BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Cleaning your intake valve's carbon buildup
      01-04-2015, 10:07 AM   #23
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by DrivenByE30 View Post
For those in the US, do you think my dealership would do this task if I ask them before my car turns to 50k
Of course, but it won't be free of charge. They do this work all the time.
      08-02-2019, 09:28 AM   #24
DrivingPassion
DrivingPassion's Avatar
Drives: '15 M235xi
My dealer used to offer walnut blasting for like $1,200 but they stopped it.
Not sure why.
Lately, there are people using CRC GDI turbo valve cleaner. Not sure if that helps
2015 M235i xDrive 8AT
      08-02-2019, 04:21 PM   #25
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Not sure why.
Since the interval for the N55 is somewhere over 100k miles I doubt the dealer gets many inquiries
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      08-02-2019, 05:39 PM   #26
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
They may do it, at a price. To prevent having to face that possibility I installed an oil catch can, and am now using CRC valve cleaner as part of my spring maintenance.
      08-03-2019, 07:43 AM   #27
oceanview
oceanview's Avatar
Switzerland, Swiss Confederation
219
Drives: 335i F31 RWD Autom.
I wonder if it's just kind of snake oil, or if driving with high RPM for a while from time to time could prevent/reduce that problem.
- Engine warm
- drive at highway speed, in a lower gear but higher RPM (above 5'000 RPM) for a few minutes.
So the income valve area get's a higher operating temp that could reduce/burn the junk.
Any idea?
335i F31 RWD in SB (2013) || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around
      08-03-2019, 08:24 AM   #28
Billfitz
Billfitz's Avatar
The source of the carbon build up is fully documented, it's oil that makes it's way from the crankcase to the intake manifold via the PCV. Driving habits have no influence on that. An oil catch can, which should be standard in cars with direct injection, is the best prevention.
      08-03-2019, 09:51 AM   #29
DrivingPassion
Drives: '15 M235xi
- Engine warm
Any idea?
Are you talking about an Italian Tune-up?
Will it work?
Yes and No.
      08-03-2019, 11:06 AM   #30
oceanview
oceanview's Avatar
219
Will it work?
Yes and No.
Well, not "redline". But just keep it over 4500 or so for a while (gasoline, not diesel)
Normal street driving keeps you in the low RPM mostly <2500rpm while driving, not accelarating.
I doubt that this is good for keeping the engine clean.
      08-03-2019, 11:15 AM   #31
Billfitz
Billfitz's Avatar
Will it work?
Yes and No.
Where the intake valves on a direct injection engine are concerned it's a resounding 'No!'. This is especially true with BMW, which runs hotter at low RPM for efficiency, cooler at high RPM to prevent knocking.
      08-03-2019, 12:55 PM   #32
DrivingPassion
Drives: '15 M235xi
That's interesting info.
May I know where you get that from?
      08-03-2019, 02:12 PM   #33
Billfitz
Billfitz's Avatar
It's been posted here many times.
      08-03-2019, 04:50 PM   #34
perryo91
perryo91's Avatar
Uganda
393
Drives: 335
Is that why when I'm on a road trip I see oil temp get pretty much at 250 spot on.. But if I'm driving aggressive in the city I will see oil temp drop almost down to 205?->
Hi
      08-03-2019, 05:29 PM   #35
Billfitz
Billfitz's Avatar
That's why. Pre-ignition can be controlled by retarding the timing, but that also hurts acceleration, so when the car senses that you're driving aggressively it cools the engine to control knocking with minimal, if any, retarding of the ignition timing.
      08-03-2019, 10:27 PM   #36
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Water pump increase the flow of coolant?
I can't remember if there's a thermostat for the oil cooler
      08-04-2019, 03:29 AM   #37
oceanview
oceanview's Avatar
219
Yes, water pump will increase the flow of coolant. That's what the pump is for. (but I guess your question was more an answer)
The higher the rpm of the pump, the more gallons per time will flow.
Thermostat in the oil filter housing
see #09: https://www.realoem.com/bmw/enUS/sho...diagId=11_4465
I see increasing temp of oil, water and cat. temp (exhaust) with higher rpm.
I think I read somewhere, that driving in SPORT/SPORT+ will also increase the oil/engine temp compared of driving in ECO or COMFORT mode.
      08-04-2019, 08:09 AM   #38
Billfitz
Billfitz's Avatar
You have it backwards. The engine would run hotter in ECO or COMFORT for better fuel economy, cooler in SPORT/+ for better acceleration. That's why the concept of the Italian Tune Up is flawed. Forty years ago we called it 'blowing the carbon out', driving at high speed in a low gear for maximum RPM. It may have worked then, long before direct injection and computerized engine heat management, but all it would do today is waste fuel.
      08-04-2019, 04:14 PM   #39
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
IMO the "Italian Tune up" would loosen stuck rings.
      08-05-2019, 06:06 PM   #40
AtlantaDan
Drives: 2017 330i Msport Touring
You can easily handle the walnut blasting on your own. Harbor Freight sells a media blaster for like $50 and you can also get the crushed walnut shells from there as well. $25 for 25 pounds. Hook it to a good compressor, pull the intake off, and go to work. Rotate the engine until the intake valve is closed and the lifter is on the base circle of the cam. (Sounds a lot harder than it is). Blow out the remaining shells with compressed air. Anything that you don't get out will be burned off.
Its far from rocket science. I used to do it to my Focus ST. It took about an hour on a cold engine, and that was with me lollygagging.
