05-22-2018, 11:41 PM | #309 |
Rep 606
Supernova66
Did you check the voice input part? I really would like to voice input my destination but I think the external optional mic is for bluetooth only. I just need Louie to confirm that if I dont connect it, it uses the internal mic for this. Then onlu USD5 lost I just received an email to confirm my shipping addres and I have NBT with 6 pin LVDS (which I have). When my mic question is answered, they are ready to ship The USD15 will be returned after the end-date of the group buy I heard from Louie. Last edited by DRuw; 05-23-2018 at 12:41 AM.. |
05-22-2018, 11:48 PM | #310 | |
Rep 42
One last question is If the factory antenna cable (the one connected to radio unit) is long enough, can I just take it out and connect it to 10.25 without using gps splitter? Does the raido unit need gps signal from the sharkfin gps antenna cable? Is gps signal to radio unit necessary for some functions of original idrive unit (e.g. to retrieve data into new android unit?) Sorry for silly questions but im learning a lot from the experts in this forum. Many thanks in advance! |
05-22-2018, 11:49 PM | #311 | ||
Rep 606
I know there is also a horizontal slot available in the glovebox but if you plug something in you cant close it anymore. I will use one plug for my DAB so I only have 1 connection in my glovebox which I do not have problems with, there is also a pre-cut and covered hole in the back of the glove box. About installation, I would actually recommend removing the glovebox itself. 11 screws in total and you have complete access to the guts of the car, also the back or the radio (with somewhat smaller than average hands that is..) Very easy to route the cables that way so if you have the time, I would do that... Quote:
I dont know if other functions need the GPS signal, perhaps it is tied-in to more functions and you can get a signal error but I doubt it.. The android unit is completely seperate from the factory radio. If you use the factory radio on screen, it just acts as a "dumb" screen. No info is transmitted other than the video signal. |
05-23-2018, 03:06 AM | #312 | |
Rep 44
Mine |
05-23-2018, 03:51 AM | #313 |
Rep 606
wacky007 Thirdy losdamianos Grandelama
I have just had contact with Louie and it seems that the unit EITHER had the external mic OR the internal. It is not an addon. Oficially, the mic is only for bluetooth calling but since Supernova66 has his mic (internal) working with google, I dont know how it works exactly since the old mic is removed and on the connections, the external mic is soldered (cant imagine how they do it otherwise). Perhaps (and I give this option a real chance) an USB mic wil work otherwise... Taechit I understood that the internal mic is physically removed and replaced by an external connection. The hardware is therefore different instead of an add-on which I thought.. Last edited by DRuw; 05-23-2018 at 05:13 AM.. |
05-23-2018, 03:53 AM | #314 |
Rep 152
Louie said my unit should ship in two days. Also ordered the gps splitter. Hopefully other orders follow suit. I won't fit the unit until the splitter arrives but then I'm sure others will post pictures
05-23-2018, 03:56 AM | #315 | |
Rep 606
Also my DAB splitter and module are not in yet so there is a lot of china-stuff going my way |
05-23-2018, 04:04 AM | #316 |
Rep 152
Yeah the dab is out of stock. I'm going to use it without the dab splitter for now and get one if I need it. I doubt I'll use the car's nav but if I do then I never use navigation audio anyway. Can use BMW's dab and then android's google maps. I actually can't recall the last time I used navigation audio
05-23-2018, 04:06 AM | #317 | |
Rep 606
The android based programs do have this I used Waze and thats very user-friendly and clear. Google maps also works ok and is nice with the sattelite photos but will take way more data.. Damn, I cant wait! |
05-23-2018, 10:15 AM | #318 | ||
Rep 201
05-23-2018, 10:16 AM | #319 | |||||
Rep 201
05-23-2018, 11:19 AM | #320 |
Rep 12
Hello all. I am newby to this forum and could not hesitate to jump into this discussion and get my conclusion in 2 days after a deep research on Avinusa and others with Android 4.1.
Definitely this Ugode solution looks like the better choice. I just put my order with Louie/Alice. Cheers!!! |
05-23-2018, 12:03 PM | #321 | |
Rep 44
When I hold the voice button on the steering wheel, it activate Siri on my iPhone via the original NBT system and using my BMW mic, but nothing shows on the android display. But when I try to use the google voice assistant app in the unit, it doesn't receive any voice signal, even I've already plugged my external mic. |
05-23-2018, 12:26 PM | #322 | |
Rep 44
Alice has sent me a new microphone cable. She said that I need to plug it in the power cable (not that 3.5' jack?, so confusing). I'll try it first and report if this annoying problem is solved or not. |
05-23-2018, 02:26 PM | #323 | |
Rep 606
they are two seperate systems to that should not work unless they are tied-in in the harness somewhere (which I doubt). Supernova66 You do have a internal mic in the unit (which is replaced when you order one with the external mic) but how do you know its the BMW that picks up the voice? Please update the spreadsheet https://docs.google.com/spreadsheets...OSU/edit#gid=0 |
05-23-2018, 02:54 PM | #325 | |
Rep 606
Read this topic and if you want to buy it use the Alibaba link and option remarks in my post #224 on this page: http://f30.bimmerpost.com/forums/sho...481613&page=11 ps: If im correct the new price is now communicated in the order from Louie. The USD15 refund is not required for the new orders since we already reached 10+ orders. The early buyers will probably get the refund shortly after 28-5 but Louie will contact us for this I understood. |
05-23-2018, 03:49 PM | #328 |
Rep 847
Drives: 2025 G05 X5
Someone tell me how Spotify and Netflix look/sound. Are there are any lip sync with videos. Also, does it maintain original aspect ratio with video and apps?
05-23-2018, 05:36 PM | #330 | |||
Rep 201
they are two seperate systems to that should not work unless they are tied-in in the harness somewhere (which I doubt). Supernova66 You do have a internal mic in the unit (which is replaced when you order one with the external mic) but how do you know its the BMW that picks up the voice? I don't have an external mic attached so I assumed it was the BMW mic. Once I get my car back together I can look deeper. Waiting for the USB cables from Louie as one of my original had a broken wire. |
