05-27-2024, 12:15 AM | #4247 | |
Rep 70
So you think that BM3 uses stock values for behind the scenes corrections? Feels like every other person running bm3 should have this issue then. Bm3 have the option for sports cooling, but I dont know if thats the intercooler or engine. My preference would be to run engine sport cooling only in sport+. Do you think I need new Coolant? https://www.bootmod3.net/log?id=6653...c70e1310e85f3a https://www.bootmod3.net/log?id=6653...6b8c3377f6bf24 https://www.bootmod3.net/log?id=6653...c70e1310e85f13 The logs seem to look okay though. |
05-28-2024, 04:21 PM | #4248 | |
Rep 1,181
It's not an issue, the DME is doing what it is designed to do, with higher IAT DME increase boost and decrease timing.
And since you have minor corrections means you can't increase timing anyway unless you reduce boost, you can't have both. If you still want more timing then switch to an Ethanol Map. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
05-29-2024, 01:11 PM | #4249 | |
Rep 70
I opened up the Coolant tanks. I actually had pretty low levels, especially in the smaller one. Have ordered new caps. I guess it's the same Coolant fluid in both tanks? |
06-06-2024, 02:11 AM | #4250 |
Rep 3
Hello, im a happy owner of a 340i for 15k km already.
Ordered the car from auction in USA after a collision. Car came tuned with added boost, little bit of valve lift, stronger pops and retarded ignition, I guess they do that because in USA the fuel is worse or they have already saw the problem im meeting right now. On this same tune ive added ignition back to stock but the car cant seem to work with it. I'm only running E98 Neste fuel which seems to be the best one we can get here in Baltic States. Haven't tried to add Ethanol into the mix yet. I've done a log with a few most necceseary parameters for best log frequency. Car corrects ignition on cyl1 strongly, on cyl2 a bit, when switched to 5th gear cyl1 and cyl4... All knock detection maps are stock. https://datazap.me/u/reinis/340i-tun...9-10-11&solo=1 Spark plugs new NGK, compression same in all cylinders 14bar if my tool shows correctly. I had a bad waterpump (bearing) and it could vibrate but that is also new OE BMW. If there is anyone with some suggestions about the tune i'd be ready to pay for information! Edit: I have done more research since im starting to hear some weird sounds from head once in a while. I guess i might have a cracked cam ledge? ...if so, why does some misfires happen in cylinder 4? Last edited by reinis; 06-07-2024 at 02:13 AM.. |
06-08-2024, 04:26 PM | #4251 |
Rep 38
Hello again,
I installed today HPFP TU and flash to Multimap Stage 2 HPFP 98RON (fuel RON100) Can you take a look at what it looks like? https://datazap.me/u/black340i/hpfp-...og=0&data=4-23 https://datazap.me/u/black340i/hpfp-...og=0&data=4-23 |
06-09-2024, 03:54 AM | #4252 | |
Rep 1,181
It's not too bad but not great as this HPFP tune has too much mid RPM boost, better switch to Stage 2 RON98 map and if you have access to Ethanol and want to take advantage of the TU pump give HPFP E40 map a try.
+ If Ethanol is too costly where you live you can run HPFP RON98 map and adding 5 liters of Ethanol or HPFP RON102 map and adding 10 liters of Ethanol. Quote:
Michalt3.00 |
06-09-2024, 04:26 AM | #4253 | |
Rep 38
Should I make mixtures with 98 or 100ron fuel? 5 liters ethanol give me mix ~e14 and 10 liters give ~ e23 yes? |
06-09-2024, 04:39 AM | #4254 |
Rep 3,997
You can run the TU HPFP on any map without problems, but unless you run RON 102 or E maps, you won’t see any benefits. (Very limited gains on RON 98, Stage 2+).
Most people use RON 98 as base fuel for E mixes. Math 3rd grade: 5 L in a 60 L tank = 8% (E8) … You get bonus points if you guess how many %E 10L would give you 😉
Michalt3.00 |
06-09-2024, 05:13 AM | #4255 | |
Rep 38
Yours 10l gives e16 But does this take into account that 98 fuel already has e5 in it? |
06-09-2024, 05:19 AM | #4256 |
Rep 3,997
No it doesn’t and not every 98 has E in it! They always write min E5 as this gives them legal freedom to have traces of E. In some countries they do in fact have some, in others - not. You need to measure for yourself to know for sure. Here 98 has zero E, 95 has about 3% E. The one is labelled E5, the other either E5 or E10.
