06-03-2024, 06:06 PM | #23 | |
Rep 2,018
06-04-2024, 12:09 AM | #24 | |
Rep 524
For this sort of abrasion your pads were very excessively engaged, this level of corrosion could have been boosted by extreme temperatures due to excessive friction of pads with a disc, but only on the inside. So I see no argument for manufacturing defect of a disc in this case.
1995 E34 525td auto • 2016 F30 320ed auto
06-04-2024, 05:06 AM | #25 | |
Rep 802
Drives: 2018 F80 M3 CP YMB
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
06-04-2024, 08:47 AM | #26 |
Rep 1,467
Looks like the pads haven't worn down uniformly, slightly tapered, which would indicate binding in the caliper carrier.
The inboard side of the disc is in that state because the outboard pads have done most of the work, whilst the inboard side has just rusted away, which Ennoch was spot on about. Exactly the same thing happens with old steel sliding caliper brakes as well. |
06-04-2024, 03:29 PM | #27 |
Rep 524
Out of interest, can you measure thickness of the disc on both sides - They also look well under the wear limit, especially corroded side.
Btw have you heard of a concept that corrosion is a slow process of burning?
06-05-2024, 02:08 AM | #28 | |
Rep 872
A similar thing happened to our MY20 X4. The corrosion was so bad that the pads 'clicked' as they were applied. It didn't have disc wear like this though. All that said though, the pads are barely half-worn. Asymmetric wear, whether insiside/outide or upper/lower would surely be significant with that level of disc wear. I exercised all the pistons with my thumbs and all 4 moved freely and easily with my thumb. Ill see if i can measure the discs later on. Ill have to use a shim as i only have a vernier caliper. |
06-05-2024, 12:23 PM | #29 | |
Rep 2,158
06-09-2024, 06:37 AM | #30 |
Rep 463
This is a common problem with Porsche drilled discs, holes fill with water (especially after washing) and rot the inner face.
Only solution seems to be blowing the water out of the holes with compressed air or not fitting drilled discs. |
Ennoch2391.50 |
06-09-2024, 12:10 PM | #31 | |
Rep 524
I don't know about Porsche discs, but if you examine OP pictures carefully - disc is corroded in many places, and it not typical for any type of discs, vented, non-vented, drilled or non-drilled. It's overheating due to excessive friction either from stuck pads or a bad caliper.
06-13-2024, 11:19 AM | #33 | |
Rep 1,467
I suppose if the pitting gets really bad, a machine shop could shave the corroded areas down and fashion some kind of stainless pad. The strongest JB weld available might fill in the pitting as a short term fix though. As you say, shite quality from Brembo there really, given BMW charge about £750 each for the fronts. Not letting the pads wear down to nothing to minimise sliding and corrosion may also help. I think because the OEM pads have wrap around shims to slide on the caliper carrier, they could get away with not using stainless inserts. |
06-14-2024, 06:06 AM | #34 |
Rep 2,158
No Brembo OEM caliper, at least on boggo models, comes with wear plates to my knowledge. But all cars with them have issues; Renault Megane 225's have issues with snapped bleed nipples, the Subaru STI/Evo calipers are notorious for stripping the mounting bolt threads, and the nipples seizing too. And the 370mm calipers are even worse at £1200 not £750, as BMW tried to charge when they snapped the bleed nipple off. I just got a local engineering place to fit a Nipple Therapy insert for a total of £75 and we were done. BMW of course 'strongly advised against this'.
I'm really not sure that pad wear levels would really impact it, and having looked at the shim I'd actually suggest the lower surface area compared to just leaving the pad without it would actually contribute to digging in as it's a smaller moving surface than the whole pad edge for the load to push against. It's all minor though, the big issue is that it's unprotected aluminium, mounted to steel and in a salty environment so galvanic corrosion is massively sped up by the electrolyte. My front left is the worst and is also the one which has now got sticky pistons causing brake drag. I'm going to chance my arm with getting BMW to replace it under warranty but I suspect I'll just end up taking them off myself, repainting and then rebuilding with new seals. It'll be less hassle than the typical arse of dealing with a service manager who tries to tell me the usual lies and bollocks to justify not doing something. I'm certainly not paying £1200 for a new one, that's mental money. |
06-14-2024, 07:17 AM | #35 |
2320
Rep 2,497
Going back to my E38 728i in 2010; had the Brembo 4 pot calipers up front
Took me a few weeks to source the parts for my pal to refurb them and even then the bleed nipples were fubar! Looks like they've never learned!
06-15-2024, 05:57 AM | #36 | |||
Rep 1,467
