01-12-2023, 05:00 PM | #23 | |
Rep 347
01-12-2023, 06:45 PM | #24 |
Rep 346
The inner tail in the pre LCI don’t have the lights that the LCI has right? So I add a wire on each side, run in through the inner panels to the rem and tap them into the wires that powered the outter lights
This way the inner lights will turn on when the outter lights are on |
01-17-2023, 09:32 PM | #25 | |
Rep 347
Also, any advice/steps when doing this on F36, e.g. boot trim removal? |
01-18-2023, 02:24 AM | #26 |
Rep 346
i will take a picture of the REM for you
for the f36, its a pain in the ass...there are too many panels to take off in order to run the wires down to the REM. I ran the wire through the tailgate, pass the rubber boot, to the passenger side trim above the seat and then to the REM my only advice is that you need to be patient because you dont want to break anything other than that just remove all the screws and clips, and take them off one by one... |
11-29-2023, 08:50 AM | #29 |
Rep 3
Question - I installed the lights, but I haven’t run the inner light wire to the REM unit because I don’t have those small connector pins to put in the wire. These are really hard to find, is it possible to just splice into the outer light wire and connect the inner wire directly to the outer wire turn signal?
05-05-2024, 05:25 AM | #31 | |
Rep 45
If we use the OEM retrofit harness there is no need to run additional wires to the REM for inner turn indicators, am I right? Do anyone know which I-Step Level is needed to not add HELC to the FA? Coding is still needed, sure. Thanks in advance! |
05-06-2024, 08:32 AM | #32 | |
Rep 548
https://www.ebay.com/itm/204124442843
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
