| 01-22-2019, 08:48 AM | #23 |
![]() 2253
Rep 4,376
If (and only IF) it was a stock feature to be able to disable the AWD on demand, I would pay for that option and I am sure I would enjoy playing occasionally with RWD only.
I would however not jeopardise both car health and safety by an aftermarket product. As others have written already - I bought X-Drive for a reason. RWD was never an option.
1QuikWS61671.50 |
| 01-22-2019, 08:55 AM | #24 | ||
![]() ![]() ![]() 6589
Rep 15,857
They simply recognise they can fail, (as we all know they can and do), and then state 'delete' allows you to drive without repair. Quote:
| 01-22-2019, 09:16 AM | #25 |
![]() ![]() ![]() 155
Rep 407
I'm getting mixed feelings from this - at first it sounded like a nice to have but anything involving the transfer case scares the bejesus out of me
Current:
22' G31 520D XDrive Previous: 16' X253 AMG GLC 43 13' F30 330D XDrive |
| 01-22-2019, 09:23 AM | #26 |
Rep 141
I think it would be something neat to use ans mess around with in a parking lot for 10 minutes but nothing I would leave on for a length of time until there are proven long term tests that show it's safe.
| 01-22-2019, 09:38 AM | #27 |
Rep 14
You can pull the fuse on any i xdrive bmw to disable the transfer case and make it RWD, however it’s not a quick and handy process and it lights up your dash like a christmas tree. We use to do it when we dyno’d our car.
Having this feature on the fly, for a mere $150, sounds pretty good to me. Burnout fun, dyno fun, winter parking lot fun. Why not? The i xdrive cars are basically RWD, with an AWD tc component installed. Guy is a genius for figuring this coding out actually 👍🏼 |
| 01-22-2019, 10:03 AM | #28 |
Cheapskate
4786
Rep 5,029
Gotcha. I mean it's pretty common especially if its peoples daily drivers, but I guess I understand the reservations. I just know like in the case where I've snapped an axle, it would be nice to at least limp my car home instead of waiting an hour for AAA.
| 01-22-2019, 10:52 AM | #29 |
Rep 166
I have X-Drive, and with the current split, I can get the back out in the snow. It's a nice predictable drift out. I like X-Drive, and do not notice the 'Under Steery' aspect.
Perry
2015 328i X-Drive, M-Sport, Cold Weather Pkg, Lighting Pkg, Premium Pkg, Harman Kardon, Black Grilles, Hands-Free, M-Perfomance side sills, X-Drive floor liners. |
| 01-22-2019, 01:08 PM | #30 |
![]() 1013
Rep 1,934
Xdrive isn't permanent. It's an add on to BMWS rwd config. The transfer case controls when and how much power goes to the front axles in certain conditions. xHP simply modifies this algorithm, the same way BM3 and others modify your DME tune. If you can trust aftermarket tuners you shouldn't have problems with this.
In layman's terms you will just be removing the transfer cases recognition of said scenarios it would engage it's clutch and send power to the front. Leaving the clutch disengaged for long periods of time will not increase wear. It's not being used. This will INCREASE the tranfer case's lifespan as its being used LESS. Simple logic. This is exactly how it is done in the new Ms, albeit they likely have beefier transfer cases for the torquier engines. Anyone who purchases xdrive does it because they value power to all four wheels more than the better driving dynamics of a rwd config. If you could have both, some of you would have added the option at factory. Give BMW time and this tech will tickle down to all of their models. F90 M5 now, G80 M3 next, everyone later likely
| 01-22-2019, 04:06 PM | #31 |
![]() ![]() ![]() 217
Rep 518
Don't crucify me, but I think it would be cool, too, if there was an option to add a "snow mode" that puts a little more power to the front wheels (or maybe forces a 50/50 split, front to rear). I noticed when hooning in the snow that more power goes to the rear wheels with xdrive -- which is FUN -- but xdrive doesn't "pull" you out of oversteer conditions when you're heavy on the gas -- due to the RWD bias. Again, the ONLY time I would want this is for snowy conditions -- to have the car pull me through, rather than push. In dry conditions, I prefer the RWD bias.
