12-18-2023, 06:58 PM | #3917 | |
Rep 971
Pull the plugs, look at them and see if they look bad. Put in stock plugs it could be as simple as that. Your STFTs looked fine, your vanos looked fine, your load target / actual looked fine, your rail pressure looked fine. To me it looks like its a mechanical issue and i'd start looking at the easiest component to diagnose which are the spark plugs. As for the gap of 0.019, its completely necessary to gap your spark plugs. I've pushed cars past 30psi on the stock gap with a pure850 or daw UF without issue. |
12-19-2023, 04:23 AM | #3918 |
Rep 2
Hi guys,
could you please take a look at my log and give me your opinion on it? My setup: - M240i (automatic, rear wheel drive) LCI without OPF (from 09/2018) - approx. 70.000 km - M Performance exhaust - stock downpipe - new service (including oil change, spark plugs and ignition coils) 1 month ago - xHP Stage 2 - MHD Stage 1 (at 95ron) but I get 102roz from the gas station Run: https://datazap.me/u/shoodaa/1812-te...43-44-45-46-47 1st "pull" - medium load from 100 - 200 km/h (normal mode) 2nd pull - full throttle from 100 - 200 km/h (normal mode) 3rd pull - full throttle from 100 - 200 km/h (sport mode) I don't notice any problems while driving, but after checking the logs I noticed timing corrections up to -7.5 degrees. I also started first with MDH Stage 1 (98roz) and saw some timing corrections there as well, thats why I did the oil change together with a replacement of spark plugs and ignition coils and went down to the map for 95roz. I could also check if I find the previous logs. Also no corrections that are caused by knocking. Thank you in advance! |
12-19-2023, 09:08 PM | #3919 | |
Rep 971
12-20-2023, 03:18 AM | #3920 | |
Rep 6
Yesterday I changed the spark plugs to NGK with OEM gap. The combustion chamber and cylinders look normal. Car runs smoother. Attached is a photo of the spark plug from the 1st cylinder. The others look the same. I made new logs. Some are good and some are not. It still feels like there is a lack of performance. In the logs, the Vanos exhaust reacts slowly and fidgets back and forth. I carried out the Vanos test with ISTA and lo and behold, the Vanos could not be adjusted and the test was aborted. Run1 https://datazap.me/u/flom4/run1-e30?...48-49-50-51-63 Run2 (High timing corrections and timing delta for knock adapt.) https://datazap.me/u/flom4/run2-e30?...46-47-48-49-50 Run3 https://datazap.me/u/flom4/run3-e30?log=0&data=3-23 Run4 https://datazap.me/u/flom4/run4-e30?log=0&data=3-23 Run5 https://datazap.me/u/flom4/run5-e30?log=0&data=3-23 I replaced both actuators 9,000 miles ago. Didn't look good. The next guess would be the Vanos central valves. Could this be the cause? Thanks in advance for your time and feedback. greeting Flo |
12-20-2023, 10:34 AM | #3921 | |
Rep 971
12-20-2023, 04:04 PM | #3922 |
Rep 2
Perfect, thank you! I'll also ask MHD just to be on the safe side, but they need logs with psi instead of bar. I recorded some new logs today and I changed bar to psi only for the display but not for the logs
12-20-2023, 08:25 PM | #3923 |
Novice
316
Rep 700
I'm just gonna drop my DAW V2.5+, DS2, E10-E50 FF log here to show everybody what my current setup is doing.
