04-04-2018, 10:18 PM | #397 |
Rep 983
Drives: 2016 F36 435x MSport
you know whats interesting ... the ignition timing 2 graph around the time of the knock detection
every other log i have the timings all seem to match. Most likely the reaction to the knock.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current Last edited by paimon.soror; 04-04-2018 at 10:25 PM.. |
04-04-2018, 10:20 PM | #398 | |
IG @bmwF9xG80
3858
Rep 7,614
I'm running V5 E30 for the past full week E20 blend went well, now running E25 going to test tomorrow more.
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
04-05-2018, 09:45 AM | #399 |
Rep 983
From Halim@HCP
"Nothing to worry about, you should worry if it happens at WOT high rpm."
2016 BMW 435xi GC - Current |
04-05-2018, 02:56 PM | #401 | |
IG @bmwF9xG80
3858
Rep 7,614
Sometimes even a bad batch of gas can knock but if the knock is persistent then there's something to check No, not enough customers that have AH3. I remember hearing a few months ago it will have to be custom when compared to the user-base of say N20/N55/S55/N63TU/S63TU. Time-consuming and not enough testers to have OTS maps last heard they were not supporting it anymore due to this.
60-130 6.5s X4M
04-05-2018, 05:00 PM | #402 | |
Rep 983
https://datazap.me/u/paimonsoror/bm3...log=0&data=4-8 Seems to happen mostly when the engine is colder vs fully warmed up. Ride home, leaving work, she detected 4 knocks. WOT is still fine. Just wierds me out because there isn't really anything that would indicate why the knock is happening. Boost is nearly nil, timings are all inline, and i wouldn't think that the timings are aggressive at cold start low rpm.
04-05-2018, 05:03 PM | #403 | |
Rep 808
04-05-2018, 07:57 PM | #404 | |
Rep 969
Unless I am looking at something completely different... all the knock I'm seeing in your logs happens below 2k rpm at barely 25% throttle and under no boost... as in you are barely pushing the gas pedal. I wouldn't worry about it unless its happening when you are on throttle and boost is building. It's so sporadic ... probably just picking up some false knock.
FSociety3857.50 |
04-05-2018, 08:02 PM | #405 |
IG @bmwF9xG80
3858
Rep 7,614
Switch gas station/brand
60-130 6.5s X4M
ceedawg472.00 |
04-05-2018, 08:02 PM | #406 | |
Rep 983
F30_SixSpeed1171.50 |
04-05-2018, 08:37 PM | #408 | |
Rep 983
Shell 93
low rpm + little to no throttle + light load != lugging
04-05-2018, 09:17 PM | #409 |
Rep 1,206
04-05-2018, 09:26 PM | #410 | |
Rep 983
look at my logs again. theres no heavy throttle action. i know what lugging is ... that's not at all whats going on none the less, will give it a fresh tank and make sure it doesn't continue into the higher rpm/load ranges
04-06-2018, 11:29 AM | #411 |
BMW Fan
294
Rep 847
Sorry for asking about a different platform but this is by far the most active thread on the forums.
I've read all 19 pages of this thread and I saw a couple of posts regarding the e82 N55 PWG. Mine is a 2012 with locked DME. Is BM3 available for this? If not, will it be? There's no mention of it on the PTF website. Thank you
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i |
04-06-2018, 01:27 PM | #412 |
Rep 55
If I am running Stage 2 OTS map E30, is it still safe to run a full tank of 93 in the car on this tune and then the next tank some E85 to E30?
Lets say I am on a trip and don't have access to E85 but later on in the next fill up, put some E85? |
04-06-2018, 01:38 PM | #413 |
Rep 214
My car came with MPPK, MPE etc.. as it was a 2015 M-performance edition.
I want to get BM3 but was just wondering if it would take advantage of any of the OEM BMW performance mods? Have catless DP, chargepipe and intercooler in the works before I go with BM3. |
04-06-2018, 09:35 PM | #415 | ||
IG @bmwF9xG80
3858
Rep 7,614
I usually throw E30 and if I need to fill up only 93 i try to add at half tank so at least there's some E15-E20 there MPPK gets replaced once you flash any of the OTS maps, furthermore the latest OTS has MPPK inspired throttle mapping
60-130 6.5s X4M
deezeedee33532.00 |
04-06-2018, 09:37 PM | #416 |
Rep 983
It wouldn't necessarily 'take advantage' of any of the MPPSK stuff, but the intake will certainly help a bit over the folks running the BM3 with OE intake.
04-07-2018, 01:31 PM | #417 |
Rep 969
Stock PWG Turbo, FBO, 93 octane, V6
Best Pull: 383whp, 494trq
04-07-2018, 01:33 PM | #418 |
Rep 983
ecided to give the stg1 93tune a shot (ran 91 tune before). Hrmm, not good on the more aggressive pull i took:
http://www.bootmod3.net/log?id=5ac8fb77d10b437180ac3398 https://datazap.me/u/paimonsoror/bm3-v6-93-oct… looks like cyl 1 didn't like it @ 4th gear around 6.5k rpm afr looks good, not too rich and didn't take a hit after the knock
bm3, bmw, bootmod3 |
