07-06-2023, 06:51 AM | #23 |
Rep 110
Is there a chance that a batch of Zimmerman rotors could be defective with different part numbers? My rears started making basically the same exact noise as the fronts when I had the new rotors on and now I can’t figure out what’s going on. When you push in the brake, the same pulsating effect can be heard until you fully let go off the brake in the rears which is weird because it was fine the past few weeks and all of a sudden yesterday the problem is in the rears this time.
07-06-2023, 07:29 AM | #24 | |
Rep 3,990
So at the last NCC DIY, someone brought Zimmerman rotors they bought from FCP Euro. The part numbers and SKU on the Zimmerman rotor packaging was correct for his vehicle, but the rotors clearly didn't fit his X5. We suspected that Zimmerman packaged the wrong rotor in the box and there was no way for FCP Euro to anticipate that error. The quality across all parts manufacturers seems to have gone down. |
07-13-2023, 01:14 AM | #25 |
Rep 2
Is this the same situation here? Though, i’m not braking in the video. It used to appear when i enter parking lot, turning the wheel 45’ and slowly riding. Now it took place during slow straight
https://youtube.com/shorts/OJUuCwthOeY?feature=share |
07-19-2023, 07:39 AM | #26 | |
Rep 548
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
casualDIYer499.00 |
07-21-2023, 01:26 PM | #27 |
Rep 110
The warranty is still being worked out for the new rotors. I measured the new rotors and they are pretty much the correct size and they are identical to the old rotors. So, maybe the build quality has a defect. The supplier did send me the correct rotors for my car though. The old setup in the front is working fine for now, no weird noises.. but doesn't have much life left.
One thing I noticed is the new rotors have some sort of indented lip and each rotor has a different size indentation. Is that normal? I don't see how that would affect the braking though. |
07-23-2023, 10:44 AM | #28 | |
Rep 3,990
07-26-2023, 06:48 PM | #29 |
Rep 18
You know I been having a similar issue, not sure if that’s the case with you, I had this annoying clunk every time I depress the brakes, it’s only in the front tho, I think for me the brake pads are the issue, they are possibly just rattling around even tho I put the proper lubricant, what I recently did is I changed the rotors to the Zimmerman brand, I changed the slider pins and put new anti rattle clips, it’s cleared up about 50 percent of the clunk, but it’s still there, my problem was that I got autozone brake pads, im actually gonna buy some oem ones and replace them again, but what I would check is the brake pads themselves if you have a clunk.
07-27-2023, 08:04 AM | #30 |
Rep 603
Not sure if these will solve any of the issues in this thread but they seem like a cheap and easy option to try.
https://www.bimmerworld.com/Brakes/B...xoCXFgQAvD_BwE |
07-27-2023, 02:35 PM | #31 | |
Rep 3,990
07-28-2023, 10:01 AM | #32 |
Rep 18
Unfortunately I’ve already changed both of those parts, actually the only thing that’s left in the suspension that is still original is the sway bar itself and the bushing aren’t bad, I actually had even went as far as removing the end links and took it for a test drive to see if it was the sway bar but the clunk was still there, I’m more confident that it’s in the brake system, like I said I changed the slider pins and the rattle clip and it actually help reduce the sound, the calipers seem to move properly, not getting stuck or rusted, ima change the pads soon, I already ordered them, luckily autozone was able to exchange them, the absolute last thing I can think of is maybe some air in the brake fluid? I changed the fluid as well, maybe I didn’t bleed it right, but I’m not sure if that would be any reason to get a clunk you know, anyways once I put the new pads on I’ll post my results lol
Polo088161626.50 |
07-29-2023, 08:09 PM | #33 |
Rep 1,438
Not according to BMW's instructions.
As for why these items need to be replaced every 4 years (according to BMW). 1) The pins will warp over time making them hell to get back in and 2) the spring does lose it's springiness being less effective over time. I too am a Hawk user, with the 5.0 on the street and HP+ on the track. Not a surprise to learn the HP+, while still doing well for a track day pad, have been cut down quite a bit. When the brake is applied I can hear the clack of the piston hitting the pad. Never had an issue with it.
07-30-2023, 09:36 AM | #34 | |
Rep 1,438
As mentioned, clacking pads are not unusual as they wear down and the space between the pad and rotor gets bigger. A new set should eliminate this issue. If you had put in new pads and they ran down rather quickly, you've discovered a crap brand/model of pad. From what I've seen, the cheapo (~$20 per pair) pads actually work fine for city driving. Where they fail is under hard braking e.g. an emergency stop where they tend to disintegrate rather quickly. You could be out driving for weeks using little pad then have one incident where you hammer the brakes really hard and consume 25% or more of the pad. Cheap pads tend to live much shorter lives than the premium makes and models as the cardboard in them doesn't last long.
Polo088161626.50 |
