06-07-2017, 07:22 AM | #23 |
Rep 2,152
i paid £150 delivered from BMW. we worth the investment. not sure on fitting my mate fitted it for free
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
06-22-2017, 03:00 PM | #24 |
Rep 541
So how much is involved in fitting the rear ARB? Do you nee to remove both wheels or can it be done from underneath on ramps?
06-22-2017, 03:12 PM | #25 | |
Rep 19,982
06-22-2017, 04:08 PM | #26 |
Rep 541
06-22-2017, 04:32 PM | #27 |
Rep 19,982
Not sure that'd work I'm afraid.
06-22-2017, 05:15 PM | #28 |
Rep 8,524
AFAIK the chassis needs to be fully supported and the entire suspension assemblies and rear sub-frame lowered from the vehicle. Having the vehicle on ramps won't allow you to do that.
06-22-2017, 05:47 PM | #29 | |
Rep 9,708
Both wheels removed. Rear subframe bolts loosened but not removed. Front subframe bolts and subframe lock brackets removed. Drop diff supporting jack to allow access to roll bar brackets either side, then slide roll bar out. Reverse to re-assemble. |
06-23-2017, 02:37 AM | #31 |
Rep 2,152
10-18-2023, 10:19 AM | #32 |
2015
Rep 2,195
Is the M135i rear ARB the one to go for on a RWD F31 touring? I'm wanting to upgrade the weedy one on my F31 when I do the suspension overhaul etc
10-19-2023, 02:50 AM | #33 |
Rep 1,124
Seems that way. A nice sensible size upgrade for a road car, and OEM fitment and quality
Every time I've fitted the big boy Eibach, Whiteline or H&R kits, to ANY of my previous cars, the ride quality got trashed.....as the guys explained on page 1. So they are staying well clear of my F30 |
danb19792015.00 |
10-19-2023, 03:39 AM | #34 | |
2015
Rep 2,195
Fitted the E39 M5 rear ARB to my E39 touring and that really. helped the ride & handling (along with new SLS Arnott SLS bags and Sachs Sport spec shocks etc) That's what I'm aiming for re my F31
10-19-2023, 06:33 AM | #35 | |
Rep 1,124
Is the M135i front bar bigger than the F30 M Sport's as well? Might be worth doing as I find ARBs work better in pairs, otherwise the car can feel unbalanced like it's a table with a shorter leg at one corner. OEM bars are usually hollow (if that's even possible on such a weedy 12mm one, lol) whereas the Eibachs et al are big solid lumps of pig iron and weigh a ton, which all adds to the mass the dampers have to control, as well as the additional spring rate when the opposite wheel is unloaded. I hate arbs tbh, I think the active ones in Range Rovers, big Audis etc are far superior, but us lowly F3Xers can't have em' |
10-19-2023, 06:36 AM | #36 | |
2015
Rep 2,195
From my reading the F31s are similar; the rear ARB makes a big difference Not sure re the F30s etc I doubt the rear ARB is hollow; not at the thickness it is; you'd be bending it all the time...
10-19-2023, 06:39 AM | #37 |
2015
Rep 2,195
Is this the correct version from an F20 135i?
https://www.realoem.com/bmw/enUS/sho...diagId=33_1612 Pt number 1
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 Last edited by danb1979; 10-19-2023 at 08:52 AM.. |
10-19-2023, 08:52 AM | #39 |
2015
Rep 2,195
It is; I put up the wrong link
Amended
10-19-2023, 10:22 AM | #41 | |
2015
Rep 2,195
The E39 non M5s all got the 12/14mm rear ARBs; never knew why. The M5 16.5mm one was a superb upgrade It would have made a lot of sense on E39 Sport Tourings due to the SLS system etc When I fitted it, it reduced the roll that was left over and the car felt so much more planted Added the 15mm F20 135i rear ARB to my parts list; same with the necessary poly bushes The list is growing My pals popping round tomorrow with his F31 320D; he's having the B4 shocks and Eibach pro kit springs fitted as I type this; it'll get a full fast road set up in the morning as they've had some bad luck with a few bolts that have snapped/needed to be drilled out etc... Always the way I'll be soaking all mine in Wurth Rost Off Ice well before it goes in to get all the bits fitted!
10-19-2023, 01:09 PM | #42 |
Old Fart
369
Rep 697
15mm on the 140i as well. I got one for £45 on eBay and when I need something doing on the rear it'll be going on. Oh, and judging by it's weight there's no way it's hollow.
The doctors said it's OK to listen to the voices..... just don't do what they tell me
danb19792015.00 |
10-20-2023, 02:58 AM | #43 | |
Rep 1,124
Yeah I guess at 12-15mm, it's too thin for some hollow action. And also, in VAG world, the hollow ones tend to be weird diameters, like 15.7mm or something. Not sure of the advantages of hollow ones tbh, other than less material, so less cost And less weight.
Anyway, looking forward to your feedback on the rear arb and on your mate's upcoming upgrades |
10-20-2023, 03:15 AM | #44 | |
2015
Rep 2,195
Still think the ARB will make the best upgrade in terms of handling and reducing body roll etc
