08-14-2023, 02:36 PM | #23 | |
Rep 559
08-14-2023, 03:19 PM | #24 | |
Rep 957
The Track pack (as well as other option combos like M Sport aero with M sport brakes) adds the ‘second’ aux radiator, the outboard one opposite the oil cooler. |
08-14-2023, 04:23 PM | #25 | |
Rep 3,990
I replaced most of the coolant system hoses in my 2014 M Sport 335i RWD. So the radiator that sits over the main radiator should be part of the coolant system, but if I remember correctly, it's plumbed to the liquid to liquid heat exchanger for the ZF 8HP. |
rlesko273.50 |
08-14-2023, 05:20 PM | #26 | |
Rep 957
Lol, maybe now I’m confused too. Maybe they were including the remote auxiliary oil cooler in that diagram, like Jeremy thought… but why then leave out this added #13 cooler if they distinguished between AT/6MT variants..? |
08-14-2023, 05:35 PM | #27 | |
Rep 4,969
Polo088161626.50 |
08-14-2023, 06:14 PM | #28 | ||
Rep 3,990
I had to write an entire email to CSF to explain the differences for their fitment suggestions. |
08-14-2023, 06:18 PM | #29 |
Rep 559
Would the trans cooler be an 'easy' retrofit, then?
08-14-2023, 08:11 PM | #30 | |
Rep 7,733
08-14-2023, 08:44 PM | #31 |
Rep 3,990
Hard to tell. It's never easy adding a whole bunch of shit to a tight fitting BMW engine bay.
What makes newer BMW so challenging is you can't quite see everything immediately. It requires layers of reconnaissance to confirm stuff. That's why the good ole days of just standing inside the engine bay with an naturally aspirated domestic V8 are over lol. |
rlesko273.50 |
08-14-2023, 08:55 PM | #32 | |
Rep 10,545
M-Sport. 2015, 9/14 build.
"Drive more, worry less. "
08-14-2023, 09:00 PM | #33 | |
Rep 10,545
I agree the same set up and I don't have the THP but my car is a 2015.
08-15-2023, 05:17 AM | #34 |
Rep 1,182
Drives: 2015 BMW 435i Xdrive MSport
I'll probably just forego adding this extra cooler. Too much work and not enough info.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
Polo088161626.50 |
08-15-2023, 06:50 AM | #35 |
Rep 559
08-15-2023, 07:03 AM | #36 |
Rep 1,182
Hahaha. My worry is electrical harness' that I'm not seeing. Adding such is a pain.
08-15-2023, 08:49 AM | #37 |
Rep 957
So here’s the N55 cooling system diagram, marked up to what I now understand about the cooling system variants, particularly the remote oil cooler #2 and the auxiliary radiator #15 (after wading into it a lot deeper, ha!).
Leaving the auto trans cooling stuff out for now (which also varies with M Sport Pkg/M Brakes). Also, going back to Phil’s original Q - I added a pic of the parallel flow auxiliary radiator hookup. Maybe it’s not that many new hoses and replacement connections to splice in..? |
Boostedphil698467.50 rlesko273.50 |
08-15-2023, 08:55 AM | #38 | |
Rep 1,182
08-15-2023, 09:59 AM | #39 | |
Rep 559
I also realize the auxiliary engine oil cooler I have on my N55 could be because of S823 Hot-climate version, and nothing to do with the engine. With regards the auxiliary radiator, it does look rather simple from your diagrams. I wonder what is the need for the auxiliary pump, then? |
08-15-2023, 10:30 AM | #40 | |
Rep 957
I have found NO ‘auxiliary pump’ cited in any of my research. Just the belt-driven water pump and the single electric pump. Maybe folks are confusing the oil-to-coolant heat exchanger (#9) with being an extra pump? |
rlesko273.50 |
08-15-2023, 11:10 AM | #41 | ||
Rep 3,990
https://www.realoem.com/bmw/enUS/sho...diagId=17_0675 It's #19. If you removed the coolant expansion tank, it's mounted in the vicinity of the coolant thermostat behind the passenger side headlight. |
08-15-2023, 11:11 AM | #42 | |
Rep 7,733
AFAIK there is an aux water pump if you have the aux radiator, and i thought there were actually 2 electric water pumps and nothing belt driven. |
08-15-2023, 11:13 AM | #43 | |
Rep 3,990
(Forgive me, I'm trying to remember exactly what I did over 2 years ago when I overhauled my cooling system. I will say that the BMW parts diagrams are confusing enough that I did a parts cannon order for all the components listed in RealOEM and returned what I did not use or need for my configuration). |
08-15-2023, 11:15 AM | #44 | |
Rep 3,990
