01-19-2011, 05:16 PM | #23 |
Rep 1,271
Where does it say N52 will be obsolete? from what I can see it sais the inline 6 on CERTAIN models will be replaced with the I4 turbo engine. as following:
E89 Z4 sDrive30i F10/F11 528i F25 X3 xDrive28i E81/E87 Someone correct me if i'm being a spaz here.
Monte Carlo Blue M3 Comp |
01-19-2011, 05:36 PM | #24 | |
Rep 998
Once the F20 launches, this engine will likely power the highest trim (today's 130i) and the F30 will also launch with this engine powering the 328i. So essentially 28i every car that is currently powered by a N52 will switch over to this engine. |
01-19-2011, 05:41 PM | #25 |
Rep 323
Well I truly do believe these engines will be better in every respect or I truly believe bmw would not have taken this leap. However you just cannot help be sad to see the end of the bmw Inline 6! I mean how many famous bmw's had an inline 6 engine, so many car magazine raves and so many years refining their trademark. Really a sad day, however in the end I do believe both bmw and M division will perfect these turbo applications where we will not be able to tell the difference between an NA and these but will have more power, torque, efficiency and at a lower cost. That is the great thing about technology
01-19-2011, 05:49 PM | #26 | |
Rep 3,445
Absolutely! I just want to highlight the FUD. If there are no I6 engines for the new 1 series the engine bay can be shorter by about 8 inches. That space can be reallocated to the rear seat and boot. I have no doubt that BMW will get it right. My N55 135i is a blast to drive. It is not my first turbocharged car, but it is my first piston engine turbo. Years ago I owned a single turbo RX7 rotary. Rated HP was only 180, but it was fast because it only weighed about 2700 pounds. It did not even have power steering. My 135i goes 65 to 105 mph about as quick as the RX7 could do 65 to 90 mph. I really like the growl that the N55 makes. The 135i is as quick as my 1992 6 Sped LT1 Corvette, but the 135i does it's thing with much less drama. In inflation adjusted dollars, the 135i cost less.
See my photography at http://ronscubadiver.wordpress.com
01-19-2011, 06:09 PM | #27 | |
Rep 998
01-19-2011, 06:57 PM | #29 |
Rep 331
F20 and F30 are based on the same platform, so I don't think they can design the F20 for I-4 engine only. Both can take I-6 engines in my opinion.
Even if they make it I-4 only they can't pull the engine all the way forward because the weight distribution won't be ideal. |
01-19-2011, 10:50 PM | #32 |
Rep 1,585
01-19-2011, 11:46 PM | #34 |
Rep 426
Yeah Right! Since when did BMW lower prices? If they were going to lower the price these would've named X25i's
G30 540i Msport
G05 X5 xDrive40i Msport Retired '03 330i, '10 335d |
01-19-2011, 11:48 PM | #35 | |
Rep 426
To all you turbo lovers... A Turbo engine will never match the throttle response of a NA engine with 8 individual throttle bodies
G30 540i Msport
01-19-2011, 11:57 PM | #36 |
310
Rep 15,745
Its odd to say but BMW has completed its life circle 360 degrees. They started with 4 cylinders in the 2002s and first 3 series, and now look where they have ended up.
01-20-2011, 03:30 AM | #37 | |
Rep 1,898
1.5 3cyl FI 2.0 4cyl FI 3.0 6cyl FI 4.0 8cyl FI all to save cost by using the same parts. A 2.2 would not fit this scheme. |
01-20-2011, 05:05 AM | #38 |
130i Treiber
120
Rep 1,432
Drives: BMW 130i
# BMW 130i /// + SPARCO Assetto Gara 8x18 bronze + KW + PP SteeringWheel II +PP Exhaust +PP Kidneys + PP AirFilter + PP Style Flaps + PP SS Kit + AC-Schnitzer Gear Knob + MorVision Diffusor + LCI Blacklines high + GroundZero-Audio #
01-20-2011, 05:12 AM | #39 |
Rep 402
Thanks for telling us something we figured out a couple years ago.
01-20-2011, 05:14 AM | #40 |
Rep 402
What exactly do you think is going to happen? As soon as they shut down production, your M3 is going to explode? Enjoy the car for as long as you want to keep it. I for one am excited to eventually own a TT M3...in it's 2nd year of course
01-20-2011, 06:13 AM | #42 |
130i Treiber
120
Rep 1,432
Drives: BMW 130i
Its boing to Be a 4 banger too...
01-20-2011, 06:45 AM | #44 |
Ignorance is Bliss?
101
Rep 484
