10-20-2020, 02:35 AM | #23 |
Rep 93
10-20-2020, 02:48 AM | #24 |
Rep 93
The installed plugs are Stock and ungapped (New). I found that when driving on comfort mode/manual (sport transmission map) , the car accelerates smoothly even on low throttle. I concluded from this test drive is that, vibration occurs only below 2000 RPM - low throttle.
10-20-2020, 03:51 AM | #25 | |
Rep 2,409
(A Dane in China) |
10-20-2020, 11:28 AM | #26 | |
Rep 7,733
10-20-2020, 12:48 PM | #27 |
Rep 93
Much appreciated for your support Harkes. All main hardware has been checked and they're are in good condition and tight. The car has a mileage of 40,000 miles. DP and CP are fine. No boost leak. Pumped the car with 91 and 93 octane and still no improvement.
10-20-2020, 12:50 PM | #28 | |
Rep 93
10-20-2020, 01:02 PM | #29 |
Rep 93
Logs comparison between Stage 1/91 (V6.4),(V7.1),(ACN91-V7.1) and New OTS map
So guys, here are some of the logs taken for the mentioned map versions. Actually, i couldn't find a major issue that could be related to the high vibration/stumbling during low throttle. Maybe some of you could point out something
Stage 1/91 (V6.4, V7.1 & ACN91-V7.1): https://datazap.me/u/wiz992/bm3n55-e...1?log=2&data=6 Stage 1/91 - New OTS map: https://datazap.me/u/wiz992/bm3ewg-n...p?log=0&data=6 Thanks |
10-20-2020, 01:38 PM | #30 | |
Rep 7,733
I glanced through and the main thing i noticed is that the ACN log overboosts almost the entire pull whereas the others do not, but i doubt thats related to your issue. |
10-20-2020, 03:53 PM | #31 | |
Rep 93
True, I've noticed too. In (V6.2) which runs smooth there was something about (Acceleration at low RPM issue fix) i don't know if it's related to this. https://ibb.co/YPnFxQS Last edited by DarkWhisper; 10-20-2020 at 04:13 PM.. |
