BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Rough idle engine shaking after car is warm
      08-10-2021, 12:51 PM   #23
Beasty_916
Drives: Bmw 435i
Originally Posted by thejeremyman9 View Post
Well you can see some strange behavior but unfortunately I am just not sure how to interpret the carly parameters or how to pinpoint what might be wrong.
You are still getting no codes, even shadow codes? I think MHD lets you scan for codes for free via their app, you might try that.
Without any codes or anything remote diagnosis may not be possible.
Still no codes I ran the scanning tool and its the sames codes as before. I think I might have to buy the bm700 scanning tool for more in depth analysis or just take it to BMW. My SA said diag is $210 my ignition coils come in next week if that doesnt help I guess ill just take it to the dealership instead of throwing random parts at it.
      08-19-2021, 09:06 PM   #24
Beasty_916
Drives: Bmw 435i
Changed ignition coils and sparks No change. Where would I start next? Still no codes.
      08-20-2021, 02:46 PM   #25
thejeremyman9
thejeremyman9's Avatar
4464
Drives: 2015 BMW 335i
Wait until a code comes up or continue throwing parts at it... fueling issue would be the next guess... injectors, etc, but again just a guess.
      08-20-2021, 09:43 PM   #26
BMWILUVU
Drives: 340ix
I think your upstream O2 is on the way out. You can inspect & clean it then reinstall and check results.
What do your exhaust tips look like? Overly or quickly sooted?
      08-21-2021, 09:23 AM   #27
jgoens
jgoens's Avatar
3824
Drives: 2013 335i msport
You might consider installing ISTA on a computer and hooking it up--I have had instances where it gave more info than phone apps.
Last car: 2011 335i Msport. JB4. Vrsf CP
      08-27-2021, 01:24 PM   #28
KeatonK
KeatonK's Avatar
Drives: 2013 335i
I have had this problem with my car for years. Only does it when its warm and parked for a little bit. If I rev it up a bit totally gone! If you find the issue please post it!
2013 335i Alpine White 88k miles and going!
bm3 stage 1, jb4 (map 0), ER Downpipe,
M Performance Exhaust, ER chargepipe, bms intake,
Fuel-it Stage 2 LPFP, HR Sport Springs, 19" Morr FS77
M Performance Alcantara Steering Wheel
      09-15-2021, 09:02 AM   #29
Beasty_916
Drives: Bmw 435i
I decided to lift my car and check the charge pipe again and I found the 2 bung holes with no screws on the bottom of the pipe. I think the screws fell out when driving which was causing a boost leak and probably giving faulty readings to the MAF causing the revving. I closed both of the holes with screws from Home Depot with basic 1/8 NPT thread and loctite So far it’s been 2 weeks since the revving has stopped so hopefully that was the only issue.
      11-07-2021, 11:35 PM   #30
Slo_F80_Mike
Slo_F80_Mike's Avatar
Drives: 2016 M3 (MW SO, 6MT)
Turns out it was just a boost leak caused by the VRSF charge pipe from the bung hole. The screw plug had fallen out on one hole, other one was quite loose. Got a new plug for the first hole and added some loctite and took the original screw out of second hole and added loctite and tightened that as well.
      02-15-2024, 02:10 AM   #31
catalin199522
Drives: bmw f25
Did you find the issue?
Did resolve the problem with this? i have the same issue
      02-15-2024, 11:31 AM   #32
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Leaking chargepipe.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
