BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      05-19-2024, 04:24 AM   #4225
DreamerJoe
Drives: 2017 340i M.G. w red interior
Originally Posted by BMW335l View Post
So boost is on point, that was my mis-read from not being used to bm3 layout, everything looks on point besides those timing corrections. Idk which region you’re from, but might want to up your e85 a bit
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      05-19-2024, 06:56 AM   #4226
BMW335l
Drives: M240i, GTI MK5, Corolla TTE
Yeah, cyl 1 definitely has to much correction. Weirdly enough, the car runs much worse then the logs indicate. Feels more like -6 to -8 on all cyl.
I will do a re flash, add some more E and then do another run. I'm located in Sweden, and our fuel is known to be bad. But that doesn't really explain why my stage 1 tune with less E runs better. Maybe higher boost/lower timings.
I'm thankful for any other suggestions.
      05-19-2024, 10:35 AM   #4227
DieselDuck
DieselDuck's Avatar
110
Drives: BMWB58
Originally Posted by aataylor18 View Post
What steps would you take in this scenario? I guess run out the tank, reset adaptations, check plug gap. I flashed back to stock. Kind of at a loss. I'm afraid to even do pulls if it's that dangerous.
Yeah as you say, flash stock, use stock gap, check for any fault codes, and do a log while stock. Start from there
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
      05-19-2024, 05:58 PM   #4228
SimonO
Drives: 340i
MHD Stage 2 HPFP Logs & Dyno Chart
So I had a couple of runs on one of the UK's most conservative dynos at the weekend. First run was MHD Stage 2 HPFP 95 Ron; second run was MHD Stage 2 HPFP 98 Ron. Tesco Momentum 99 Ron fuel was used in both runs and with no ethanol. Only hardware modifications were a 4.5" 200 cell downpipe and TU HPFP.
See both logs below and accompanying chart. Hopefully this might be useful but comments would be welcomed! Note how things seem to plataeu a little early on the 98 Ron map, around 5200rpm? I'm undecided if I should just run the 95 Ron map in the longer term or add ethanol on the 98 Ron. This car is my daily driver and I'm not sure if I want to be adding an extra £15 per tank when the benefit isn't actually that much?
There was an M140i there too with the exact same MHD map, same fuel, same TU HPFP but had a 4.5" decat, rather than 200 cell. His peak power was 456 bhp. His graph looked identical to mine in every way. I have seen his logs too and they are very similar, albeit with slightly worse timing corrections.
Dyno chart is flywheel figures.
https://datazap.me/u/simonocr/2024-0...og=0&data=3-17
https://datazap.me/u/simonocr/2024-0...0&data=3-17-43
IMS-340C454.50
      05-19-2024, 11:24 PM   #4229
Aplatosz
Drives: 2018 BMW 340i Xdrive
Hey y’all, in the middle of tuning my 340i right now, car is on a ds25 and e50 mix, how’s this log look to y’all?
https://bootmod3.net/log?id=664abdced333f04fe73d5dad
      05-20-2024, 01:49 AM   #4230
BMW335l
I have now reflashed stage 2. This time BM3 asked me to download stage 1 map before flashing, which didn't happen before. I also set all the settings to OEM or otherwise without leaving them on "choose".
The log looks a bit better, but I think the power is still down. Do I have to high expectaions or are the timings actually low?
https://www.bootmod3.net/log?id=664a...2aed60cedf4296
      05-21-2024, 01:06 PM   #4231
IMS-340C
IMS-340C's Avatar
Egypt
455
Drives: Self Tuned 340i 8AT RWD
Thanks for the info very useful, both logs say HPFP 98 as there is no HPFP 95 map in existence but surprisingly the 2 maps produce totally different boost levels.
The 2nd log with higher boost doesn't look too good I recommend adding ethanol to fix it.
Did you take that log while the car was on the dyno ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT
https://datazap.me/u/ims/e20max?log=0&data=4-19-29
      05-21-2024, 04:23 PM   #4232
SimonO
Drives: 340i
It is confusing, but MHD did recently advise me that the Stage 2 HPFP 95 Ron map is basically just a Stage 2. It is an option within the Multi-map flash section.
Yes, both logs were taken on the dyno - the 2nd log may have suffered due to increased IATs. I'm going to try another log on the road this week.
Thanks for the advice - I need to go down the rabbit hole on octane booster vs ethanol
      05-21-2024, 05:39 PM   #4233
IMS-340C
IMS-340C's Avatar
Egypt
455
Yeah this explains it though confusing as Stage 2 95 is not a HPFP map.
The logs also show the importance of ignition timing, 15.3 psi / 11.5 degrees almost equal same power as 17.3 psi / 9 degrees.
I would definitely go the Ethanol route.
      05-23-2024, 04:05 PM   #4234
BMW335l
I flashed Stage 2+, the car feels really slow. I have no knock and barely any corrections.
