08-11-2022, 03:35 PM | #23 | |
Rep 666
Yesterday after work, I managed to jack up the car and remove the whole front end and prep the turbo inlet area to receive the boost leak tester adapter. That part will get in tomorrow. I'll put in boost in 5psi increments all the way up to 30psi to see if I can catch anything this way. But yeah, I really want to make sure I clear the boost leak test before I go much further. Thanks so far for all the help so far.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
08-13-2022, 04:06 PM | #27 |
Rep 41
08-13-2022, 11:37 PM | #28 |
Rep 666
I don't want to steal this thread and make it my own issue; but I gotta say, my symptoms are eerily similar to what the OP has. An update today: I managed to run the boost leak tester and long story short, I've identified many small leaks around the intercooler joints and a big leak because the throttle-side charge pipe has a slight collapse on the worm-clamp ring. It's what's causing my car to limp upon boost beyond 13psi; I'm guessing because it's got "implausible" MAP reading between the leak and what the turbo's EWG's been doing. Maybe it's a good bone to throw at the OP here?
I've put mostly OEM plumbing and OEM intercooler back in and was then able to achieve 20psi,23psi, 25psi, and 28psi boost leak test, all held with flying colors. I only had enough time to button everything back together today. I'll be taking the car out on the road for real test tomorrow.
08-14-2022, 06:12 PM | #29 | |
Rep 7,629
08-15-2022, 09:11 AM | #30 | |
Rep 666
08-15-2022, 11:50 AM | #31 |
Rep 7,629
08-15-2022, 01:38 PM | #32 | |
Rep 666
I'm now chasing after two codes: 101F01 - Calculated air volumes in air intake system implausible 104B01 - Absolute pressure sensor, intake pipe, multiple fault Only get these codes upon cold start. Car drives fine and runs strong.
08-15-2022, 01:44 PM | #33 | |
Rep 4,210
Still waiting on OP to get back, but no leaks or issues with the new IC/CP setup - on your chassis any issue with the tubing bursting/Cracking?
Mods: Yes.
yupetc398.50 |
08-15-2022, 01:56 PM | #34 | |
Rep 666
No issues with the piping since I was able to fit a boost leak adapter onto the turbo inlet and introduce different levels of compressed air into it. Was able to step up to 25 psi without an issue. The two codes I list seems to be pointing to an issue with pressure during vacuum situations, ie. idle and cold start; but I don't get bad idling rpms. Very weird. The only thing I haven't gotten to replace is a valvecover (which mine is only less than 0.5 year old.) But it's a brand new OEM VC ordered through FCPeuro. So I've ordered a new one and will do the swap with them. I suspect a crack somewhere in the PCV system in that valvecover, but just don't have a way of checking it.
08-15-2022, 01:59 PM | #35 | |
Rep 4,210
Share your logs when you can I wonder what the boost and load profile look like with them installed on a stock map - may be able to compare it to thejeremyman9
Mods: Yes.
yupetc398.50 |
08-16-2022, 09:17 AM | #36 | |
Rep 666
Will replace valvecover tomorrow then go on a vacation. Will log after the vacation and see where this goes. I'm very curious too about what that log may look like.
08-16-2022, 02:36 PM | #37 |
Rep 7,629
What log are you looking for comparison?
I do have some stock logs way back in the beginning of my datazap uploads https://datazap.me/u/thejeremyman9 |
yupetc398.50 |
08-17-2022, 09:19 AM | #38 |
Rep 666
Got the valvecover replaced. fault codes 101F01 and 104B01 are both gone. Driven 40 miles this morning to confirm it. Hopefully it doesn't come back.
I'll still need to log the car in September after my vacation. Still dealing with very hard fish-bite jerk upon high load when climbing up on the rpm. Boost does get to where it needs to go, but car will go into limp mode after the surge of boost. So even on MHD stage 1, I don't get to rev it beyond 5k rpms because the car would already reach limp mode first. No codes prior to doing this, and the only codes I get after the limp mode is cylinder 6 misfire and multiple misfires. I know you guys will be diagnosing this in blind without a log. So once I get back, I'll manually log it. Am watching enough videos on youtube to learn how to operate it on the MHD app. Will also look to do a compression test to see if that cylinder is acting funny. I dearly hope it's not due to a cracked head or something wrong with the valves.
08-17-2022, 11:00 AM | #39 | |
Rep 7,629
yupetc398.50 |
08-17-2022, 02:05 PM | #40 |
Rep 666
Definitely appreciate a whole lot of you so far. Very helpful folks and knowledgeable to learn from. Will tackle to limp mode issue once I'm back in again. Will be troubling you folks to look at logs then.
b58, failure, hpfp, n55 |
