04-08-2020, 02:43 PM | #3103 |
Rep 80
Yeah, same here. I guess it's the price you gotta pay. I also tried with the "10.25 NBT" screen size option in the Android HU configuration, but the OEM side started acting up so I had to reverse it.
04-08-2020, 02:50 PM | #3104 |
Rep 1,048
04-08-2020, 04:35 PM | #3105 |
Rep 40
That sounds like a problem I heard from people with a CIC and there you canīt change the resolution, so if you started with a 6 inch display you have to stick to the size.
04-09-2020, 02:43 AM | #3106 |
Rep 551
Hello friends,
Can someone tell me which folder is our factory_config.xml file please? I would like to copy / save it on my PC (I am root) then add lines like Kri. I'm on S625 Android 9 V3.8.7 Als from 29-11-2019 and I only have 3 choices of ID, it's poor I think ... |
04-09-2020, 02:54 AM | #3107 | |
Rep 43
I will try to boot only with android, without bmw unit to see if it works |
04-09-2020, 12:35 PM | #3108 |
Rep 13
Hi all. Received my unit from MEKEDE on AliExpress. I have a BMW E87 without any screen.
Currently having an issue with sound & AUX. My car has Bluetooth, USB and AUX as standard with BMW Professional Headunit. However, I removed the fiber optic cable from the original quad lock to add to the harness provided, and when I do this, the original head unit loses AUX, USB and BLUETOOTH options therefore no sound for the Android screen. When I plug the original BMW professional back in with the original quad lock, everything works fine, USB, Bluetooth and AUX, it's only when using the android harness. @Kri can you help? I believe you have E87. |
04-09-2020, 12:52 PM | #3109 |
Rep 399
Can you make pictures of your harness? Sounds like the two connectors with all the white cables are switched, or not correctly inserted.
04-09-2020, 01:04 PM | #3110 | |
Rep 551
it is normally the opposite! When I received my unit, I did not put the quadlock, so no AUX and USB, then I put it = access (from the OEM) to AUX and USB, and finally, I put the AUX cable from the unit to the armrest (take a good cable of higher quality) |
04-09-2020, 01:43 PM | #3111 | |
Rep 13
View post on imgur.com Hi friend. I have BMW E87 2009 with no screen and BMW Professional (USB, BLUETOOTH AND AUX). Do I have to take GREEN FIBER OPTIC from original harness to place into after market one? |
04-09-2020, 02:05 PM | #3112 |
Rep 551
I don't mean stupidity, because I have an F20, but what I have described to you is what you can see in the video at 3.50 minutes :
But it seems that you don't have an optical cable in the quadlock? Watch the other video to maybe help you: |
04-09-2020, 02:13 PM | #3113 | |
Rep 13
Have a look at this. Seller says you have to switch optical cable from original quad lock to android quad lock. View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com Last edited by Livar; 04-09-2020 at 02:26 PM.. |
04-09-2020, 06:36 PM | #3115 |
Rep 12
another tip... I also have a Mekede unit whit the extra option called worse support.... took me 2 months to get it work.... also ordered an new wiring harness but that was not the problem..... there is a setting within the Factory option in the menu. The options asked you if the car is with original oem screen yes/no... I had to choose yes because I already had a 6.5" screen. try that option
04-10-2020, 01:22 AM | #3116 | |
Rep 1,048
@ Livar like the other already told, put the fiber into the chinese harness. Btw please don`t do double posts in both Threads, most people are reading both threads, so if someone does know a solution you will get a respond. Kri |
F20_M135i100.50 |
04-10-2020, 03:27 AM | #3117 |
Rep 80
04-10-2020, 03:34 AM | #3118 | |
Rep 8
04-10-2020, 04:07 AM | #3119 | |
Rep 8
04-10-2020, 04:44 AM | #3120 | |
Rep 1,048
As i`m running only a 2GB Ram version is see lags some time when switching between apps. But for the moment i see no "Killer-Feature" to update to Android 10, so if you`re fine with Android 9 stay on it at the moment Kri |
daschacka76.50 |
04-10-2020, 03:08 PM | #3121 | |
Rep 11
04-11-2020, 05:34 AM | #3122 |
Rep 80
04-11-2020, 07:49 AM | #3123 |
Rep 551
Hello !
I have a problem that annoys me when I listen to sound on the ANDROID side (KSWplayer / Spotify player or any) and I switch to the OEM side, the sound (on AUX) is always muted (?) when driving and wanting for example, Adjust the on-board computer = no More sound When Android Auto is disconnected, the unit switches to the OEM side, so = more sound When you park and PDC stop = no More sound You want to display Sport = no More sound It is quite painful! Anyone have a solution please ?? |