The timings look really low, while boost pressure is quite high. Is this normal?
https://www.bootmod3.net/log?id=664c...2aed60cedf6f78
https://www.bootmod3.net/log?id=664f...27982c5534fb2c
      05-23-2024, 04:52 PM   #4235
IMS-340C
IMS-340C's Avatar
Egypt
455
With warmer weather the DME corrects timing with higher IAT, those type of corrections are not visible in the log.
So yeah it's normal.
      05-24-2024, 01:45 AM   #4236
BMW335l
Thanks!
Make sense, but my iat are fairly low at around 32c or 88f in the top range. That shouldn't really cause any issues right?. Would "sports cooling" help with this or I guess the sensor is located after the air box?
      05-24-2024, 03:45 AM   #4237
IMS-340C
IMS-340C's Avatar
Egypt
455
B58 DME is designed to reduce/correct timing by the following:
- High boost/load above 180% which uses lowest timing.
- IAT/Coolant Temp, IAT above around 30C and Coolant above 110C
- Fuel Octane which is the only correction visible in the logs
Looks like BM3 are using close to stock values for this map so the low timing makes sense.
Yeah you can use sport cooling for engine and it will increase timing but could be on the expense of octane timing corrections, the other sport cooling for intercooler is pretty much useless.
Thanks!
      05-25-2024, 05:07 PM   #4238
Empire087
Empire087's Avatar
Drives: 18 340xi 8at 15.5 CCSB 3500
Need an opinion on how things are looking on my final logs, We are gonna do the final touch up revision, but im getting a number 2 misfire and a 102a22(which i guess we will just tune out) but im noticing a little more corrections on #2 cylinder. Plug looked fine when i inspected it the other day, and its got about 15-16k miles on plugs/coils, and car is at 76k miles. Opinions?
Daw Flowmax + v2.5, fuel it stage 2 hpfp, flex fuel tune.
https://datazap.me/u/empire087/curre...37-38-39-40-42
Well did another log from a dig, and i moved cylinder 1 to 2 and vice versa plugs/coils. Now my number 1 cylinder is misbehaving pretty bad. That must be a bad plug/coil. weird
https://datazap.me/u/empire087/hesit...38-39-40-41-42
      05-26-2024, 12:48 AM   #4239
BMW335l
Great info, thanks!
Any other workaround for this "problem"?
I live in a pretty cold country so regarding temp, it can't be much better even though the summers can be fairly hot at 25c.
      05-26-2024, 01:18 AM   #4240
IMS-340C
IMS-340C's Avatar
Egypt
455
Fairly hot at 25C ? you can switch to an ethanol map like E30 during summer as ethanol is a great resistant to knock which allow tuners to increase timing.
Great info, thanks!
      05-26-2024, 03:04 AM   #4241
BMW335l
Exactly, it's a cold country 😅 That's why I think its strange that I see so low timings for this tune. I'm running the stage 2+ 93 with around E20. Could that be to much E for a 93 tune?
      05-26-2024, 04:03 AM   #4242
IMS-340C
IMS-340C's Avatar
Egypt
455
Here 25C is my cold weather map Gasoline maps are good up to 25% Ethanol so no worries.
As for weather at the end it's all about IAT, the IAT and Coolant Temp. control timing.
Attached is my gasoline table I use, with Ethanol I can considerably reduce the reduction in Timing. Vertical axis is IAT, Horizontal axis is Coolant, Table values are Timing Reduction %.
Example: at IAT 35C and Coolant 100C DME will reduce timing by 38%
Exactly, it's a cold country �� That's why I think its strange that I see so low timings for this tune. I'm running the stage 2+ 93 with around E20. Could that be to much E for a 93 tune?
      05-26-2024, 10:54 AM   #4243
tehchrz
Drives: BMW 440i GC
Hey all,
Any chance you can review my logs please? Car is running MHD Stage 1 98 RON v3.7, stock DP/air filter/etc, just M Performance Exhaust which I believe does nothing performance wise. Spark plugs were changed 1k miles ago as part of regular service.
Lately the low to mid range pick up seems a bit sluggish, no idea if it's just me imagining things. Seems like Cyl1&5 are making a correction, no idea if it's significant enough or not.
https://datazap.me/u/tehchrz/b58-4th...og=0&data=4-23
Thanks in advance!
      05-26-2024, 11:45 AM   #4244
IMS-340C
IMS-340C's Avatar
Egypt
455
Dude you're running Stage 1 RON 102!!
Originally Posted by tehchrz View Post
Hey all,
Thanks in advance!
      05-26-2024, 12:36 PM   #4245
tehchrz
Drives: BMW 440i GC
Okay, clarification: I have a multimap with map 1 = RON 102 (which I don't use), map 2 = RON 98 (which is what I used here and use daily), map 3 = RON 98 + burbles when feeling silly and map 4 I don't use at all.
If you click on "current map" you'll see a value of 2.
      05-26-2024, 12:55 PM   #4246
IMS-340C
IMS-340C's Avatar
Egypt
455
OK corrections at top end are worrying.
Run Stage 1 RON 95 and post log.
