04-19-2023, 07:59 PM | #23 | |
Rep 7,733
04-19-2023, 08:12 PM | #24 |
Rep 32
I haven’t really played with the flash options, but do you think it was heatsoak on the previous logs? Or are there no signs of it?
04-20-2023, 10:31 AM | #25 |
Rep 7,733
No. IATs at less than 100F, and heat soak isnt going to do that. There's very clearly a torque limit issue when the boost target is low
01-12-2024, 02:33 PM | #26 |
Rep 1
Hello, i own 440X Drive, i have the same exact issue, every time i floor it power is ok. but after 5.5k rpm there is power leak. Did you fix it? If you did, please reply, i'm looking for solution
01-12-2024, 08:17 PM | #27 |
Rep 7,733
01-15-2024, 08:29 PM | #28 |
Rep 32
It kinda just went away, I switched gas stations and made sure the octane and ethanol content is correct. I haven’t had that problem since. One time I anti-lagged tho and the car cut power. My “solution” was good fuel and no anti lag😂
