04-05-2020, 03:08 PM | #309 | |
Rep 7,733
How confident are you on a leak free install of the CP and IC? Your boost control looks a little strange; it takes a while to reach target, then you start to overboost, it pulls WGDC and you drop below again, which repeats. It might have even happened one more time if you went to 6k+ rpm. Also, your STFT are very negative. I dont think ive ever seen 20% fuel getting pulled like that before. To me those things suggest a leak after the MAF, hard to be certain though since you are actually able to reach boost target eventually. |
04-05-2020, 05:24 PM | #310 |
Rep 983
Drives: 2016 F36 435x MSport
Anyone got thoughts on the two random knocks? Wondering if its just noise since one is low RPM and the 2nd is mid shift. Really cant believe how crappy the timing looks. Been trying to chalk it up to crap CT gas, but i get the same behavior with the 91 tune.
https://www.bootmod3.net/log?id=5e89...0b436a66a1a264 Running 93 octane with boostane. Sport+, Paddles., Stg2 and XHP Stg3. One step plugs at .024 (replaced them and coils with eldors about 200 miles ago) Second pull, same spot, no knock https://www.bootmod3.net/log?id=5e89...90c608068500f6
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
04-05-2020, 06:25 PM | #311 | |
Rep 741
or is that XHP?(i think i m spelling it correctly)
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
04-05-2020, 07:16 PM | #313 | |
Rep 38
04-05-2020, 08:27 PM | #314 |
Rep 741
Thank you.
04-06-2020, 11:17 AM | #315 | |
Rep 7,733
https://f30.bimmerpost.com/forums/sh...als+for+charge https://f30.bimmerpost.com/forums/sh...oost+leak+test There needs to be some resistance when you install the CP onto the IC. If it just "falls" on and you can rattle/wiggle it back and forth easily even once it is all the way on and clipped, its probably not going to be air tight. |
04-06-2020, 12:44 PM | #316 | |
Rep 643
adding boostane hasn't helped as much as it did last season, so i'm guessing the gas quality is really bad right now and rising IAT is exposing it. |
04-06-2020, 12:54 PM | #317 |
Rep 114
I bought the car it came with a stage 1....... I got it for free I found it in there when I was doing maintenance called Dinan they told me to upgrade to stage 3 would be 100 bucks plus it is still under their warranty
04-06-2020, 01:06 PM | #318 | |
Rep 983
04-06-2020, 01:38 PM | #319 | |
Rep 7,733
04-06-2020, 01:48 PM | #320 | |
Rep 564
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
04-06-2020, 02:04 PM | #321 | |
Rep 7,733
E85 has roughly 30% less energy density than gasoline. You cant just add a bunch of E85 (without switching to an ethanol tune) because your fueling will be off. Yes, the DME will try to compensate with fuel trims, but you really dont want to do that beyond a few gallons of E85 to a full (remaming) tank of pump gas. Bottom line you should do the test using 100 octane. If long term you want to start mixing E85 into pump gas to achieve higher octane, that is a separate conversation. |
stlb5277.50 |
04-06-2020, 02:06 PM | #322 | |
Rep 564
04-06-2020, 05:38 PM | #323 | |
Rep 983
And in CT there is literally only one e85 station and it's about 5o miles away |
04-16-2020, 04:03 PM | #325 |
Rep 114
04-16-2020, 10:21 PM | #326 | |
Rep 643
Just stick with your dinan software and reinstall original catalytic converter. If you want more exhaust note, you can install aftermarket exhaust or do resonator or muffler delete for cheap.
M235i rwd 6mt
n55david1322.00 |
05-09-2020, 05:23 PM | #327 |
Rep 39
how is version 7.0 treating you guys? Im still on 6.4, havent had the time to update, any weird issues or idling?
'15 335i x-drive 6MT.
Catless DP, CP, Intake, IC - BM3 STG1 93 ' |
05-09-2020, 10:42 PM | #328 |
Rep 643
7.1 has been out a while. Most are satisfied with 7.1. I never read of idling issues. Just don't delete your 6.4 tune if you want to revert
M235i rwd 6mt
05-11-2020, 02:15 AM | #329 |
Rep 39
05-18-2020, 06:31 PM | #330 |
Rep 39
Been busy and haven't been able to share this yet (or even go on the forums) but man 7.1 feels refined almost stock. definitely feels better at lower rpm.
Anyone care to chime in? 2nd gear pull 2500-7k https://www.bootmod3.net/log?id=5eb8...0b430ed5ce443f