Either way- don’t forget that E in the pump fuel is NOT on top of the octane rating but used to achieve the labelled octane rating. The less E in pump fuel you have - the better. So forget about any E in the fuel itself - calculate assuming there isn’t any. That’s more conservative.
Michalt3.00 |
06-09-2024, 05:25 AM | #4257 |
Rep 1,181
Stage 2 HPFP RON98 and RON102 maps on RON98/RON102 fuel are useless in my opinion as with the increased boost most likely you will end up with timing corrections, they only run well if you mix them with Ethanol.
MHD should replace them with HPFP E10 and E20 maps You can mix Ethanol with RON98 no problem. 340i's fuel tank is 55 liters so as Skyhigh said: 5 liters Ethanol mixed with 50 liters of Petrol = E9.1 10 liters = E18
Michalt3.00 |
06-09-2024, 05:29 AM | #4258 |
Rep 3,997
Stage 2 HPFP RON 102 is great! runs fine and deliveres noticeable torque and power increases. Love that map - to me it subjectively performs better than E40.
I doubt that 340i’s tank is smaller than 440i’s tank, which is 60L (although the gauge only measures up to 55).
Michalt3.00 |
06-09-2024, 05:48 AM | #4260 |
Rep 1,181
Yeah 5 liters E > HPFP RON98 map, 10 liters E > HPFP RON102 map.
Michalt3.00 |
06-11-2024, 06:44 AM | #4261 | |
Rep 1,181
Hey Sky long time Are you comparing to Stage 2 RON98 or Stage 2 RON102 map ?
On pure RON98 fuel B58 Gen 1 hits Octane limit before HPFP limit, I.E. you will get timing corrections before Fuel pressure dips in the log that's why an upgraded HPFP will not make a difference. Do you have a log for HPFP RON102 map ? Also I am curious if you logged HPFP RON102 map on RON102 fuel and Stock HPFP ? + From your findings on RON102 Stock HPFP reaches it's limit before Octane Timing Corrections ? Quote:
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 06-11-2024 at 09:23 AM.. |
06-13-2024, 11:42 AM | #4262 |
Rep 62
Hey guys, first time tuning a B58, I went stage 2 MHD and the car doesnt feel as fast as it should, Details:
2017 340i 6 Speed, originally had MPPSK tune, Car has CTS Turbo high flow downpipe, mst intake with swap in larger K&N Filter, NGK spark plugs gapped to .22, No codes or errors and 65k miles I am in Oregon using 92 octane Heres my logs: https://datazap.me/u/ausmurry/0612-n...og=2&data=4-18 Feels like im getting a decent amount of cylinder correction, especially cyl 1 Thank you |
06-13-2024, 11:59 AM | #4263 |
Rep 3,997
Yep. Heavy corrections!! Don’t drive this setup! You need better (higher octane) fuel for this map!
06-13-2024, 12:49 PM | #4264 |
Rep 62
06-13-2024, 12:54 PM | #4265 |
Rep 3,997
Because the maps are pretty aggressive and fuel is not always up to the advertised octane and quality. This, to a different degree, is the case for 80% of us, why do you think it should be different for you 😜
I’d say, based on what I read in forums and own experience, you need to aim for pump fuel with at least 2 octanes higher than the map you run in order to have a good chance of smooth/decent logs. If you have access to E85 - that’s your easiest solution.
06-13-2024, 12:55 PM | #4266 | |
Rep 62
06-13-2024, 12:57 PM | #4267 |
Rep 3,997
You do not need to go that high. Try 10% E85 first and see what the logs say. Trial-error approach.
Ausmurry25.50 |
06-14-2024, 05:09 AM | #4268 | |
Rep 1,181
Tune is not too aggressive it's producing only 16.5 psi at 6500 RPM and timing is not aggressive either.
Problem is fuel is crap, add 10 liters of E85 and you'll be good and maybe you can even run Stage 2 93 OCT. My problem with this map it produces high boost a mid-range and low boost at high RPM, I prefer the other way round. Quote:
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 06-14-2024 at 05:25 AM.. |