| 01-22-2019, 10:46 PM | #32 | |
Vault Dweller
867
Rep 608
| 01-23-2019, 08:52 AM | #33 |
Rep 118
This is interesting, seems like there is mixed feelings about it. I think it would be cool to have for the occasional parking lot drifting, burnouts, mountain driving drifts, snow fun, etc. but would most likely leave xDrive enabled for the majority of the time, and only disable it for the fun times. I think I will wait it out and get a feeler for how others with F chasis report with it.
| 03-01-2019, 05:52 AM | #35 |
Rep 308
+ 6sp manual!
2017 F31 328d xDrive
M Sport M Performance |
| 03-01-2019, 07:05 AM | #36 |
Rep 6,191
With some aggressive throttle, I have no issues doing controlled slides with x-drive. I do get a bit of understeer on corners, but there is a lot of body roll at the front which could be fixed with upgraded sways.
So once this mod is done, you basically have a 1WD car? I don't know of any LSD options for the x-drive (might be wrong, but haven't seen any). |
| 03-01-2019, 07:48 AM | #37 |
![]() 99
Rep 227
Drives: 2000 BMW E39 M5
I know right?!? I've researched the hell out of doing a manual swap, but it would get very expensive real quick.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
| 03-02-2019, 07:54 AM | #38 | |
![]() 1013
Rep 1,934
Since xdrive is rear biased and sends power back there all the time, and to the front to a max of 40% in slippage situations, I don't believe an lsd would cause us any issues. It is perfectly fine in Audi cars, but they use a front and rear locking diff. We would just be using a single rear locking diff. For eg. Since the rear would only slip a maximum of ~30% xdrive may then send only a max of 30% to the front axles. With xDelete that would never occur and all power would go to the rear, with a max slippage of 30%. Correct me where wrong.
| 03-02-2019, 09:44 AM | #39 |
![]() 2253
Rep 4,376
Not sure what you mean by those percentages but XDrive, while biased to 60:40 rear:front, by default, can distribute power dynamically to whichever axle or wheel requires it!
Mikesmith293957.00 |
| 03-02-2019, 09:45 AM | #40 |
Rep 1,169
[QUOTE=Logicoeur;24456998]All of the current lsd options will fit an xdrive car. We use the same rear end as rwd. The difference is only in the front (tcase, axles, a few suspension components).
I will not speak to other years and models but I can tell you with one hundred percent certainty the LSD offered by BMW in 2016 for 2016 model year cars will not work with a 2016 xDrive 340, I know this because I had the Dealer try to install it in mine when I had the MPPSK installed. In 2016 and possibly other years xDrive used different rear axles than RWD, according to my Dealer there was no way to make it work, and they really wanted to make it work as they were afraid I'd walk away and leave them with an MPPSK kit they could not sell and the LSD unit they are perhaps still trying to sell.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
daveypetey36.50 VVlasy60.00 |
| 03-02-2019, 09:23 PM | #41 | |
Rep 6,191
[QUOTE=Beek;24457325]
I'd like to get an LSD like the torque vectoring sport diff in my Audi SQ5. There is a traffic circle leaving my work that the bloated SQ5 drives around like on rails. My 340 xdrive understeers like a mofo on that same circle. |
| 03-03-2019, 09:57 AM | #42 | |
Rep 1,169
[QUOTE=Wires;24459999]
| 03-03-2019, 01:31 PM | #43 |
![]() 60
Rep 130
To those saying disabling the front wheels causes more wear, I can speak from experience. I once had TC disable itself on snow, due to heat, and only the rear wheels were spinning. Until someone has evidence to show that there is excess wear, stop spreading misinformation.
| 03-03-2019, 02:50 PM | #44 | |
Rep 141
| Bookmarks |
