04-28-2024, 07:43 PM | #4159 |
Rep 21
Can someone take a look at these logs for me the second one is me just cruising first is a proper log, Im concerned about the timing delta being so high in the second log.
https://datazap.me/u/elb58/4th-gear-1?log=0&data=5-25 https://datazap.me/u/elb58/timing-de...og=0&data=5-25 Im on a daw flowmax+ on shells 91 might be a bad batch of fuel as I went to a different shells location but regardless doesn’t seem right. |
04-29-2024, 10:41 AM | #4160 |
Rep 29
Can someone take a look at my logs? Running BM3 stage 2+ 93 tune. Current set up is TU pump, new injectors, new NGK 94201 plugs gapped to .028, VRSF catless downpipe. I was running the stage 1 93 map and was getting quite alot corrections and knocks. I put a couple gallons of e85 in and it cleared everything right up. Over the weekend and flashed to the stage 2+ 93 map and I'm getting some minor corrections again but no knocks. Worried they will only get worse when the weather warms up.
https://bootmod3.net/log?id=662e4fe296d1b127238d2100 |
04-29-2024, 11:59 AM | #4161 |
Armchair Aristocrat
359
Rep 451
Still getting engine knock
Tune: BM3 OTS Stage 1 E30 map
Mix: E38 using 93-octane Shell gas (see log flexfuel sensor) Equipment: Active Autowerke downpipe, TU HPFP, Pennzoil Plat Euro 5w40 oil, new NGK plugs (stock gapped) Have had engine knock at low-RPM in the past. On advice of this forum am running E38 on the E30 tune to try and clear up the knock. 2 logs still have engine knock Log 1: https://www.bootmod3.net/log?id=662f...7ee711b7e3d41b Log 2 (knock): https://www.bootmod3.net/log?id=662f...7ee711b7e3d47a Log 3 (knock): https://www.bootmod3.net/log?id=662f...a8bf21c558e861 Log 4: https://www.bootmod3.net/log?id=662f...a8bf21c558e869 Any ideas what to try next? **EDIT** I think it might be something on cylinder 5. For both knock logs, it seems cylinder 5 that is knocking. Also see this E30 Stage 1 Map w/E43 from September: https://www.bootmod3.net/log?id=6502...90c6120936bbcd this Stage 2 map: https://www.bootmod3.net/log?id=6502...0b435ca6e0a8cc and this Stage 2+ map: https://www.bootmod3.net/log?id=6502...729b152462c3f5 It is always cylinder 5 that is most affected. Already replaced plugs so it might be time for some new coils or injectors? Anyone have any thoughts?
04-29-2024, 09:30 PM | #4162 | |
Rep 971
Dustin Braun @ Braun Performance Tuning
04-30-2024, 11:59 AM | #4163 | |
Rep 28
Hi im no expert in fact i know very little,,, but for me im on Mgflasher Ots stg2 and on 98 ron map (98ron fuel) i have knock, on 95 ron using 98 fuel no knock! I sent my logs to tuners they said knock is actually a throttle knock… they said nothing to worry but for me The timing is consistent, for you is not compared to mine… I think its best to spend extra money for custom tune, i will do that also we will Get more power and more safety… by the way Kern417(Kevin) also told me he not really cares about knock He looks The ignition and the correction thats what matters according to him… I double checked where i have knock timing is all Over for me as well!! Best to get custom tune 🤷 |
04-30-2024, 06:14 PM | #4164 |
Rep 74
Hi guys,
I've recently flashed my Gen1 with MHD Stage 2 HPFP and run on 99 Ron fuel. Would you mind having a quick look and let me know if these look OK? Are the timing corrections OK? There's a little bit of overboost there too and a throttle closure. https://datazap.me/u/simonocr/mhd-st...og=0&data=3-17 https://datazap.me/u/simonocr/mhd-st...og=0&data=3-17 Thank you |
04-30-2024, 07:58 PM | #4165 | |
Rep 21
https://datazap.me/u/elb58/added-175...36-37-53-66-68 |
04-30-2024, 08:02 PM | #4166 | |
Rep 971
04-30-2024, 08:35 PM | #4167 |
Rep 92
Is turbine power something controlled by tuner? I changed tuners because the car was running horrible with this log. New tuners log keeps it at 60 "turbine actual" in the same boost and fuel. It goes to nearly 80 RAM Turbine actual in this log.
https://datazap.me/u/mralmeida/pure8...&data=32-59-60 |
04-30-2024, 09:13 PM | #4168 | |
Rep 971
mr.almeida62.50 |
05-01-2024, 07:53 AM | #4170 |
Rep 38
Stock car with highflow catted dp, ron98, st2 MHD
Should I worry about these corrections? https://datazap.me/u/black340i/log-1...og=0&data=2-22 |
05-01-2024, 08:01 AM | #4171 | |
Rep 241
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
Michalt3.00 |
05-01-2024, 07:26 PM | #4173 | |
Rep 74
05-01-2024, 08:01 PM | #4174 |
Rep 21
By any chance do you know why when datalogging sometimes it will glitch and skip rpms as if it doesn’t register it example this log i just took; it cut off at 3600 rpm no data then at 6000rpm starting registering the data once again.
https://datazap.me/u/elb58/4th-idk?log=0&data=5-25 I didnt check until i got home now that log is null gotta wait take another log tomorrow |
05-01-2024, 10:35 PM | #4175 |
Rep 971
All
05-01-2024, 10:38 PM | #4177 | |
Rep 971
BryanB586.00 |
05-01-2024, 10:40 PM | #4178 |
Rep 971
Timing does not look okay. I would try another gas station, adding ethanol, or flashing a lower map.
05-02-2024, 01:59 AM | #4179 |
Rep 3,989
Used to happen up to 4 out of 5 times with the black MHD adapter! It was absolutely terrible as most of my logs were unusable!
Tried with a second one - same/similar thing. Since I moved to the MHD Universal one - the problem disappeared completely.
WrxToBeamerGuy517.50 BryanB586.00 |
05-02-2024, 09:28 AM | #4180 |
Rep 971
Im using the Kies adapter.
