05-10-2022, 03:17 AM | #23 | |
Rep 1,181
Interesting, Funny I am going the complete opposite direction
So did you compare speedometer with GPS ? Also how much slower is the car now ? My 340i RWD 8AT's VIN says I can run either 2.81 or 3.15 (attached) 3.15 Diffs are selling as low as $150 on ebay, if it works it would be the best performance upgrade for a very little cost. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 05-10-2022 at 12:13 PM.. |
mike082802124.00 |
05-10-2022, 02:57 PM | #24 |
Rep 9
Car doesn't seem any slower at all. No reason for it to be slower; HP is still the same and I spend more time in the power band now.
First gear was already too short for the b58 on the stock turbo. Last edited by RumDomRum; 05-10-2022 at 03:05 PM.. |
05-10-2022, 03:00 PM | #25 | |
Rep 9
There's no reason for the speedo to change. The wheel speed sensors are based on revolutions of the tires per mile, not the transmission. Most cars stopped using the transmission for vehicle speed over a decade ago. |
WolfGTI737.00 |
05-10-2022, 03:02 PM | #26 | |
Rep 9
I really dislike 5th and 6th in this trans. After the supra comes out with their manual, if the ratios are better, I will go to those. If they are not better, I'll design a new 5th and 6th to put in the case. |
IMS-340C454.50 |
05-10-2022, 03:08 PM | #27 |
Rep 1,181
If the sensor is on the transmission any point before the diff speedo will not change but if it's on the tyres the tyres rotate at a different speed so it will cover different miles.
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
05-10-2022, 06:27 PM | #28 |
Rep 9
wow, it's almost like that's exactly what I said.... but backwards. You're very confused.
05-11-2022, 07:00 AM | #29 |
Rep 1,181
Actually when I thought about it yes any readings before the diff will not be accurate.
05-11-2022, 08:25 PM | #30 |
Rep 9
WrxToBeamerGuy517.50 mike082802124.00 |
05-13-2022, 12:05 PM | #31 |
Rep 1,181
Anybody know what's the difference between Rear Axle Drive and Exchange Final Drive ?
06-07-2022, 11:42 AM | #32 |
Rep 1,181
Bought a used 3.15 rear diff, since almost the whole rear axle will be disassembled what other parts do you guys recommend changing ?
Car has 40K miles - 60K Kms Thanks
07-05-2022, 09:12 PM | #34 |
Rep 971
Found this setting in Bm3.
07-06-2022, 12:10 AM | #36 |
Rep 1,181
Confusing indeed I wonder what happens in the tune when you change this table.
11-13-2022, 08:17 AM | #37 |
Rep 1,021
Any updates on how everything is working? Cruise control still works? Do you notice much of a difference with the 2.81 in your manual car? I find first and second gear almost useless in the 6mt especially with an upgraded turbo.
Atom Ant3.00 |
06-07-2023, 08:13 AM | #38 |
Rep 5,801
Just to update this thread…
I read a few comments that stated that BMW did not make an M Performance LSD for XDrive models. That is not actually true. When BMW was designing the F30 MP LSD probably around the 2011-2012 timeframe, it was an expensive aftermarket part, around $3,000 including installation. BMW assumed that it’s target market would be guys with F30 RWD, enthusiasts who track their cars. At the time BMW German engineers couldn’t imagine XDrive owners tracking their cars. So the compatibility lists and MP LSD literature only listed RWD cars with either manual or automatic transmissions because their final drive ratios are different based on transmission. The XDrive cars were using the exact same stock rear differentials with the same rear final drive ratios as the RWD cars. So the MP LSD just swaps right in and works on XDrive. It’s just that the MP LSD literature written in 2012 doesn’t say anything about XDrive. Many people don’t see XDrive listed in MP LSD literature and immediately say that BMW doesn’t make an LSD for XDrive, which is incorrect. To create an XDrive car, BMW essentially takes a RWD model and adds a bunch of XDrive components like front differential, transfer case, front wheel drive shafts and much more. Part differences between RWD and XDrive happen in the front half of the car. The back half of RWD and XDrive cars are close to 100% identical. I haven’t run across a difference. UPDATE: BMW is known to sometimes do unexpected things. Always verify part numbers and specs on your own car using realoem and other resources. My car is an F30 335i XDrive Automatic. |
B58 parts527.50 |
06-07-2023, 10:30 AM | #39 | |
Rep 28
RWD 6 cylinder 225kw diff AWD 6 cylinder 181kw diff RWD 4 cylinder 181kw diff Why did you make up that elaborate story |
06-08-2023, 09:23 AM | #41 | |
Rep 5,801
06-09-2023, 07:57 PM | #42 | |
Rep 1,117
Just because the LSD worked on the RWD or the AWD in the N55, doesn’t mean it will in the B58 models. You are about to lead someone to make an expensive mistake. |
06-11-2023, 08:04 AM | #43 |
Rep 5,801
Wasn’t posting to any subgroup. When the application lists New Posts to read it provides all 2012-2019 3&4 Series without identifying any subgroup where a post may have originated. That’s why I added more specific details.