https://datazap.me/u/universalg/v37-e43-dec-9 - MOST RECENT LOG E43 BOOSTING 25-26psi https://datazap.me/u/universalg/v25-december - RECENT LOG E43 BOOSTING 27-29psi I'm planning to go full frame soon |
12-20-2023, 09:56 PM | #3924 | |
Rep 340
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
12-21-2023, 03:22 AM | #3925 | |
Rep 6
I have now ordered everything I need to change the central valves. I also ordered 6 new Bosch fuel injectors and a new BMW OEM valve cover. In January I will change everything and report back with the results. Thank you in advance for your help and your time. greeting Flo |
WrxToBeamerGuy517.50 |
12-21-2023, 01:44 PM | #3926 |
Rep 28
Hi Guys, i Have B58 made log everything perfect , but im new to tune and IAT numbers what counts normal Compared to Ambient Temp? Like I measured 27.8 celsius IAT AT 8.5 outside Temperature is this normal? Summer i measured at OUTSIDE temp 32 celsius IAT was 46 celsius are these numbers Okay? Thx
12-22-2023, 01:40 AM | #3927 |
Rep 3,988
Yes they are. IAT will always be appreciably higher than ambient. One wants to keep them as low as practically possible.
12-23-2023, 08:56 AM | #3928 |
Rep 31
Hello,
My 2018 M240i runs a stage 1 map tuned by my local tuner and 95 octane fuel is used. My car feels really slow and sluggish especially when the car gets warmer. This feelings is a lot more noticable in lower gears. It revs up so slowly as if something is holding it back. I see some torque limiters kicking in and I have no idea what they mean. Can someone please review my log? 5th gear: https://datazap.me/u/ycilgin/5th-gea...og=0&data=5-28 2nd gear: https://datazap.me/u/ycilgin/sorun-2...og=0&data=5-28 |
12-23-2023, 10:32 AM | #3929 | |
Rep 92
12-23-2023, 11:37 AM | #3931 |
Novice
316
Rep 700
I plan to keep everything within the safe limits of the trans. 30PSI on a hybrid turbo is not the move. The back pressure and cylinder heat caused by running 30PSI+ on a hybrid just isnt worth it. That is why Id rather go with a full frame single turbo kit to minimize the back pressure thus allowing you to run more timing advance.
12-23-2023, 10:22 PM | #3932 | |
Rep 590
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
blacksapphire440i316.00 |
12-28-2023, 03:38 PM | #3933 | |
Rep 5
12-29-2023, 08:12 AM | #3934 | |
Rep 31
12-31-2023, 09:25 AM | #3935 | |
Rep 6
In addition, I replaced the valve cover and all injectors. Would have been too nice, but it didn't solve the problem. VANOS system could not be adjusted during test on the inlet side. It runs much smoother at idle and when driving it also feels more power and less timing delta for knock adap. Chain length is very good, no wear on the cylinder head or camshaft to be seen. The engine is easy to spin. Steering times were also perfect. I also checked all the cables. Unfortunately, I didn't know how to test the Vanos adjustment unit for wear. I will now also replace these on the inlet and outlet side. I hope it solves my problem. Otherwise I have no idea anymore Run1 https://datazap.me/u/flom4/run1-e30-0?log=0&data=3-23 Run2 https://datazap.me/u/flom4/run2-e30-0?log=0&data=3-23 Run3 https://datazap.me/u/flom4/run3-e30-0?log=0&data=3-23 greetings Flo |
12-31-2023, 12:33 PM | #3936 | |
Rep 118
Maybe that's the reason why the actual boost is showing some waves in the beginning (26-23-26-23 psi) until it stabilizes. |
01-01-2024, 06:07 PM | #3937 | |
Novice
316
Rep 700
https://datazap.me/u/universalg/v25-part-2 boost looks beautiful from 4th to 5th. I believe the boost shows waves due to the tuner and turbo spooling quick as balls these datazap logs also have 2 logs within them each and they all look fantastic even tho im maxed the hell out! Last edited by blacksapphire440i; 01-01-2024 at 06:16 PM.. |
01-01-2024, 10:34 PM | #3938 |
Rep 971
Sorry no one replied to you sooner. No I don't think you have a boost leak I think there is something wrong with this tune. If you look at "load actual" and "load target" it absolutely should not be decreasing down to 160 from 190 and then increasing again. It doesn't make much sense. Is this the "final revision" can you have your tuner fix this with the next revision?
As stated previously though, please never floor the car in a high gear at a very low RPM it can cause predetonation. |
ycilgin1.50 |
