02-12-2020, 12:13 PM | #23 | |
Rep 2,181
The only F30 with NBT in MY2013 was the 335i ActiveHybrid 3. If yours is not AH3 then the OEM HU is CIC.
Regardless, this adapter seems to pass thru the OEM display of the CIC, which means that it is the CIC adapter and compatible with the CIC display. An NBT adapter will not pass thru the OEM display of a CIC. The problem seems to be the CarPlay display output not working/not passing thru. Quote:
x-m4n145.50 |
02-12-2020, 02:21 PM | #24 | ||
as long as it runs :)
43
Rep 164
Blank
02-12-2020, 04:27 PM | #25 |
Rep 843
In theory, the NBT should work.
As you connect the current LVDS cable from the back of the screen, into the carplay box, so you don't remove the LVDS cable from the headunit. Your headunit will trigger the carplay box as if it was the screen. Then you run a new cable from the carplay box to the screen. The NBT comes with a new quadlock connector for power etc. |
02-12-2020, 09:59 PM | #26 | ||
43
Rep 164
02-13-2020, 05:00 AM | #27 | |
Rep 843
The carplay box is just a pass-through for everything to the screen, except for when Carplay / AA is being used, at which point it interrupts the video signal to the screen to give the required graphics. |
02-13-2020, 10:51 AM | #28 | ||
43
Rep 164
That and I am afraid that there might be minor differences in the cic quadlock like the backup camera or combox etc, that the nbt patch quadlock for carplay won't work with or wont connect to... also if the CarPlay box is using input from the controller when In CarPlay mode, the cic controller might not communicate properly since the CarPlay box is presumably expecting KCAN2 input... I'm not sure... I am no expert in idrive comparability |
02-13-2020, 11:43 AM | #29 |
Rep 843
I don't know the answer sorry.
If carlinkit has said you need the NBT box, then tell them you will order it, so long as they cover the return costs if it doesn't work. |
02-13-2020, 10:21 PM | #30 |
Rep 8
I am also having this issue, I plan on getting Car Play or Avin USA. would love to get the figured out. look below HIGH-CIC
https://m.imgur.com/a/vCa2mkW |
02-14-2020, 01:58 PM | #31 |
43
Rep 164
Ok I went and tried again to install the cic Carlinkit box in all the different switch combinations and none of them worked, but when I was there I took pictures of the lvds cable going into the headunit to show how the cable for the display is a 6 pin while the headunit uses the 4 pin, lastly I wanted to see if my connector would work with nbt, here are the images:
02-14-2020, 02:28 PM | #32 | |
Rep 2,181
The correct Carlink box for the CIC should be LVDS 4pin input/6pin output. If you are seeing the OEM iDrive display with the Carlinkit box connected then the problem is the CarPlay output through the LVDS 6pin cable (4pin video and 2pin 12V/ground). "No Signal" means that the 12V/ground signals are provided by the Carlinkit box, the 4pin video signal is not. |
02-14-2020, 02:51 PM | #33 |
Rep 8
After looking into this, i believe NBT is the box needed. You will need to take the screen 6PIN, and connect it to the carplay box. Once you do that they Provide you a 6 PIN to 6PIN you take that plug it to the carplay box, and back into the screen. So in theory you never take the 4 PIN out of the head unit. As for the head unit cable it's a 6PIN to 4PIN correct ? 6PIN in screen and 4PIN in head unit ?
02-14-2020, 02:54 PM | #34 | ||
43
Rep 164
02-14-2020, 02:55 PM | #35 | |
43
Rep 164
02-14-2020, 02:57 PM | #36 |
Rep 8
https://ibb.co/hdrdkms
Here is the way it should be wired. |
02-14-2020, 03:07 PM | #37 |
Rep 843
02-14-2020, 03:10 PM | #38 | |
Rep 8
https://car-solutions.com/en/camera-...gh-nbt-system/ |
02-14-2020, 03:50 PM | #39 | ||
43
Rep 164
From the images I assume you disconnect the 6 pin cable from the display and that goes into the new box and the box has its very own 6 pin out to go to the display, and the quadlock is connected to the patch harness for the other controls. |
02-14-2020, 03:56 PM | #40 |
43
Rep 164
Here is the cic box
02-14-2020, 04:04 PM | #41 | |
Rep 843
Yeh the CiC box is completely different to the NBT box. |
02-14-2020, 04:27 PM | #42 | |
Rep 2,181
That means that an NBT box may work as long as the box has 6pin LVDS input (combo 4+2 LVDS cable to 6pin LVDS box input) and output for an extra NBT 6pin LVDS cable (from box to NBT screen). |
02-14-2020, 05:01 PM | #43 | ||
43
Rep 164
02-14-2020, 05:26 PM | #44 |
Rep 843
