BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > f30 Xenon to full LED headlight conversion (non adaptive) vertical aim issue
      05-04-2023, 02:37 PM   #23
TheNine90
Drives: bmw
It seems since you have not coded adaptive the lights wont move.
Check fa and make sure you have correct configuration remove xenon and add adaptive LED. Then try to code.
      05-04-2023, 04:59 PM   #24
rVito
Drives: bmw f30 335i
but they are not adaptive, just basic ones..Do I still need to code them as adaptive..?
      05-04-2023, 05:02 PM   #25
rVito
these are mine
      05-04-2023, 05:15 PM   #26
TheNine90
Drives: bmw
Then jsut code as led only
      05-07-2023, 06:30 PM   #27
rVito
In another post Ive found out SA code for adaptive led headlights is 552.. Then whats the SA code for NON adaptive LED headlights?
      05-07-2023, 11:26 PM   #28
TheNine90
Drives: bmw
5A2 LED headlight
rVito5.50
      05-08-2023, 07:14 AM   #29
rVito
5A2 LED headlight
Thank you! Finally they work perfectly without errors. I was racking my brain on why they worked well externally but I had adaptive lights errors
FEM still produces these errors, probably because of 0318 time criteria, but nothing to loose sleep over:
      05-08-2023, 09:48 AM   #30
TheNine90
Drives: bmw
UGDO OFF
If car car has manuel lwr
MLC_Enable on
Flc_enaxxx off
Lwr_ahl_type manuel
For MFL
LIN_VARIANTE_MFL (Change according to vehicle MFL)
For BEL
LCE_BEL_LIN_VAR
      05-05-2024, 07:33 AM   #31
F30MC
Drives: BMW F30
Hello, i need help about wiring. I upgrade from pre lci xenon to lci led(non adaptive).
What wiring needs to be done? Do i have to put new wires or just re pin the original conector?
Thanks in advance!
