01-30-2017, 12:19 PM | #23 |
Rep 358
The only clear coats that are hard and durable are two pack ones which contain isocyantates and are too poisonous for diy home use.All solvent based clear coats tend to be on the soft side,but you have no alternative really but to use these at home.
Regarding the repair you approached it in the same way as I would have and obviously got good results with perfection not possible under the circumstances. After the lacquer had thoroughly dried (next day) I would have blended the overlap area in by polishing with fine liquid compound which can disguise the join. |
01-30-2017, 12:31 PM | #24 | |
Rep 32,881
01-30-2017, 12:49 PM | #25 | |
Rep 2,376
Current - X3m Comp
Gone but not forgotten - F80 m3 Comp, F30 340i, F30 - 320i |
01-30-2017, 12:51 PM | #26 | ||
Rep 32,881
01-31-2017, 05:45 AM | #29 |
Rep 13,043
Drives: BMW M340I G20
What's the spray pattern like with the E tech. Is it a fine mist?
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
01-31-2017, 05:49 AM | #30 |
Rep 32,881
To be honest it could have been better as i used it at 8° C I should of kept the can indoors so it was above the advised 17° C
01-31-2017, 07:06 AM | #31 |
Rep 13,043
Thanks
01-31-2017, 12:23 PM | #32 |
Rep 331
I have 2 spare front 442Ms that could do with this treatment !
Current: F30 335d xDrive M Sport Plus
18" PZero - 405Ms - ACS Springs - Eibach 16mm ARB - Indigo GT Remap |
08-07-2017, 10:41 PM | #34 |
Rep 7,484
Bump this mother
#weekendgoals |
MashinBenzin8501.50 |
07-04-2018, 06:03 PM | #38 |
Rep 32,881
07-04-2018, 06:14 PM | #39 | |
Fool
1859
Rep 3,542
Actually, just remembered how I found them. They were 'offline' when I wanted to see them but actually they're still online, you just have to change the domain name to match the one they're currently using to serve images.
07-04-2018, 06:22 PM | #40 |
Rep 32,881
10-23-2018, 03:09 PM | #41 |
Rep 235
Apologies for bumping an old thread, just wondering if this is possible without taking the wheel off? I have some fairly deep curbs on my front wheel and will be attempting this shortly once the laquer turns up!
10-23-2018, 03:19 PM | #42 | |
Rep 32,881
I’ve got a nassive kerb rash on one of my wheels that I need to repair when I put my winters on! |
10-23-2018, 04:05 PM | #43 |
Rep 664
good post teaston
I need to do this with my 442M's on the front when i have them off to do the disks and pads. got some lacquer going white after chipping. I did something similar with my previous alloys 403M's. and they looked good. but the lacquer de-bonded after a while. the problem seems to be adhesion of the clear coat straight to metal. pity there's no such thing as a clear primer....
MOD's/DIY list
Bonnet Badge Repacement, LED Door Sills, 35%VLT Window Tinting, 442m alloys, Stainless Steel Pedals, Front and Rear Disk Replacement, GTechniq C1 Detail, Gladen HIFI upgrade, LED DRL's, 90mm Stainless Tailpipe, Complete Leather Reupholstery. |
10-23-2018, 04:10 PM | #44 | |
Rep 32,881
Auto Inpart Clear Gloss E-TECH Alloy Wheel Lacquer Chip resistant Wheel refurb https://www.amazon.co.uk/dp/B0079Z6M..._D44ZBb5F8SCH7 |
