02-18-2024, 03:40 PM | #23 | |
Rep 2
02-18-2024, 07:00 PM | #24 |
Rep 341
thats how loud it is.. mine is the same
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
02-20-2024, 02:09 PM | #25 |
Rep 44
Ditto
Mine is louder than this even. I don't run the insulation foam anymore but I have gotten used to the noise. It's normal with the revised edition of the pump. There is however something called "breaking pulse tuning" that can be done to quiet the pump down some.
02-25-2024, 07:04 PM | #26 |
Rep 2
I just reached out to dorch and the say that noise in the cabin should be quite minimal if anything. I currently have the oem foam on the motor aswell as motor cover.. I will try running some logs
02-26-2024, 11:11 AM | #27 |
Rep 194,538
Sub'd for updates
02-26-2024, 03:11 PM | #28 |
Rep 810
I have dorch s2, I hear nothing from inside or outside the car, I have the foam under engine cover and bought their pump when it was first released. I’ve heard the pump with no foam and engine cover and it was loud, but with them on I hear zip.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-12-2024, 03:07 PM | #30 |
Rep 44
The newest version of the pump definitely makes more noise than the first generation. It's a mechanical clicking type noise that rises and falls based on throttle inputs. It's normal and eventually it just fades into the background as your rpm's climb.. The newer version was able to max out my OEM injectors quite easily on E50 with my DAW UF turbo. Rail pressure has been rock solid throughout the entire rev range. I can't recommend this product enough if you are looking to significantly improve your fueling levels for a larger turbo.
04-13-2024, 09:47 AM | #31 |
1322
Rep 3,593
Normaly.m put the sound deadening foam in..
2017 m240i xDrive 10.67@132.32mph w/bm3
04-17-2024, 11:59 AM | #32 | |
Rep 29
