05-22-2023, 08:46 AM | #23 | |
Rep 742
The only exception is when cruising at highway speed, gently giving it gas to maintain speed, it will feel like a mild roughness, as if it skipped 1 beat once in a blue moon. Let's say in a 30-minute drive, I'll feel it once or twice. It's so mild that I could be confusing it with the crappy NJ road conditions to be honest. At the moment, I have an appt with a well-known indy shop next week so if this doesn't resolve, I'm just gonna bite the bullet and take it in. I'll keep this thread updated.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
05-22-2023, 09:11 AM | #24 | |
Insta~ f10_sapphire
158
Rep 413
05-22-2023, 09:41 AM | #25 | |
Rep 742
Also, do you know any test plan or a way to test the injectors? when I pulled the sparkplugs were dry and looked normal on all 6 plugs.
05-22-2023, 10:55 AM | #26 | |
Insta~ f10_sapphire
158
Rep 413
05-22-2023, 10:56 AM | #27 | |
Rep 742
05-22-2023, 11:02 AM | #28 | |
Rep 742
https://imgbb.com/4Z1Zk06
05-22-2023, 11:13 AM | #29 | |
Insta~ f10_sapphire
158
Rep 413
jkwhar175.00 |
05-23-2023, 03:34 PM | #31 |
Rep 742
Nope. I did the calibration as well I have a map sensor coming in.
09-15-2023, 07:58 AM | #32 |
Rep 1
10-12-2023, 11:40 AM | #33 | |
Rep 742
Now that the temps are getting cold, I noticed that on cold start, the car feels like a very very mild misfire/rought idle when keeping the rpm's low/under 25mph while driving.
03-26-2024, 12:31 PM | #34 |
Rep 10
Drives: 2016 BMW X3 xDrive 35i M Sport
Any update? Same exact issue on my X3.
03-26-2024, 12:55 PM | #35 |
Rep 742
Since my last post, I changed both VANOS solenoids and that did not fix it. The next thing I'm going to check are the fuel injectors with a borescope/inspection camera to see if they are leaking.
03-27-2024, 07:18 PM | #36 |
Rep 3
Same issue here with pretty fresh coils/plugs. Misfire/rough idling for 10-15 seconds, only on warm starts, and it doesn't *always* do it, though it does most of the time. 152.5k on my N55, plugs/coils were replaced around 125k. Runs and drives like new aside from the warm start rough idle. Stock tune and nearly stock car aside from a VRSF chargepipe. I have also noticed that my fuel range is consistently higher than actual - the car will say I have 395 miles of range on a fill-up, then I end up getting about 345 actual. If the injectors were leaking and causing that, though, that would be almost two gallons of fuel they would have had to leak to cause that amount of range reduction - not to mention, the fuel in the oil would cause the car to run rich from the gasoline vapors entering the CCV system and getting re-introduced back into the intake tract. I wonder if the throttle body or ICV (if these cars have one) need to be cleaned, as on initial startup, the car runs with the throttle body before shortly transitioning to valvetronic for air mass control - cold starts and the higher RPMs/larger throttle body opening might mask it if that is indeed the issue.
04-08-2024, 10:09 AM | #37 |
Rep 742
My estimated range vs actual range never was close but my MPG has decreased alot. It could be from the winter gas causing it so not taking this into consideration. One thing i recently noticed was my car doesn't cold start anymore (high rpm for first few mins).
To add more issues, lets say in the last 12 months, about a handful of times, I had an issue where it would crank, fail, crank again and it would start and throw drivetrain malfunction. It would throw a few codes at me...I don't think these are related to my primary issues tho. after about a minute or two, the drivetrain malfunction clears itself and the car drives perfectly. 101F01 - Trottle valve opening angle pressure ignore 1C0102 - engine oil pressure regulation 1C2002- oil pump 131501- vanos 120408- reduced power mode
04-08-2024, 05:58 PM | #38 | |
Rep 38
05-03-2024, 09:28 AM | #39 |
Rep 742
Just adding on to the list lol.
I replaced my valve cover (PVC failed) and didn't fix my warm start issue (wasn't expecting it). Also checked my injectors and none of them are leaking.
05-03-2024, 09:32 AM | #40 |
Rep 742
^^ that was fixed with a new MAF sensor.
