05-10-2020, 07:13 AM | #3125 |
Rep 41,224
PM sent.
05-25-2020, 01:51 PM | #3127 |
Rep 41,224
Are you using the latest 7-Zip to extract, not older version?
05-25-2020, 02:15 PM | #3128 |
Rep 37
05-25-2020, 02:31 PM | #3129 |
Rep 41,224
05-26-2020, 03:24 AM | #3130 |
Rep 10
ACSM1
Hi All
i want to switch off the 3 gongs when seat belt not plugged in yet this is for a 120Ah i3 November 2019 i have coded mirrors using esys, no problem doing that can any one tell me which line to edit to disable the 3 gongs when seat belt not plugged in yet ? many tnx Simon Last edited by simonfraser; 05-26-2020 at 07:14 AM.. |
06-18-2020, 07:15 AM | #3132 |
Rep 41,224
PM sent.
06-18-2020, 09:00 AM | #3134 |
Rep 41,224
Asked and answered. No need to cross-post.
06-20-2020, 10:02 AM | #3135 |
Rep 41
I-Step
Hello.
I'm in the proccess of adding idrive controller with touch function (I had the smaller dial) and touch module. Right now, the controller doesn't work even when connected directly to the car. I already coded four "touch options" to the NBT unit, but still nothing (with or without touch module). I suspect I might have an issue with kcan/kcan2 but that's a problem for another thread. "The four "touch options" coded are HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP set to aktiv HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER set to aktiv HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER set to aktiv HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH set to aktiv" I already updated "zeitkriterium" to 0713 (from1112, I believe). Now I might have an issue with NBT program level.. Other users report that it needs to be 50.4 or newer. I don't know how to check it. In doubt I tried to flash it. ( only chose that unit because I don't have external power source) However, when I choose "Check software availability", on the second to last step of the tutorial, I get an error: "Missing SWEs in PSdZData directory [C201]." I need the full version of the PSdZData files, correct? How do I get the correct version? I have I-Step (shipm.) F020-15-07-502. I get two options for target. The newest is F020-19-03-530. I have to get the full set of PSdZData files for that same F020-19-03-530 version. Correct? (F31 from 11/2012) Can I get a link for it here, also? |
06-20-2020, 11:42 AM | #3136 | |
Rep 41,224
06-23-2020, 03:14 PM | #3138 |
Rep 5
DKOMBI2 [60] []
readCPS o.k. CAFD_00002660_009_001_020 Fehler: File for "cafd_00002660-009_001_020" not found! [C012] Hi ShawnSheridan, do I need PSDzData files to fix this problem? Or am I doing something else wrong? Esys 3.31.0 G30 2018 Recently updated software at BMW workshop. |
06-23-2020, 04:50 PM | #3139 | |
Rep 41,224
07-09-2020, 01:30 AM | #3141 |
Rep 41,224
If you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full. PM sent.
07-12-2020, 09:59 PM | #3142 |
Rep 30
Hi Shawn. Recently purchased 2012 F30 AH3 and would like to try some coding. Have purchased cable and would appreciate if you could send me links to the required software ( and installation instructions if these exist) Many thanks in advance. David
07-12-2020, 10:05 PM | #3143 |
Rep 41,224
PM sent.
07-13-2020, 11:42 AM | #3146 |
Rep 41,224
PM sent.
