03-27-2021, 02:36 PM | #3125 |
Rep 2
03-27-2021, 02:44 PM | #3126 | |
Rep 25
I was pretty sure mine was NBT because of the production date and the UI. I've also updated the NAV maps regularly so I know for sure it is an NBT unit. I should be getting mine on Monday. It would have arrived sooner (i.e. in 5-7 days) but the local logistics company (SkyPostal) dropped the ball and had the package waiting at the US hub in Chicago for about 4 days. SMH. Yes, the pre-sales customer service with KANOR has been good. I did have a somewhat long debate about the LTE bands on different versions. However, I think the issue was due to a language barrier. I chatted with both Joyce and Crystal but ended up working more with Crystal and placing the order through her. Remains to be seen how post-sales experience will be. Hopefully, there should be little to no reasons for contacting them. After reading through this thread, I think I know what to expect and how to address potential issues if they do arise. Finally, seeing that your BMW OEM display screen was made in China (no surprises there in the manufacturing supply chain), it seems funny how we often refer to these aftermarket head units as Chinese units. Issues in quality are obviously down to hardware and software engineering design standards and overall quality control - not so much from where they were made. Just thought I'd throw that out there. :-) |
03-27-2021, 02:53 PM | #3128 | |
Rep 25
My unit was actually shipped 2 days after I placed the order. I was initially told that there was no stock and it would take a week to ship. However, after I told them that I would shop elsewhere, they made things happen. Lol. So it seems like they may truly not have their own stock like you said. |
03-27-2021, 05:18 PM | #3129 | |
Rep 115
had the same issue with the yzg ones. not sure about the cpu but you can tell by the android version. look at the android sdk version and the build number theyre all for android 9 not 10. edit: just seen i replied to the wrong person lol, the cpu i think you can check by clock speed as i believe it should be 2.0ghz but these are 1.8 |
03-27-2021, 05:52 PM | #3130 | |
Rep 4
03-27-2021, 07:25 PM | #3131 |
Rep 124
Hey guys just installed an android screen in my car. My car originally came with the backup cam. When I go into reverse I see it switching but I get no image from the camera. Did I not install it correctly? I did the optical cable switch and I have sound witouth having to connect to arm rest aux.
03-27-2021, 07:26 PM | #3132 |
Rep 4,928
If anyone is looking for a solid supplier:
https://www.aliexpress.com/item/33047984764.html?spm=a2g0s.9042311.0.0.16474c4dvBd 4ru[/url] I bought the the 4G/64G 1920x720 blue anti-glare version. Works great, fully legit, also uses Zlink 4.0.5 wireless Carplay and Wireless Android Auto. Very pleased with it |
03-27-2021, 07:41 PM | #3133 |
Rep 71
Hi guys. Still having problems with my new Fiio K3. Seems like KSWSound Restorer isn’t autostarting sometimes, therefore multimedia audio is on 25%. And there are other times that the Fiio doesn’t output any sound if I don’t reconnect it. I’ve factory reseted the screen but nothing changed. I don’t know what else to do.
EDIT: seems like it’s a common problem: http://www.fiio.me/forum.php?mod=vie...=17&mobile=yes I think I’m going to return it and get another different. Recommendations? Last edited by coniman; 03-27-2021 at 08:08 PM.. |
03-28-2021, 05:33 AM | #3134 |
Rep 4
Hi Guys, first of all Thank you for the great collection of information!
I have a big problem with the new version of the android idrive Controller (Metal Ring Knob) like in this Video: https://www.facebook.com/groups/9987...3366511668312/ First Start up of the car - the idrive Controller is working, 2-3 start ups later - the controller completly off without light (not booting up with the HU) after start-up.. You have to unplug and plug-in the Cable from the Connector or the Controller while the HU is on, to make it work again. (Like in the Video) Someone knows this Problem ? I had an older idrive Controller too like this one: https://i.ebayimg.com/images/g/LKkAA...vsa/s-l300.jpg And this one do not have this Problem. What changed with the new Idrive from China ??? Thank You in advance!!! |
03-28-2021, 08:14 AM | #3135 | |
Rep 592
Don’t see anything for F15/F16 X5/X6 Models in their inventory. |
03-28-2021, 08:22 AM | #3136 |
Rep 592
@KRI
I’m about to upgrade my HU to SD625, and so that I don’t make the same mistake twice, or get left behind on the fine things you guys are doing, I’ve narrowed it down to Ebilaen and Avin. Which one would you recommend? Your advice is always appreciated. I’ll be putting the PX6 on marketplace once I upgraded. |
03-28-2021, 09:46 AM | #3138 |
Rep 2,370
Drives: E63 645Ci
03-28-2021, 12:41 PM | #3139 | |
Rep 353
Check out the store I've mentioned above. |
03-28-2021, 01:08 PM | #3140 |
Rep 4,928
Hmmm.. When I bought it a month ago, they had 3 units, SD, Antiglare, HD Antiglare Blue.
The one "win" for me was the wireless Android Auto. Most list as "wired". If they are using Zlink, then I have no idea why they wouldn't be wireless. |
03-29-2021, 09:08 AM | #3142 |
Rep 353
Use 2.3.6 android HU firmware + Sound Restorer app v1.2, it will keep your android sound level on max level at startup, you just need initially to set the volume on the DAC.
03-29-2021, 09:16 AM | #3143 |
Rep 26
03-29-2021, 09:32 AM | #3144 |
Rep 551
first thread : https://f30.bimmerpost.com/forums/sh...postcount=1300
03-29-2021, 10:30 AM | #3145 |
Rep 71
Hi again guys. I've finally fixed my issues with Fiio K3. I've connected it to the other USB port and now works perfectly. Also I've disabled anything related to battery saving for the Sound Restorer app and now it autostarts every time. But I'm still having problems with the mobile data. Sometimes even it has 4G and 5 signal bars I don't have internet. I have to switch on/off airplane mode to get internet.
03-29-2021, 06:21 PM | #3146 |
Rep 25
Just received my 12.3" unit today.
FYI: I got my unit from KANOR for $380 + shipping. I'll post feedback once it is installed. serge858 Like you said, there is a connected male AUX IN 3.5mm and female AUX OUT 3.5mm cable. Meanwhile, attached here are pics of the received shipment. |
