BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: LCI IHKA Climate Control Display Retrofit - IHKA3 Required
      04-15-2017, 08:25 AM   #23
atzebmw
Drives: Tesla Model 3
No further parts are required.
Only change with the old panel and coding.
Works only with IHKA3.
      04-15-2017, 08:47 AM   #24
jtskariah
Bud Light General
jtskariah's Avatar
Drives: M4 CS Limerock Grey
2015 BMW 335i  [10.00]
2019 BMW M4 CS  [10.00]
Ok I have a 2015 335i can I just install the AC unit now and code later (in about a week)? It should work in amber for now right?
      04-15-2017, 08:56 AM   #25
atzebmw
Yes, that should work.
      04-15-2017, 09:33 AM   #26
jtskariah
Bud Light General
jtskariah's Avatar
Perfect just installed. Fow now the light only shines white at all times but all the buttons work and functions as it should. Once I code it next week it should work as intended! Thanks!
      04-18-2017, 08:54 AM   #27
Chas325
Drives: F31 325d MSport
Hi,
I have a F31 manufactured 06/2014 according to RealOEM. Does that mean I have IHKA3 already and it's a straight swap?
I have found 64119363546-02 for a reasonable sum - is that correct for a car with heated seats?
Cheers
      04-18-2017, 09:32 AM   #28
rubber_ducky
rubber_ducky's Avatar
394
Drives: roach coach
Originally Posted by Chasdrury View Post
Hi,
The unit is a straight swap, but until IHKA3 is coded, it'll always illuminate in white.
Cheers
That's the correct unit
      04-18-2017, 09:35 AM   #29
Chas325
Thank you!
      04-28-2017, 05:58 PM   #30
GCinFLA
Originally Posted by atzebmw View Post
Oh yes, i'm sorry. I misunderstood.
The white screen control panel came in 08/2015.
But the retrofit of the new Control Panel should be possible for cars from 03/2014 upwards.
To find a cheap one on eBay you need much luck.
Why could this not be done on a MY 2013?
      04-29-2017, 01:18 AM   #31
GCinFLA
What changed in 3/2014 that only newer cars can change out the AC Control panel and make this work?
      04-29-2017, 01:28 AM   #32
Dante
Enthusiast
Dante's Avatar
Drives: F87 M2 / F31 330d
From 03/2014 the IHKA3 Module is equipped, before it was the IHKA Module. It's not possible to get the new panel to work with IHKA.
Also retrofitting the IHKA3 Module wasn't successful yet.
      04-29-2017, 02:53 AM   #33
GCinFLA
Where is the IHKA/IHKA3 module located in the f30 and what is the part number?
Clearly the IHKA3 module and the AC Panel listed in Post 1 are needed to make this work, so I am trying to grasp where the IHKA3 that was installed starting in 3/2014 is located and it's part number, as I (and others) thought was was in the actual AC Control Panel that one would replace.
Integriertes Heizung und Klima (Integrated Heating and Air Conditioning) sure sounds like it's the front panel. The name if the module has been the same since the 3 series.
Thanks.
      04-29-2017, 06:12 AM   #34
atzebmw
Part numbers for IHKA3 are:
CONTROL UNIT AIR CONDITIONING SYS.
64 11 9 380 883
64 11 9 381 113
64 11 9 390 096
64 11 6 803 168
64 11 6 820 234
64 11 6 840 450
64 11 6 842 985
Only suitable for auxiliary heater
64 11 9 380 896
64 11 9 381 115
64 11 9 390 100
64 11 6 803 170
64 11 6 840 452
64 11 6 842 987
For vehicles with
Automatic air conditioning S534A = Yes
64 11 9 380 885
64 11 9 381 114
64 11 9 390 099
64 11 6 803 169
64 11 6 820 235
64 11 6 840 451
64 11 6 842 986
For vehicles with
64 11 9 380 900
64 11 9 381 116
64 11 9 390 101
64 11 6 803 171
64 11 6 840 453
64 11 6 842 988
The IHKA/IHKA3 is located above and behind the glove box.
GCinFLA303.00
      05-18-2017, 12:11 PM   #35
tamerjammer
United Arab Emirates
Drives: 2017 F33 428i
Need Information
Dear Timbits 93 I have a 2016 F30 with IHKA3 and basic AC controls, I bought the same high AC control panel that you bought with he same part number apart from the amber and white coding, what else do I need to code in order to use the panel correctly
Thanks
      06-20-2017, 07:11 AM   #36
jdr78569
jdr78569's Avatar
217
Drives: F31 328d sport wag
My F31 was built "Prod.date 2014-02-17" Would I be able to add the white control led part? From what I read i should be able to add the piano black bezel since if im correct.
If possible id like to add the white/orange displace on my AC control. I think it looks sharp
Oh my car also has the lighting package code 563.
      08-03-2017, 01:46 PM   #37
PhreakShow
Drives: F31
What will happen if you connect the new controls to the old IHKA (IHKA2)?
Will it not work at all, or just without the new colour changes?
      08-06-2017, 10:10 AM   #38
Dante
Enthusiast
Dante's Avatar
Won't work at all.
      10-12-2017, 05:00 AM   #39
1QuikWS6
No 55mph
1QuikWS6's Avatar
1672
Drives: F32 435ix MSport
Question for OP:
Probably stupid, but how are you switching between amber & white display with this LCI unit?
On my pre-LCI the display is always amber - whether it be day or night, Comfort or Sport mode
      10-12-2017, 04:05 PM   #40
atzebmw
Originally Posted by 1QuikWS6 View Post
Question for OP:
This happens automatically. When it gets dark, it switches to amber. When it is bright again on white.
      10-12-2017, 04:11 PM   #41
1QuikWS6
No 55mph
1QuikWS6's Avatar
1672
Ah, OK - Thanx!
In his video it is dark, yet the display could be switched back and forth between amber/white? That's the part i didn't understand
Sounded like he was throwing some switch in background when it happened
      10-12-2017, 04:23 PM   #42
atzebmw
Ah, OK - Thanx!
Ah yes, you're right.
Maybe he is switching the light switch from automatic to 0 and back.
I did not test it.
      10-14-2017, 12:10 AM   #43
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
Ah, OK - Thanx!
I did not test it.
Yes, just using the light switch to demonstrate the color switching between "daytime" and "nighttime" modes
      10-24-2017, 01:43 PM   #44
1QuikWS6
No 55mph
1QuikWS6's Avatar
1672
Got mine installed today - love the newer look to the display & white/amber switching
My car has BD of 9/14 so correct module already installed - all worx perfectly as it should
>> Curiosity - when I 1st installed the new HVAC, the lighting was switching between amber/white as it should WITHOUT coding Then a couple weeks later, all of a sudden it stopped switching & remained in white, so I had to code. Anyone know why this happened?
I also did NOT notice the display flashing for a couple minutes, as it initialized, as one member stated previously - worked as soon as I plugged it in. Mine was a used unit purchased from forum member, maybe the flashing to initialize only happens with new/never installed units
Thanx to TIM for the info on this!
Dante482.50
