-06-2020, 07:55 AM   #3079
b777rky
Drives: f45
Originally Posted by b777rky View Post
Vin: WBA2B11080V685310
2015
He send me same mcu from my photo, it wasn t an upgrade or downgrade
I want to mention, if i open the Youtube app, it works perfect it didn t give me "no signal"
Only the apps: waze-instant when i click"start", gmaps(after 10-15min), sygic-instant when i click "go", i didn t tried with other navigation apps..
Waiting for your answer, you can ask me everything is not o problem
Thank you for seeing my posts😉😉
Somebody can help me?
      04-06-2020, 08:47 AM   #3080
daschacka
Have anyone ever worked out the boot into Android function? Mine is keeping to boot into OEM side whatever i click in settings (Boot into OEM / Boot into Android / Remember last state)
